- To:
- Subject: Re: [cgal-discuss] Can CGAL cope with very long numbers?
- Date: Mon, 28 Feb 2011 17:45:04 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:user-agent:mime-version:to:subject:references :in-reply-to:content-type:content-transfer-encoding; b=eYp/dm7U1cUEuV+kac+b5oFJI2BsAoe+yq5RSTUKg/xwI0NBHF9xiTMbeRUk4gwhmz q6JtufOhzRH5cgpB9jV58vV99BCeFN5K9XEodnv44wSlMbl5vD/69PLf7oKhIMMJUApV CpuavIFAZ3J4cDV3KS4hxXbVXYEz36CIXkfUQ=
Thank you for your answer.
I'm not sure how to achieve this.
I have a good coordinates values, but only when I write it in console like this:
printf("%.3f, %.3f.... ", x, y )
The thing is I need to have it written in file. I use:
f<<x<<y
But I probably do sth wrong here, when I make a new point:
Point(x,y)
These x and y are not as simple as I write here because I get them from a function. But they are ok - as long as I use printf. So what am I doing wrong?
I would be very grateful for help.
Regards,
annie
W dniu 2011-02-28 08:26, Sebastien Loriot (GeometryFactory) pisze:
annie wrote:
Hello,The only version we provide support for is the latest one, CGAL-3.7.
Just would like to know, is it possible for CGAL-3.4 to process in CDT
(constrained Delaunay triangulation) numbers such 5555555.555 as coordinatesNot sure to understand the question. If you mean exact representation, gmp and mpfr can be used with CGAL.
or is it a problem? I'm having some problems with application and that's
why I'm asking about CGAL possibilities ;)
S.
Would be very grateful for answer.
Regards,
annie
- [cgal-discuss] Can CGAL cope with very long numbers?, annie, 02/27/2011
- Re: [cgal-discuss] Can CGAL cope with very long numbers?, Sebastien Loriot (GeometryFactory), 02/28/2011
- Re: [cgal-discuss] Can CGAL cope with very long numbers?, aneta, 02/28/2011
- [cgal-discuss] Re: Can CGAL cope with very long numbers?, annie, 02/28/2011
- Re: [cgal-discuss] Re: Can CGAL cope with very long numbers?, Laurent Rineau (GeometryFactory), 02/28/2011
