cgal-discuss - Re: [cgal-discuss] How to do Delaunay tetrahedralization for several triangulated surfaces
  • To:
  • Subject: Re: [cgal-discuss] How to do Delaunay tetrahedralization for several triangulated surfaces
  • Date: Mon, 21 Feb 2011 14:52:19 +0100
xianhai meng wrote:
I mean, for example, I have two intersected surfaces, both are represented by
triangular mesh. At the intersection line between the two surfaces, the two
meshes are watertight, but not consistent in topologcial.
What do you mean by "not consistent in topologcial" ?
Are you dealing with closed polyhedral surfaces?
I want to use the Polyhedral_mesh_domain_3 to contain the two surfaces, and
generate tetrahedron mesh by Mesh_complex_3_in_triangulation_3.
However, I was confused by how to input the two surface into mesh_domain.
Should I convert the two triangle meshes of two surfaces into Polyhedron in
CGAL and set it to mesh_domain, like below:
Polyhedron polyhedron;
//convert two meshes into polyhedron
Mesh_domain domain(polyhedron);
C3t3 c3t3 = CGAL::make_mesh_3<C3t3>(domain, criteria, no_perturb(),
no_exude())
But it seems to that the no-manifold are not supported by Polyhedron and how to
do for the intersected part?
Or do I need to construct two Polyhedron in CGAL for the two surfaces? But if
so, how to input two Polyhedrons into the mesh_domain?
