cgal-discuss - [cgal-discuss] Failing double intersection with AABB Tree
  • To:
  • Subject: [cgal-discuss] Failing double intersection with AABB Tree
  • Date: Thu, 23 Jun 2011 19:56:33 +0200
  • Importance: Normal
Hi,
I cannot reproduce the behaviour you suggested:
<Suppose that the line does not intersect the opposite facets on an edge.
<Given a vertex, they are two cases:
<1) if the vertex v is not incident to the infinite vertex:
<the set of finite cells incident to v is a topological ball with
<the point of v in the interior the ball. So in that case you must
<intersect exactly two facets opposite to v.
<2) if the vertex v is incident to the infinite vertex:
<then the set of finite cells incident to v is a topological ball with
<the point of v on the boundary of that ball. Due to the convexity of
<any small neighborhood of v, the number of intersected facets opposite
<to v ranges from 0 to 1 (it depends on the direction).
<S.
I have some single intersections even though the vertex is not incident to
the infinite vertex. (The result doesn't change using a Facet_iterator
instead of a Finite_facet_iterator for Id and testing
c3t3.is_in_complex(cell) or considering only cells incident to the
vertex). The case 2 works fine.
Thank you for your attention.
#include <CGAL/Mesh_triangulation_3.h>
#include <CGAL/Mesh_complex_3_in_triangulation_3.h>
#include <CGAL/Mesh_criteria_3.h>
#include <CGAL/Implicit_mesh_domain_3.h>
#include <CGAL/make_mesh_3.h>
#include <CGAL/AABB_tree.h>
#include <CGAL/AABB_traits.h>
#include <list>
#include <CGAL/iterator.h>
#include <iostream>
#include <fstream>
#include <map>
#include <vector>
#include <string>
#include <utility>
#include <cassert>
template <class Tr>
class AABB_triangulation_triangle_primitive
public:
// types
typedef typename Tr::Finite_facets_iterator Id; // Id type
typedef typename Tr::Geom_traits GeomTraits;
typedef typename GeomTraits::Point_3 Point; // point type
typedef typename GeomTraits::Triangle_3 Datum; // datum type
private:
// member data
Id m_it; // iterator
Datum m_datum; // 3D triangle
public:
AABB_triangulation_triangle_primitive() {}
AABB_triangulation_triangle_primitive(Id it)
: m_it(it)
, m_datum(it->first->vertex((it->second+1)&3)->point(),
it->first->vertex((it->second+2)&3)->point(),
it->first->vertex((it->second+3)&3)->point()){}
public:
Id& id() { return m_it; }
const Id& id() const { return m_it; }
Datum& datum() { return m_datum; }
const Datum& datum() const { return m_datum; }
/// Returns a point on the primitive
Point reference_point() const { return m_datum.vertex(0); }
// Domain
struct K: public CGAL::Exact_predicates_inexact_constructions_kernel {};
typedef K::FT FT;
typedef K::Point_3 Point;
typedef FT (Function)(const Point&);
typedef CGAL::Implicit_mesh_domain_3<Function,K> Mesh_domain;
// Triangulation/domain
typedef CGAL::Mesh_triangulation_3<Mesh_domain>::type Tr;
typedef CGAL::Mesh_complex_3_in_triangulation_3<Tr> C3t3;
// Criteria
typedef CGAL::Mesh_criteria_3<Tr> Mesh_criteria;
// Triangulation
typedef C3t3::Triangulation Tr;
typedef C3t3::Cell_handle Cell_handle;
typedef Tr::Finite_vertices_iterator Finite_vertices_iterator;
typedef Tr::Vertex_handle Vertex_handle;
//Geometric objects
typedef K::Ray_3 Ray;
typedef K::Line_3 Line;
typedef K::Direction_3 Direction;
typedef K::Segment_3 Segment;
//AABB Tree
typedef AABB_triangulation_triangle_primitive<Tr> Primitive;
typedef CGAL::AABB_traits<K,Primitive> Traits;
typedef CGAL::AABB_tree<Traits> Tree;
typedef Tree::Object_and_primitive_id Object_and_primitive_id;
typedef Tree::Primitive_id Id;
//typedef Tr::Finite_facets_iterator Id;
