Re: [cgal-discuss] Constructing a terrain with a constrained Delaunay triangulation
- To:
- Subject: Re: [cgal-discuss] Constructing a terrain with a constrained Delaunay triangulation
- Date: Wed, 08 Jun 2011 16:34:29 +0200
Costas Tsirogiannis wrote:
Greetings,
i am trying to make terrain triangulation which is also a constrained Delaunay triangulation. The instantiation that I try is:
typedef typename CGAL::Triangulation_vertex_base_2<Kernel> Vertex_base;
typedef typename CGAL::Constrained_triangulation_face_base_2<Kernel> Face_base;
typedef typename CGAL::Triangulation_data_structure_2<Vertex_base,Face_base> Triangulation_structure;
typedef typename CGAL::Triangulation_euclidean_traits_xy_3< Kernel > Triangulation_traits;
typedef typename CGAL::Exact_predicates_tag Exact_tag;
typedef typename CGAL::Constrained_Delaunay_triangulation_2<Triangulation_traits, Triangulation_structure, Exact_tag> Triangulation;
but I get lots of compilation errors, instead if I try a simple Delaunay triangulation everything looks ok.
Any ideas on what I'm doing wrong?
thanks,
Constantinos
First CGAL::Triangulation_euclidean_traits_xy_3 is deprecated,
you should use Projection_traits_xy_3 instead.
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Kernel_23_ref/Class_Projection_traits_xy_3.htm
Then replace K by Triangulation_traits in vertex and face instantiation
and that should work.
Sebastien.
- [cgal-discuss] Constructing a terrain with a constrained Delaunay triangulation, Costas Tsirogiannis, 06/08/2011
- Re: [cgal-discuss] Constructing a terrain with a constrained Delaunay triangulation, Sebastien Loriot (GeometryFactory), 06/08/2011
- Re: [cgal-discuss] Constructing a terrain with a constrained Delaunay triangulation, Costas Tsirogiannis, 06/08/2011
