- To:
- Subject: Re: [cgal-discuss] 2D Minimum width annulus reference
- Date: Mon, 7 Feb 2011 09:18:26 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:from:date :x-google-sender-auth:message-id:subject:to:content-type; b=mANen7GCv9siwRTJV8a0x8IKBpEDcBuKO8DWQkQ2yhWX4z86piU95WtzumQK9uNxbm A/kptMa6wSGlPbHGR0sdMbuqlcnaZu+b2DiRVAYfI6nFapQup9q5vGedr0DedUYgBVzB a+9jIlNsF4vfEDjMth9C3Ht/jnR3O9PdTvP7o=
Hi,
I once created an application computing the minimum width annulus, but it did not use the fastest tools in CGAL.
The solution consists of:
1) Computing the Voronoi diagram of the set of points - you can do that using Delaunay and and Voronoi adapter.
2) Computing the farthest Voronoi diagram of the set of points - you can use convex hull, but I am not sure whether there is an easy way to convert it to the Voronoi diagram.
3) Convert the Voronoi diagram to an Arrangement_2 and overlay them.
4) Iterate on the vertices of the diagram and check which is the minimum.
On my program, I used Envelope_3 to compute both Voronoi diagrams, and did not have to convert it to Arrangement_2 (as Envelope_diagram_2 is already of "type" Arrangement_2).
HTH,
Ophir
On Sun, Feb 6, 2011 at 12:41 AM, ulund <> wrote:
Wondering if anyone has a reference to a published application of using CGAL
to find the minimum width annulus in 2D. I'm looking for a publication that
has the data and the solution.
Thanks,
UL
View this message in context: http://cgal-discuss.949826.n4.nabble.com/2D-Minimum-width-annulus-reference-tp3262422p3262422.html
- [cgal-discuss] 2D Minimum width annulus reference, ulund, 02/05/2011
- Re: [cgal-discuss] 2D Minimum width annulus reference, Ophir Setter, 02/07/2011
