- To:
- Subject: Re: [cgal-discuss] Create_skeleton_and_offset_polygons_with_holes_2 bug
- Date: Wed, 08 Jun 2011 18:12:23 +0200
I personally don't know what this file was intended to be used for.
Anyway the outer boundary is not correctly oriented for this
application. If you add:
outer.reverse_orientation();
Then it will work as expected.
Sebastien.
CGALFan wrote:
Hello!
Does the Create_skeleton_and_offset_polygons_with_holes_2 example run with
sample_4.dat? I tested it now with two different installations (with Windows
and Ubuntu). Can someone test that for me?
The error is:
CGAL error: assertion violation!
EXpression: lParent
File: ... /CGAL/arrange_offset_polygon_2.h
Line: 93
Explanation:
Refer to the bug-reporting instructions at ...
Best regards
Gernot
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Create-skeleton-and-offset-polygons-with-holes-2-bug-tp3579320p3579320.html
- [cgal-discuss] Create_skeleton_and_offset_polygons_with_holes_2 bug, CGALFan, 06/07/2011
- Re: [cgal-discuss] Create_skeleton_and_offset_polygons_with_holes_2 bug, Sebastien Loriot (GeometryFactory), 06/08/2011
- Re: [cgal-discuss] Create_skeleton_and_offset_polygons_with_holes_2 bug, Gernot H. Gutschi, 06/08/2011
