- To:
- Subject: Re: [cgal-discuss] un-triangulating a polyhedron
- Date: Wed, 01 Jun 2011 08:47:08 +0200
Max Harris wrote:
CGAL::convex_hull_3 is very nice, but the resulting polyhedron is
triangulated (which it has to be, because the polyhedron is calculated by the
quickhull algorithm), which is bad for my application.
How should I go about removing the unnecessary edges? Or to put it another
way, how do I go about combining all of the coplanar triangular faces into
new faces? Is there a built-in way to do this, or an example?
Unfortunately, there is no built-in way to do it, you need to play with
the functions:
join_facet
join_vertex
erase_center_vertex
all documented here:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Polyhedron_ref/Class_Polyhedron_3.html
and with the coplanar and collinear functions:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Kernel_23_ref/Function_coplanar.htm
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Kernel_23_ref/Function_collinear.html
S.
- Re: [cgal-discuss] un-triangulating a polyhedron, Sebastien Loriot (GeometryFactory), 06/01/2011
