- To:
- Subject: [cgal-discuss] AABB tree Exact_predicates_exact_constructions_kernel
- Date: Sat, 7 May 2011 23:28:45 -0700 (PDT)
Hello,
I am trying to use an AABB tree with the exact predicates exact
constructions kernel on polyhedrons using the polyhedron triangle primitive.
When I call accelerate_distance_queries(), I get the following error output
from the executable:
terminate called after throwing an instance of 'CGAL::Assertion_exception'
what(): CGAL ERROR: assertion violation!
Expr: i >= 0 && i < dim
File: /home/rcf-proj/jdo/friesz/lib64/include/CGAL/Kd_tree_rectangle.h
Line: 82
Abort
I can get the tree to work with the Cartesian kernel using Gmpq as the field
type and with a filtered Cartesian kernel also using Gmpq. Is there a
reason why the exact kernel fails?
I would like to use the exact kernel because it is much faster at Nef
containment and intersection operations, from what I can tell.
Any help is appreciated.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/AABB-tree-Exact-predicates-exact-constructions-kernel-tp3506553p3506553.html
- [cgal-discuss] AABB tree Exact_predicates_exact_constructions_kernel, schrodingersnewcat, 05/08/2011
- [cgal-discuss] Re: AABB tree Exact_predicates_exact_constructions_kernel, schrodingersnewcat, 05/08/2011
- Re: [cgal-discuss] Re: AABB tree Exact_predicates_exact_constructions_kernel, Sebastien Loriot (GeometryFactory), 05/09/2011
- [cgal-discuss] Re: AABB tree Exact_predicates_exact_constructions_kernel, schrodingersnewcat, 05/11/2011
- Re: [cgal-discuss] Re: AABB tree Exact_predicates_exact_constructions_kernel, Sebastien Loriot (GeometryFactory), 05/12/2011
- Re: [cgal-discuss] Re: AABB tree Exact_predicates_exact_constructions_kernel, Sebastien Loriot (GeometryFactory), 05/13/2011
- [cgal-discuss] Re: AABB tree Exact_predicates_exact_constructions_kernel, schrodingersnewcat, 05/13/2011
