- To:
- Subject: Re: [cgal-discuss] Beginner: Delauny Triangulation in Tecplot-Format
- Date: Mon, 28 Mar 2011 11:39:23 +0200
Hello George,
First look at the first example here:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_3/Chapter_main.html#Subsection_37.5.2
and replace color by an integer type and set to each vertex an index.
Then use
Finite_edges_iterator t.finite_edges_begin()
Finite_edges_iterator t.finite_edges_end()
to iterator over all finite edges of the triangulation.
Remember that as documented here:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/TriangulationDS_3_ref/Concept_TriangulationDataStructure_3.html
an edge in a 3D triangulation is of type Triple<Cell_handle, int, int>,
(c,i,j) is the edge of cell c whose vertices indices are i and j.
so if eit is an iterator over edges,
eit->first->vertex(eit->second)->info() and
eit->first->vertex(eit->third)->info() will give you the indices
of the two vertices of an edge.
S.
GGeorge wrote:
Hello Mariette,
I want to use CGAL to make a 3D-Delauny-Triangulation for Tecplot (Tecplot
seems to be suited only for 2D).
I started from the example triangulation_prog1.cpp and
triangulation_prog1.cin :
1 0
3 2
4 5
9 8
7 4
5 2
6 3
10 1
Tecplot needs a connectivity list which is based on the line number / order
of the points given:
1 8 6
3 1 2
3 5 4
8 4 5
6 2 1
3 7 5
7 3 6
7 8 5
6 8 7
I started with something like that:
for(Finite_faces_iterator fc = t.finite_faces_begin() ; fc !=
t.finite_faces_end(); ++fc) but the CGAL concept / datastructures are still
quite confusing me to me :(
Is CGAL a good tool to create something like that?
What data-structures / methods of CGAL are helpful for that?
Thank you for your help and for CGAL!
George
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Beginner-Delauny-Triangulation-in-Tecplot-Format-tp3403062p3403062.html
- [cgal-discuss] Beginner: Delauny Triangulation in Tecplot-Format, GGeorge, 03/24/2011
- Re: [cgal-discuss] Beginner: Delauny Triangulation in Tecplot-Format, Sebastien Loriot (GeometryFactory), 03/28/2011
