cgal-discuss - [cgal-discuss] Surface_mesher parameters
  • To:
  • Subject: [cgal-discuss] Surface_mesher parameters
  • Date: Mon, 11 Apr 2011 12:57:11 +0200
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=sender:message-id:date:from:user-agent:mime-version:to:subject :content-type:content-transfer-encoding; b=PcgVCQ3OKDAJOs4JJ7l0zY7FFjAJ/YUdl4EbDvz7dCo73Lbatq0xnT+hBWD/3Tz0+Z tO2GWgkMh1n8apR0dDuNmBUgnBiEI9scpUpy0wxEFR1d5s4IWScHTYCRo72AsWNgNVqm pJ/JB345vQiYDaRtpbyJfR4T/z1limEAVDIqw=
Good morning,
I am trying to use the Surface_mesher examples in CGAL 3.7 in order to extract an surface from
a set of images in format raw. I used the CGALIO program to generate a file .inr and i execute the
Surface_mesher but i always obtain only one part of the volume.
Apparently it has to do with the parameters of the sphere that has to enclose the object and the
Surface_mesh_default_criteria_3 trait.
The volume dimentions are 1024 x 1024 x 1024 and the spacing is (1,2,1). The origin is (0,0,0) someone can explain me which are the good parameters for the surface_mesher in this case?
Thanks in advance,
Ricardo
