cgal-discuss - [cgal-discuss] Minkowski sum error
  • To:
  • Subject: [cgal-discuss] Minkowski sum error
  • Date: Mon, 28 Feb 2011 10:37:54 -0800 (PST)
I get the following run-time error when executing
http://cgal-discuss.949826.n4.nabble.com/file/n3328469/main.cpp main.cpp :
The polygon a is simple.
The polygon b is simple.
The polygon a is not convex.
The polygon b is not convex.
The polygon a is not clockwise oriented.
The polygon b is not clockwise oriented.
terminate called after throwing an instance of 'CGAL::Assertion_exception'
what(): CGAL ERROR: assertion violation!
Expr: *sl_iter == curve
File: ../CGAL/include/CGAL/Sweep_line_2/Basic_sweep_line_2_impl.h
Line: 488
Aborted
I run it on a a patched version of CGAL-3.7 on Ubuntu Lucid and compile it
with:
g++ -I$CGAL_PATH/include -fPIC -frounding-math -L$CGAL_PATH/lib
-Wl,-rpath,$CGAL_PATH/lib -lCGAL -lmpfr -lgmp -lCGAL_Core -o reproduce
main.cpp
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Minkowski-sum-error-tp3328469p3328469.html
  • [cgal-discuss] Minkowski sum error, tofa, 02/28/2011
