- To:
- Cc: "Sebastien Loriot (GeometryFactory)" <>
- Subject: Re: [cgal-discuss] CGAL assertions using Minkowski_sum_3
- Date: Sun, 13 Feb 2011 09:30:59 -0500
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:user-agent:mime-version:to:cc:subject :references:in-reply-to:content-type; b=URWeeFE9BTeKpYkFCqrxwmotuuc7vI/x+phGULClsT63MaP3m0VsJsHMA8WNbeRA3R aWX1w7KrnLH2sWWWFbb2q90Simpqf4DQVWTDe8aYz1LnXVdxPM9vECvpprvToh7WaK+n bPYSVXKltOmPDBfAcBl0FrGeMlygGSJ7lJlUo=
Thank you for your continued help with this problem. I must admit that some of my problems were with incorrectly oriented shapes. I wish that was my only problem though, because that I can fix.
Attached is my small example program using the kernel you suggested. Also attached are two shapes that I carefully examined. All facets of both shapes should be counter-clockwise oriented. With this program and these input shapes, I still get the assertion violation.
I hope you can have the time to verify that what I have done here is valid, and if so work towards a fix in CGAL.
Thanks a lot.
On 02/07/2011 03:15 AM, Sebastien Loriot (GeometryFactory) wrote:
J.L.M. wrote:# Created by the script cgal_create_cmake_script
I just tried the kernel you suggested and I get the same problem.Did you correctly orient the cube? (as explained in one of my previous
terminate called after throwing an instance of
'CGAL::Assertion_exception'
what(): CGAL ERROR: assertion violation!
Expr: Ntmp.is_valid()
File:
/import/lightcycle/home/jlm/school/masters_thesis/code/CGAL-3.7/include/CGAL/Minkowski_sum_3/bipartite_nary_union_sorted_combined.h
Line: 222
Aborted
email)
try with the one attached.
S.
On 01/24/2011 03:10 AM, Sebastien Loriot (GeometryFactory) wrote:
I add a quick look but did not have time to finish my investigations.
Can you try with CGAL::Simple_cartesian<CGAL::Gmpq> as Kernel and tell
us whether you also observe the same problems?
S.
J.L.M. wrote:
I was wondering if any progress has been made to fix the boundary
function for Nef_polyhedron_3. I am using this code in a thesis, and I
am finding that I can not avoid the assertion in the Minkowski_sum_3
if I use a non-convex polyhedron. Limiting my input to convex
polyhedra greatly reduces the utility of my implementation, and my
experiment depends on non-convex polyhedra.
Thank you for your time.
Jason M'Sadoques
On 12/27/2010 04:32 PM, J.L.M. wrote:
Sebastien,
Thank you for your reply. I have been on holiday, or I would have
responded sooner. I hope you will be able to provide a fix to the
boundary function, as this is essential to my research. If there is
anything I can do to help, please let me know.
Here are a few responses to your statements. The call to boundary is
necessary for my work. What I am computing is the feasible region that
contains all points in which the object can be placed and be wholly
contained in the container (stored in result). If you would like, I
have
a paper I can provide to you that shows how this works.
Second, I am wondering about your statement that I need to make a copy
of container. I see that the minkowski_sum_3 modifies the input,
and in
my example code the input is container_boundary, and object.
container_boundary should be a copy of container (well just the
boundary
of course).
You are correct that the result is empty in this example. The correct
algorithm uses the interior of the object (actually the inverted
interior) in the Minkowski sum. I removed that part while simplifying
the code to one that shows the problem.
Thank you for pointing out the non-standard OFF files. I am
creating my
shapes in Blender, and I have to post-process them. First, Blender
gives
me coordinates that are something like 1.00001 or 0.99999, and I need
them to be exact whole numbers for accurate computations. Also,
Blender
has Z increase up, and Y increase into the scene, which is different
than I am used to with OpenGL, so I swapped those coordinates. It must
be in my swapping of those that I have switched the orientation of the
facets.
Thank you again for your time.
On 12/20/2010 08:26 AM, Sebastien Loriot (GeometryFactory) wrote:
J.L.M. wrote:
I have been writing some programs that use the Nef_polyhedron_3 andIt seems their is a problem in boundary function.
Minkowski_sum_3 portions of the CGAL library. I have discovered a
number of assertions with various input shapes. The attached
backtrace
shows one example problem. I have also attached a small example
program, and the input shapes. The l-shape is shown in the attached
jpeg file.
This problem shows up in both CGAL 3.7 and 3.6.1. I am using GCC
4.5.1
on Arch Linux with kernel version 2.6.36.
I think this is a bug, since it does not occur with other input
shapes. I would be very grateful if someone can help me fix it since
the Minkowski_sum_3 is essential to my research.