typedef K::Triangle_3 Datum;
// To avoid verbose function and named parameters call
using namespace CGAL::parameters;
// Function
FT sphere_function (const Point& p)
{ return CGAL::squared_distance(p, Point(CGAL::ORIGIN))-1; }
int main()
// Domain
Mesh_domain domain(sphere_function, K::Sphere_3(CGAL::ORIGIN, 2.));
// Criteria
Mesh_criteria criteria(facet_angle=30, facet_size=0.3,
facet_distance=0.15,
cell_radius_edge=2, cell_size=0.3);
// Mesh generation
//C3t3 c3t3 = CGAL::make_mesh_3<C3t3>(domain, criteria);
// Mesh generation and optimization
C3t3 c3t3 = CGAL::make_mesh_3<C3t3>(domain, criteria,
lloyd(time_limit=30),
no_perturb(),
exude(time_limit=30, sliver_bound=10));
// Output
std::ofstream medit_file("out.mesh");
c3t3.output_to_medit(medit_file);
Tree
tree(c3t3.triangulation().finite_facets_begin(),c3t3.triangulation().finite_facets_end());
Point a(0.3, 0.8, 0.1);
Point b(0.4, 0.5, 0.7);
Ray ray_query(a,b);
Direction dir(ray_query);
for(Finite_vertices_iterator vit
=c3t3.triangulation().finite_vertices_begin();
vit != c3t3.triangulation().finite_vertices_end();
++vit)
Point vertexpoint = vit->point();
Line line_vertex(vertexpoint,dir);
std::cout <<
tree.number_of_intersected_primitives(line_vertex) <<
"INTERSECTED PRIMITIVES"<<std::endl;
// compute and store all intersections with line query
std::list<Object_and_primitive_id> intersections;
tree.all_intersections(line_vertex,
std::back_inserter(intersections));
std::list<Object_and_primitive_id>::iterator
it_intersections=intersections.begin();
std::list<std::pair<Point,Id> > myvector;
std::list<std::pair<Point,Id> >::iterator it;
for(; it_intersections != intersections.end() ;
it_intersections++) {
// get intersection object
Object_and_primitive_id op = *it_intersections;
CGAL::Object object = op.first;
Id id=op.second;
Point point;
Segment segment;
if(CGAL::assign(point,object))
myvector.push_back(make_pair(point,id));
else if(CGAL::assign(segment,object))
std::cout << "intersection object is a
segment" <<std::endl;
//convex hull
std::list<Vertex_handle> verticeschull;
std::list<Vertex_handle>::iterator it_inf;
c3t3.triangulation().incident_vertices(c3t3.triangulation().infinite_vertex(),
std::back_inserter(verticeschull));
bool infinitevert = false;
for ( it_inf=verticeschull.begin() ; it_inf !=
verticeschull.end();
it_inf++ ){
if (vertexpoint == (*it_inf)->point())
infinitevert= true;
int ipr=1;
for ( it=myvector.begin() ; it != myvector.end(); it++ ){
Cell_handle cell = (*((*it).second)).first;
int opposite_vertex_index =(*it).second->second;
Point
vertexoppositepoint=(cell->vertex(opposite_vertex_index)->point());
if((vertexpoint ==
vertexoppositepoint)&&(infinitevert == true)) {
std::cout<<" "<<"squared distance"<<"
"<<CGAL::squared_distance(vertexpoint,Point(CGAL::ORIGIN))<<"
"<<"current vertex"<<" "<< vertexpoint<<" "<<"on BOUNDARY"<<std::endl;
//if(c3t3.is_in_complex(cell)==true) {
std::cout << ipr++<<"th
intersection/coordinates"<<"
"<<std::setprecision(15)<<(*it).first << " => " << std::endl;
for(int i = 0; i < 4; i++){
const Vertex_handle& vh
=cell->vertex(i);
std::cout <<"tetrahedron
vertex coordinates:"<<"
"<<vh->point().x()<<" "<<vh->point().y()<<" "<<vh->point().z()<<"
"<<CGAL::squared_distance((vh->point()),Point(CGAL::ORIGIN))<<std::endl;
else if((vertexpoint ==
vertexoppositepoint)&&(infinitevert == false))
std::cout<<"current vertex"<< " "<<
vertexpoint<<" "<<" inside the
VOLUME"<<" "<<std::endl;
std::cout<<"squared distance"<<"
"<<CGAL::squared_distance(vertexpoint,Point(CGAL::ORIGIN))<<std::endl;
=cell->vertex(i);
std::cout <<"tetrahedron vertex
coordinates:"<<"
return 0;
