- To:
- Subject: [cgal-discuss] Re: Input a 3-D polyline from a list of points.
- Date: Thu, 9 Jun 2011 08:23:36 -0700 (PDT)
Thank you very much, this is a big help!
now all I have to do is add 'polylines' as a feature for the mesh generator.
thx,
todd
On Thu, Jun 9, 2011 at 2:56 AM, Sebastien Loriot (GeometryFactory) [via cgal-discuss] <[hidden email]> wrote:
I am not sure to get you problem. Are you talking about importing
polylines from a file?
The following code reads polylines given as:
n x1 y1 z1 x2 y2 z2 ...... xn yn zn
std::list<std::vector<Point_3> > polylines;
std::ifstream ifs(filename);
std::size_t n;
while(ifs >> n) {
polylines.resize(polylines.size()+1);
std::vector<Point_3>& polyline = polylines.back();
while(n--){
Point_3 p;
ifs >> p;
polyline.push_back(p);
Sebastien.
toddoe wrote:> Sent from the cgal-discuss mailing list archive at Nabble.com.
> Hi All,
> sorry if this is a 'noob' question, but i'm relatively new to C++ and I'm
> having trouble figuring out how to import a 3-D points list and generate a
> 'curve'. Basically, what I want to do is import/add a polyline as a
> 'feature' for the 3-D mesh generator. I can see from the examples that i
> need to use:
> // Polyline
> typedef std::vector<Point> Polyline;
> typedef std::list<Polyline> Polylines;
> Polylines polylines (1);
> Polyline& polyline = polylines.front();
> and then add the points in order as in the example (the two spheres example
> in the manual), but i can't quite figure out how to import the points and
> create the polyline, especially since ulitmately i will have multiple
> polylines (features) that I will need to preserve in the 3D mesh...
> I hope this is enough info for someone to help, or hopefully provide a piece
> of example code. I'm sure this is a really simple thing for some of you
> expert out there. I did search the forums and manual carefully on this topic
> but didn't find anything related.
> Thanks in advance,
> todd
> View this message in context: http://cgal-discuss.949826.n4.nabble.com/Input-a-3-D-polyline-from-a-list-of-points-tp3583317p3583317.html
If you reply to this email, your message will be added to the discussion below:http://cgal-discuss.949826.n4.nabble.com/Input-a-3-D-polyline-from-a-list-of-points-tp3583317p3584697.htmlTo unsubscribe from Input a 3-D polyline from a list of points., click here.
View this message in context: Re: Input a 3-D polyline from a list of points.
- [cgal-discuss] Input a 3-D polyline from a list of points., toddoe, 06/08/2011
- Re: [cgal-discuss] Input a 3-D polyline from a list of points., Sebastien Loriot (GeometryFactory), 06/09/2011
- Re: [cgal-discuss] Input a 3-D polyline from a list of points., t.doehring, 06/09/2011
- [cgal-discuss] Re: Input a 3-D polyline from a list of points., toddoe, 06/09/2011