Jason M'Sadoques
If I replace:
Nef_polyhedron_3 container_boundary(container.boundary());
by
Nef_polyhedron_3 container_boundary(container);
Your program runs fine (with your data, the call to boundary is
superfluous).
Note that as you are then reusing "container", you need to make a
copy
of it
(see
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Minkowski_sum_3/Chapter_main.html)
Note also that the difference you are computing will be empty as the
Minkowski sum contains "container".
Finally, note that facets of your cube are clockwise oriented
while the
usual convention is to use counterclockwise oriented faces in off
files.
I'll try to find a fix to boundary function and will post it here.
S.
# This is the CMake script for compiling a CGAL application.
project( Nef_3_example )
CMAKE_MINIMUM_REQUIRED(VERSION 2.4.5)
set(CMAKE_ALLOW_LOOSE_LOOP_CONSTRUCTS true)
if ( COMMAND cmake_policy )
cmake_policy( SET CMP0003 NEW )
endif()
find_package(CGAL QUIET COMPONENTS Core )
if ( CGAL_FOUND )
include( ${CGAL_USE_FILE} )
include( CGAL_CreateSingleSourceCGALProgram )
include_directories (BEFORE ../../include)
#I'm just adding the output of sdl-config --cflags -libs below.
set(CMAKE_CXX_FLAGS "-frounding-math -ggdb3 -lGL -lGLU -lglut
-I/usr/include/SDL -D_GNU_SOURCE=1 -D_REENTRANT -L/usr/lib -lSDL -lpthread")
#create_single_source_cgal_program( "bug_union_find.cpp" )
create_single_source_cgal_program( "bug_ntmp_invalid.cpp" )
#create_single_source_cgal_program( "containment.cpp" )
#create_single_source_cgal_program( "locate_point.cpp" )
else()
message(STATUS "This program requires the CGAL library, and will not be
compiled.")
endif()
/* This program shows the bug terminate called after throwing an instance of 'CGAL::Assertion_exception' what(): CGAL ERROR: assertion violation! Expr: Ntmp.is_valid() File: /import/lightcycle/home/jlm/school/masters_thesis/code/CGAL-3.6.1/include/CGAL/Minkowski_sum_3/bipartite_nary_union_sorted_combined.h Line: 222 Aborted */ #include <CGAL/Exact_predicates_exact_constructions_kernel.h> #include <CGAL/Nef_polyhedron_3.h> #include <CGAL/IO/Nef_polyhedron_iostream_3.h> #include <CGAL/minkowski_sum_3.h> #include <CGAL/Polyhedron_3.h> #include <CGAL/OFF_to_nef_3.h> #include <fstream> //typedef CGAL::Exact_predicates_exact_constructions_kernel Kernel; typedef CGAL::Simple_cartesian<CGAL::Gmpq>::Kernel Kernel; typedef CGAL::Nef_polyhedron_3<Kernel> Nef_polyhedron_3; typedef CGAL::Polyhedron_3<Kernel> Polyhedron_3; int main(int argc, char* argv[]) { Nef_polyhedron_3 container; std::ifstream file_stream("shapes/l_shape.off"); int unhandled_facets=CGAL::OFF_to_nef_3(file_stream, container); file_stream.close(); file_stream.clear(); file_stream.open("shapes/cube.off"); Nef_polyhedron_3 object; unhandled_facets=CGAL::OFF_to_nef_3(file_stream, object); Nef_polyhedron_3 container_boundary(container.boundary()); Nef_polyhedron_3 result=container-CGAL::minkowski_sum_3(container_boundary, object); return(0); }OFF
8 6 0
1 -1 -1
1 -1 1
-1 -1 1
-1 -1 -1
1 1 -1
1 1 1
-1 1 1
-1 1 -1
4 0 1 2 3
4 4 7 6 5
4 0 4 5 1
4 1 5 6 2
4 2 6 7 3
4 4 0 3 7
OFF
16 14 0
1 -1 -1
1 -1 1
-1 -1 1
-1 -1 -1
3 3 -1
3 3 1
-1 3 1
-1 3 -1
1 1 1
3 1 1
1 1 -1
3 1 -1
1 3 1
-1 1 1
-1 1 -1
1 3 -1
4 0 1 2 3
4 4 5 9 11
4 13 2 1 8
4 13 14 3 2
4 6 7 14 13
4 6 13 8 12
4 12 8 9 5
4 15 12 5 4
4 7 6 12 15
4 0 10 8 1
4 10 11 9 8
4 0 3 14 10
4 7 15 10 14
4 15 4 11 10
- Re: [cgal-discuss] CGAL assertions using Minkowski_sum_3, J.L.M., 02/06/2011
- Message not available
- Re: [cgal-discuss] CGAL assertions using Minkowski_sum_3, J.L.M., 02/13/2011
