- To:
- Subject: Re: [cgal-discuss] Dynamic library for Windows
- Date: Wed, 9 Mar 2011 12:35:04 +0100
Le mardi 08 mars 2011 18:56:50, DannyM a écrit :
> Hello,
> is it possible to generate shared or dynamic libraries of CGAL for Windows
> OS ? In the installation manual I found only "Under Windows we only
> support the static versions of the Cgal libraries". Why only static libs
> supportet ?
So that a DLL is usable, on Windows, the developers of the library need to
use
the special attribute "__declspec(dllexport)". See the documentation:
http://msdn.microsoft.com/en-us/library/a90k134d.aspx
As for CGAL libraries, we have not done that work so far.
Why do you need to compile CGAL as a DLL? It might be a motivation for us to
try implementing that support for CGAL-3.9 (next release CGAL-3.8 is about to
be published and can not longer be developped).
Laurent Rineau, PhD
- [cgal-discuss] Dynamic library for Windows, DannyM, 03/08/2011
- Re: [cgal-discuss] Dynamic library for Windows, Laurent Rineau (GeometryFactory), 03/09/2011
- Re: Re: [cgal-discuss] Dynamic library for Windows, DannyM, 03/09/2011
