- To:
- Cc: Fabio Casado Ruiz <>
- Subject: Re: [cgal-discuss] CGAL in Eclipse (ubuntu)
- Date: Wed, 23 Mar 2011 21:38:23 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:from:date :x-google-sender-auth:message-id:subject:to:cc:content-type; b=UFM3y9W18DWhSr/YnNB/6zomioG1KMQiyREKW2drXcJLdHVmknlzLEmR4nMfvJfYct 74B1znUMf4Qy/kwDtkJJohzqdfXWx1YOGuAiD75vjVa/xYIT5vEVao39kZE6u9B5KRiw Ch3Ufv6RsJqKwHUYmK2qJV0mYsAso71k46mQs=
Hi,
CGAL uses CMake for generating makefiles/project files for different environments.
CMake in Ubuntu (at least the latest) supports the generation of eclipse project files:
http://www.vtk.org/Wiki/Eclipse_CDT4_Generator
I would try this.
O
I would try this.
O
On Wed, Mar 23, 2011 at 8:29 PM, Fabio Casado Ruiz <> wrote:
hi, im trying to build an example (in this case constrained delaunay triangulation) in Eclipse. i've added the CGAL library and the include directory. all builds perfectly but when I try tu run it reports:
error while loading shared libraries: libCGAL.so.7: cannot open shared object file: No such file or directory
The libCGAL.so.7 file exists in CGAL\lib, no problem there, so i dont know what the problem is.
thanks for the help,
Fabio
- [cgal-discuss] How to remove edges from Bezier arrangement?, stzpz, 03/14/2011
- Re: [cgal-discuss] How to remove edges from Bezier arrangement?, Sebastien Loriot (GeometryFactory), 03/14/2011
- Re: [cgal-discuss] How to remove edges from Bezier arrangement?, Stzpz, 03/14/2011
- Re: [cgal-discuss] How to remove edges from Bezier arrangement?, Stzpz, 03/23/2011
- [cgal-discuss] CGAL in Eclipse (ubuntu), Fabio Casado Ruiz, 03/23/2011
- Re: [cgal-discuss] CGAL in Eclipse (ubuntu), Ophir Setter, 03/23/2011
- Re: [cgal-discuss] CGAL in Eclipse (ubuntu), Joachim Reichel, 03/26/2011
