cgal-discuss - Re: [cgal-discuss] Re: how to find closest point on a segment/rectangle to a given point
  • To: <>, Bernd Gaertner <>
  • Subject: Re: [cgal-discuss] Re: how to find closest point on a segment/rectangle to a given point
  • Date: Thu, 23 Jun 2011 10:32:40 +0200
You can also use the Quadratic programming solver whenever you need to compute the minimum squared distance between two objects, each of which can be described by linear equations and inequalities (lines, segments, boxes, points,...):
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/QP_solver/Chapter_main.html
Best,
Bernd.
Sebastien Loriot (GeometryFactory) wrote:
Take a kernel with exact constructions (like CGAL::Exact_predicates_exact_constructions_kernel).
Construct you lines with this kernel.
compute the vector orthogonal to those two lines (using cross_product
on their director vectors)
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Kernel_23_ref/Function_cross_product.html
Assume the vector is not 0 and take any a point on Line_1
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Kernel_23_ref/Class_Line_3.html
and construct the plane containing this line and having the computed
vector as orthogonal vector.
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Kernel_23_ref/Class_Plane_3.html
Take two points on Line_2 and project then on the plane. Construct the
line passing through the projected points and intersect it with Line_1
to get the first point.
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Kernel_23_ref/Function_intersection.html
To get the second point construct the line containing the first point
with direction the computed vector. Intersect this line with Line_2 and
you will get the second point.
I agree that a closest_point method would be nice to have in CGAL.
Sebastien.
updog wrote:
I just find CGAL::squared_distance() would be useful.
However, is there a way to get the locations of the very pair of points
achieving the minimal squared distance?
View this message in context: http://cgal-discuss.949826.n4.nabble.com/how-to-find-closest-point-on-a-segment-rectangle-to-a-given-point-tp3618761p3618911.html
