- To:
- Subject: Re: [cgal-discuss] construct polygon using vertices and edges as input
- Date: Wed, 15 Jun 2011 15:43:49 +0900
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type:content-transfer-encoding; b=QBvGIY4/rFQblJXNneAIdT95M7Nmi1SaxUMjF+GY/v3n1zHNknP7W1fmejDTUNWYwe 91zWAfxgSGJQnBn6HWvCOZffp8wI9UFarfsymBb2vrvNgzFjLVpENc+BGOPJL8Of6fQV Vc8okqy5o/U5DkeCauFT+4FPblK8+eh06s+eo=
Dear Loriot,
Thank you very much for your answer.
I will read the related documents of the two methods you have provided.
After that, maybe I still need your help again. ^_^
Thanks again.
Best regards,
Chongke
On Wed, Jun 15, 2011 at 3:29 PM, Sebastien Loriot (GeometryFactory)
wrote:
> The answer depends on what you want to do with your polygon.
> Using CGAL::Polygon will not work because your polygon has
> a tail made of two segments.
> You can use halfedge data structure to get a representation of it,
> or even the arrangement package (using the insert functions
> insert_from_left_vertex, insert_from_right_vertex and insert_at_vertices) if
> you then need to do location queries.
> See related documentation pages:
> HDS:
> http://www.cgal.org/Manual/latest/doc_html/cgal_manual/HalfedgeDS/Chapter_main.html
> Arrangement:
> http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Arrangement_on_surface_2/Chapter_main.html
> http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Arrangement_on_surface_2_ref/Class_Arrangement_2.html
> Sebastien.
> Chongke Bi wrote:
>> Dear all,
>> I will explain my question using a simple example.
>> The input of my question is as followings:
>> - 8 Vertices :
>> (index of vertices)
>> -0.500000 -0.500000 0.00000 (0)
>> 0.500000 -0.500000 0.00000 (1)
>> 1.500000 -1.5000000 0.00000 (2)
>> 2.500000 -0.5000000 0.00000 (3)
>> 2.500000 0.500000 0.00000 (4)
>> 1.500000 1.500000 0.00000 (5)
>> 0.500000 0.500000 0.00000 (6)
>> -0.500000 0.500000 0.00000 (7)
>> - 9 Edges : 01 (01 represents an edge with vertices 0 and 1)
>> 12
>> 23
>> 34
>> 45
>> 56
>> 61
>> 67
>> 70
>> The output that I want to get is
>> - to construct a polygon by using these vertices and edges
>> or - to get the information of the corresponding surfaces
>> surface-1 : 0167
>> surface-2 : 123456
>> Are there any functions or methods to solve this problem.
>> Thanks.
>> Best regards,
>> Chongke
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
Chongke
BI<>
- [cgal-discuss] construct polygon using vertices and edges as input, Chongke Bi, 06/15/2011
- Re: [cgal-discuss] construct polygon using vertices and edges as input, zeinab hasani, 06/15/2011
- Re: [cgal-discuss] construct polygon using vertices and edges as input, Sebastien Loriot (GeometryFactory), 06/15/2011
- Re: [cgal-discuss] construct polygon using vertices and edges as input, Chongke Bi, 06/15/2011
