- To:
- Subject: Re: [cgal-discuss] Checking for a vertex in a Polyhedron
- Date: Mon, 07 Feb 2011 08:51:01 +0100
You might give this a try:
std::map<Point_3, Vertex_handle>
andreas
On 05/02/2011 17:36, vanimurarka wrote:
Hi,
Is there a way I can query a polyhedron model to check whether a point
exists as a vertex in the polyhedron?
I looked into the documentation and could not seem to find any direct query.
I do not really want to iterate over the whole set of vertices because this
query needs to be done repeatedly in the algorithm I am implementing.
If there is no direct query, what are the suggestions for the shortest /
most efficient way of obtaining this information?
At present, the best I can think of is to maintain a separate HashTable of
the vertices added to the polyhedron, where the x-y-z co-ordinate of the
vertex is concatinated as a string to serve as the key of the HashTable.
Then when I have a new point, I can use its co-ordinate values to query the
HashTable. However, I might possibly run into accuracy issues.
Thanks
Vani
- [cgal-discuss] Checking for a vertex in a Polyhedron, vanimurarka, 02/05/2011
- Re: [cgal-discuss] Checking for a vertex in a Polyhedron, Sebastien Loriot (GeometryFactory), 02/07/2011
- Re: [cgal-discuss] Checking for a vertex in a Polyhedron, Andreas Fabri, 02/07/2011
- [cgal-discuss] Re: Checking for a vertex in a Polyhedron, vanimurarka, 02/22/2011
