- To: "" <>
- Cc: Gärtner Bernd <>
- Subject: AW: [cgal-discuss] Quadratic program initial values
- Date: Thu, 23 Jun 2011 06:50:34 +0000
- Accept-language: de-CH, en-US
No, there is no such way. But I'm thinking about adding it. It's hard to add
it yourself, since the code is pretty intricate. Also, if D is not positive
semidefinite, the solver is not guaranteed to even find a local minimum. It
might as well crash in such a case.
Best,
Bernd.
________________________________________
Von: Fernanda Andaló
Gesendet: Donnerstag, 23. Juni 2011 04:06
Bis:
Betreff: [cgal-discuss] Quadratic program initial values
Hello,
Is there a way to set the initial value of the variables when constructing a
quadratic program?
If not, can you please show me where I can change that in CGAL source code?
My matrix D is not positive-semidefinite, so I may need to restart the
optimization with different starting points to find the global minimum.
Thank you,
Fernanda
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Quadratic-program-initial-values-tp3618763p3618763.html
- [cgal-discuss] Quadratic program initial values, Fernanda Andaló, 06/23/2011
- AW: [cgal-discuss] Quadratic program initial values, Gärtner Bernd, 06/23/2011
