cgal-discuss - Re: [cgal-discuss] .mesh to vtk output
  • To:
  • Subject: Re: [cgal-discuss] .mesh to vtk output
  • Date: Fri, 10 Jun 2011 10:56:52 -0400
Hi again,
Sorry, I didn't read your mail correctly. I'll give your solution a
try and report back.
// Output
CGAL::output_c3t3_to_vtk_unstructured_grid(c3t3, output);
output->Squeeze();
Best wishes,
Michel
On Fri, Jun 10, 2011 at 10:36 AM, Michel Audette
wrote:
> Hi Laurent,
> ah, my mistake. Yes, to an extent, I'm using VTK-based software, but
> some of it is not yet in the VTK code itself. I'm working with
> Sebastien Valette to refine his ACVD code and apply it to my project.
> I'll try to track down a conversion from .mesh to .vtk then. I think
> that there may one out there somewhere.
> We can revisit what you are doing in the near future, perhaps in July.
> Cheers,
> Michel
> On Fri, Jun 10, 2011 at 6:09 AM, Laurent Rineau (GeometryFactory)
> wrote:
>> On vendredi 10 juin 2011 00:51:41 Michel Audette wrote:
>>> Dear CGAL deveopers,
>>> I did a search on vtk in the 3.8 source code, and found
>>> Complex_3_in_triangulation_3_to_vtk , which sounds like what I need. I
>>> would like to be able to visualize the CGAL tetrahedralization results
>>> with Paraview.
>>> Is there an example or demo somewhere that documents how to use this
>>> class?
>> No. That is undocumented. I wrote this function with the purpose to write a
>> VTK filter that does 3D meshing of 3D images (is not it what you are
>> doing)?
>> The usage is simple :
>>  // given a C3t3 variable 'c3t3',
>>  // given vtkUnstructuredGrid* pointer output
>>  //   (that points to a valid empty grid)
>>  output->Squeeze(); // I do not remember why I used Squeeze().
>> As attachment I give you my non-finished attempt to write the VTK filter. I
>> image you can read VTK code easily. It is not finished because:
>>  - it does not use the ability of CGAL-3.8 to preserve sharp edges
>>  - I do not know what is the common way to pass parameters (such as size
>> criteria) to a VTK filter.
>> And I have not sure that still works. I started that more than a year ago,
>> and
>> then I got other more priority tasks to do and I forgot that VTK filter.
>> Maybe we could collaborate and finish that together.
>> Laurent Rineau, PhD
>> R&D Engineer at GeometryFactory           http://www.geometryfactory.com/
>> Release Manager of the CGAL Project       http://www.cgal.org/
>> You are currently subscribed to cgal-discuss.
>> To unsubscribe or access the archives, go to
>> https://lists-sop.inria.fr/wws/info/cgal-discuss
> Michel Audette, Ph.D.
> R & D Engineer,
> Kitware Inc.,
> Chapel Hill, N.C.
R & D Engineer,
Kitware Inc.,
Chapel Hill, N.C.
