- To:
- Subject: Re: [cgal-discuss] Triangulation_2_example problem
- Date: Fri, 04 Mar 2011 14:13:45 -0500
thanks sara, i installed it following your tutorial and it worked. even the example program. now im trying to run the Triangulation_2 example, and when i start a new instance and run it it says it cant find libgmp-10.dll on the system, but i already saw it is in the normal cgal..\auxiliary\gmp\lib directory. do i have to manually include it somehow or what else may cause this?
- [cgal-discuss] Triangulation_2_example problem, Fabio Casado Ruiz, 03/02/2011
- Re: [cgal-discuss] Triangulation_2_example problem, sara Samadi, 03/02/2011
- Re: [cgal-discuss] Triangulation_2_example problem, Fabio Casado Ruiz, 03/04/2011
- Re: [cgal-discuss] Triangulation_2_example problem, Nicholas Mario Wardhana, 03/05/2011
- Re: [cgal-discuss] Triangulation_2_example problem, Fabio Casado Ruiz, 03/06/2011
- <Possible follow-up(s)>
- Re: [cgal-discuss] Triangulation_2_example problem, sara Samadi, 03/05/2011
