cgal-discuss - Re: [cgal-discuss] how to construct a 2d Triangulation explicitly
  • To:
  • Subject: Re: [cgal-discuss] how to construct a 2d Triangulation explicitly
  • Date: Mon, 23 May 2011 08:29:27 +0200
The infinite vertex is already present in the triangulation even when empty, so you don't need to create it.
S.
魏华祎 wrote:
Hi, everyone,
I have a 2d simple triangulation with four vertices: p1 = (0,0), p2 = (1,0), p3 = (1,1), p4 = ( 0,1), and two triangles: (p2, p3, p1) and (p4,p1,p3). And I want to construct a object of Triangulation_2 class, explicitly ( not write these information into files, then use >> read them). The following is my code. But at last, I got five finite vertices and three finite faces. I am confused, can anyone give me some suggestions about it? Thanks very much!
By the way, I follow the code of the "file_input" member function in Triangulation_data_structure_2.h to write my own code.
#include <CGAL/IO/Color.h>
#include <CGAL/Triangulation_2.h>
#include <CGAL/Triangulation_face_base_2.h>
#include <CGAL/Triangulation_vertex_base_2.h>
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef CGAL::Triangulation_vertex_base_2<K> Vb;
typedef CGAL::Triangulation_face_base_2<K> Fb;
typedef CGAL::Triangulation_data_structure_2<Vb,Fb> Tds;
typedef CGAL::Triangulation_2<K,Tds> Triangulation;
typedef Triangulation::Face_handle Face_handle;
typedef Triangulation::Vertex_handle Vertex_handle;
typedef Triangulation::Point Point;
typedef Triangulation::Finite_vertices_iterator Fvi;
int main(){
int n = 4, m = 2, d = 2;
std::vector<Point> P(4);
P[0] = Point(0,0);
P[1] = Point(1,0);
P[2] = Point(1,1);
P[3] = Point(0,1);
std::vector<Vertex_handle> V(n+1);
std::vector<Face_handle> F(m);
Triangulation tri;
tri.tds().set_dimension(d);
// if I comment the following two lines, there will four finite vertices, but still three faces
V[0] = tri.tds().create_vertex(); tri.set_infinite_vertex(V[0]); // set the infinite vertex of tri
// create the vertex_handles
for(int i = 1; i< 5;i++){
V[i] = tri.tds().create_vertex();
V[i]->set_point(P[i-1]);
//create the first face and set its vertices
F[0] = tri.create_face();
F[0]->set_vertex(0,V[2]);
V[2]->set_face(F[0]);
F[0]->set_vertex(1,V[3]);
V[3]->set_face(F[0]);
F[0]->set_vertex(2,V[1]);
V[1]->set_face(F[0]);
// create the second face and set its vertices
F[1] = tri.create_face();
F[1]->set_vertex(0,V[4]);
V[4]->set_face(F[1]);
F[1]->set_vertex(1,V[1]);
V[1]->set_face(F[1]);
F[1]->set_vertex(2,V[3]);
V[3]->set_face(F[1]);
// set neighbor information
F[0]->set_neighbor(0,F[1]);
F[1]->set_neighbor(0,F[0]);
std::cout<<tri.number_of_vertices()<<std::endl<<tri.number_of_faces()<<std::endl;
return 0;
