- To:
- Subject: [cgal-discuss] Installing CGAL windows 64 bits
- Date: Fri, 03 Jun 2011 14:45:14 +0100
Dear all, I'm trying to install the CGAL 3.8 (64 bits) on windows 7 (64bits) with the MS Visual C++ 2010 Express following the instructions given in http://acg.cs.tau.ac.il/cgal-at-tau/installing-cgal-and-related-programs-on-windows The cmake of the CGAL (step 5) gives-me two warnings (see below). It is normal or should I fix this problem? In fact if I don't fix this problem I can't pass the sanity check (step 6). Thanks for your help. Gil -> first warning CMake Warning (dev) at C:/Program Files (x86)/CMake 2.8/share/cmake-2.8/Modules/FindPackageHandleStandardArgs.cmake:85 (INCLUDE): File C:/Program Files (x86)/CMake 2.8/share/cmake-2.8/Modules/FindPackageHandleStandardArgs.cmake includes C:/Program Files (x86)/CGAL-3.8/cmake/modules/FindPackageMessage.cmake (found via CMAKE_MODULE_PATH) which shadows C:/Program Files (x86)/CMake 2.8/share/cmake-2.8/Modules/FindPackageMessage.cmake. This may cause errors later on . Policy CMP0017 is not set: Prefer files from the CMake module directory when including from there. Run "cmake --help-policy CMP0017" for policy details. Use the cmake_policy command to set the policy and suppress this warning. Call Stack (most recent call first): C:/Program Files (x86)/CMake 2.8/share/cmake-2.8/Modules/FindZLIB.cmake:69 (INCLUDE) src/CGALimageIO/CMakeLists.txt:16 (find_package) This warning is for project developers. Use -Wno-dev to suppress it. -> second warning CMake Warning (dev) at C:/Program Files (x86)/CMake 2.8/share/cmake-2.8/Modules/FindQt4.cmake:1088 (INCLUDE): File C:/Program Files (x86)/CMake 2.8/share/cmake-2.8/Modules/FindQt4.cmake includes C:/Program Files (x86)/CGAL-3.8/cmake/modules/FindPackageMessage.cmake (found via CMAKE_MODULE_PATH) which shadows C:/Program Files (x86)/CMake 2.8/share/cmake-2.8/Modules/FindPackageMessage.cmake. This may cause errors later on . Policy CMP0017 is not set: Prefer files from the CMake module directory when including from there. Run "cmake --help-policy CMP0017" for policy details. Use the cmake_policy command to set the policy and suppress this warning. Call Stack (most recent call first): src/CGALQt4/CMakeLists.txt:18 (find_package) This warning is for project developers. Use -Wno-dev to suppress it. Is |
- [cgal-discuss] Installing CGAL windows 64 bits, Gil, 06/03/2011
- Re: [cgal-discuss] Installing CGAL windows 64 bits, Laurent Rineau (GeometryFactory), 06/03/2011
- Re: [cgal-discuss] Installing CGAL windows 64 bits, Gil, 06/03/2011
