- To:
- Subject: Re: [cgal-discuss] Re: Arbitrary Ray Shooting on Arrangement
- Date: Thu, 10 Feb 2011 16:33:38 +0100
nsoonhui wrote:
Hello, I look through my CGAL installation directory, and I don't find"Arr_landmarks_pl_impl.h" file.Are you using CGAL-3.7?
this include file is located here:
CGAL-3.7/include/CGAL/Arr_point_location/Arr_landmarks_pl_impl.h
May I know where it is located? And whether is it an example file, or core source file?
On Wed, Feb 9, 2011 at 7:12 PM, Efraim Fogel [via cgal-discuss] <[hidden email] </user/SendEmail.jtp?type=node&node=3299358&i=0>> wrote:
nsoonhui wrote:
> For 2D Arrangement, one is able to do
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Arrangement_on_surface_2/Chapter_main.html#Subsection_30.3.2
> vertical ray-shooting query . But unfortunately, for a lot of
application,
> doing vertical ray shooting is a bit too limiting; is there
anyway I can do
> arbitrary direction ray shooting ( i.e, I can shoot the ray in
any direction
> given any query point, and find whether the ray intersects a
vertex, an edge
> or a face, not just vertically)?
> You can construct a ray (or a long segment) in the given direction
emanating from the query point. Then, "walk" along the ray, in a
similar
way to the walk is applied by the Landmark point location; see
Arr_point_location/Arr_landmarks_pl_impl.h.
-- ____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
-- You are currently subscribed to cgal-discuss.
If you reply to this email, your message will be added to the
discussion below:
http://cgal-discuss.949826.n4.nabble.com/Arbitrary-Ray-Shooting-on-Arrangement-tp3296800p3297052.html
<http://cgal-discuss.949826.n4.nabble.com/Arbitrary-Ray-Shooting-on-Arrangement-tp3296800p3297052.html?by-user=t>
To unsubscribe from Arbitrary Ray Shooting on Arrangement, click
here
<http://cgal-discuss.949826.n4.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=3296800&code=c29vbmh1aS5uZ3VAZ21haWwuY29tfDMyOTY4MDB8NDk0OTIzNDUy&by-user=t>.
View this message in context: Re: Arbitrary Ray Shooting on Arrangement <http://cgal-discuss.949826.n4.nabble.com/Arbitrary-Ray-Shooting-on-Arrangement-tp3296800p3299358.html>
Sent from the cgal-discuss mailing list archive <http://cgal-discuss.949826.n4.nabble.com/> at Nabble.com.
- [cgal-discuss] Arbitrary Ray Shooting on Arrangement, nsoonhui, 02/09/2011
- Re: [cgal-discuss] Arbitrary Ray Shooting on Arrangement, Efraim Fogel, 02/09/2011
- [cgal-discuss] Re: Arbitrary Ray Shooting on Arrangement, nsoonhui, 02/10/2011
- Re: [cgal-discuss] Re: Arbitrary Ray Shooting on Arrangement, Sebastien Loriot (GeometryFactory), 02/10/2011
- Re: [cgal-discuss] Re: Arbitrary Ray Shooting on Arrangement, Efraim Fogel, 02/14/2011
