- To:
- Subject: [cgal-discuss] Re: reading an .obj file and load it into Polyhedron
- Date: Wed, 13 Apr 2011 06:30:53 -0700 (PDT)
hello Laurent Rineau,
yes i saw that, but i want to know if anyone have wrote the reader class to read the .obj
On Wed, Apr 13, 2011 at 3:26 PM, Laurent Rineau (GeometryFactory) [via cgal-discuss] <[hidden email]> wrote:
Le mercredi 13 avril 2011 16:13:53, achakik a écrit :
> hello,
> how can i read the .obj file to put it into Polyhedron, anyone have a code
> of a function that can dot this?
Currently CGAL only has the opposite feature: write a polyhedron to a
Wavefront .obj file.
It should not be very difficult to write a reader class with .obj as input.
Laurent Rineau, PhD
If you reply to this email, your message will be added to the discussion below:http://cgal-discuss.949826.n4.nabble.com/reading-an-obj-file-and-load-it-into-Polyhedron-tp3447123p3447154.html
View this message in context: Re: reading an .obj file and load it into Polyhedron
- [cgal-discuss] reading an .obj file and load it into Polyhedron, achakik, 04/13/2011
- Re: [cgal-discuss] reading an .obj file and load it into Polyhedron, Laurent Rineau (GeometryFactory), 04/13/2011
- [cgal-discuss] Re: reading an .obj file and load it into Polyhedron, achakik, 04/13/2011
- [cgal-discuss] Re: reading an .obj file and load it into Polyhedron, achakik, 04/14/2011
- Re: [cgal-discuss] Re: reading an .obj file and load it into Polyhedron, Francois Berenger, 04/15/2011
- [cgal-discuss] Re: reading an .obj file and load it into Polyhedron, achakik, 04/15/2011
- [cgal-discuss] Re: reading an .obj file and load it into Polyhedron, johnzjq, 04/18/2011
