- To:
- Subject: [cgal-discuss] Bug in AABB tree implementation
- Date: Fri, 27 May 2011 10:05:41 -0700 (PDT)
Hi all,
I've recently stumbled upon a bug in CGAL's implementation of AABB trees.
The bug occurs when you construct an AABB tree using a single primitive as
input (I used triangles); it seems that there's a common assumption that
there would be at least two primitives, and this is reflected in the
following two places:
- AABB_tree.h:499 - if there's only one primitive, a 0-length block of
memory is allocated for the tree
- AABB_tree_node.h:133 - if there's only one primitive the recursion is
incorrect since the switch handles the cases for two, three and more
primitives
The latter bug (or their combination) causes a segmentation fault (or some
other colorful panic) on my machine.
I'm running Kubuntu 11.04 (Natty) in VM over Windows 7; CGAL was installed
via the package manager and there was no special configuration that needed
to be done. I'm using the latest Eclipse for editing but compile using the
CMake-generated Makefile.
Attached you'll find some simple code example that recreates the bug:
http://cgal-discuss.949826.n4.nabble.com/file/n3555851/bug.h bug.h
Cheers,
Alexei
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Bug-in-AABB-tree-implementation-tp3555851p3555851.html
- [cgal-discuss] Bug in AABB tree implementation, alexei, 05/27/2011
- Re: [cgal-discuss] Bug in AABB tree implementation, Sebastien Loriot (GeometryFactory), 05/30/2011
