- To:
- Subject: Re: [cgal-discuss] Interior or exterior point
- Date: Mon, 21 Mar 2011 08:06:38 +0100
schrodingersnewcat wrote:
Hello Everyone,
I have a program which builds Nef_polyhedra to represent a physical
geometry. In order to continue I need to evaluate points and determine if
they are interior or exterior to the polyhedra in my space. I can use the
Nef_polyhedron::locate() to get an object handle just like on page 1871 of
the CGAL manual. So the problem is if the object is a volume, how can I
determine if that volume is inside or outside my polyhedron?
Thanks for your help.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Interior-or-exterior-point-tp3392299p3392299.html
the mark() function returns 0 is the volume is outside the Nef polyhedron and 1 otherwise.
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Nef_3_ref/Class_Nef_polyhedron_3-Traits---Volume.html
This member function is also available of other dimensional simplices.
S.
- [cgal-discuss] Interior or exterior point, schrodingersnewcat, 03/21/2011
- Re: [cgal-discuss] Interior or exterior point, Sebastien Loriot (GeometryFactory), 03/21/2011
- [cgal-discuss] Re: Interior or exterior point, schrodingersnewcat, 03/21/2011
