- To:
- Subject: [cgal-discuss] Cannot open include file: 'qpopupmenu.h'
- Date: Fri, 24 Jun 2011 15:10:58 +0800
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:date:message-id:subject:from:to:content-type; b=vt5iYh1oo6b9Q5TU8QbJCZVO94dSXSXYnTEavPNS6MSN+t/zUgfYWfaAQRazmh4G4j XXaGnboRjNAUR2i5PuTgzy7EtAN2onFJdgbuHCMmCN0JkJ1jGcU8UxQMPqzvcqvQQhS1 BKgPxBxhl+nJdKJ7NWKBlAnZwo6a4bSTGG6tk=
Hi all,
With CGAL 3.8 and QT 4.7.3 on Visual Studio 2008, I tested this minimal code:
#include <CGAL/IO/Qt_widget_Nef_3.h>
int main(int argc, char* argv[])
return 0;
which is basically a stripped off version of the last code in
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Nef_3/Chapter_main.html
and this is the output:
1>------ Build started: Project: CGALTest, Configuration: Release Win32 ------
1>Compiling...
1>main.cpp
1>WARNING: Inclusion of header files from include/Qt is deprecated.
1>D:\nixx\Project\Testbed\dependencies\CGAL-3.8\include\CGAL/IO/Qt_widget_OpenGL.h(33)
: fatal error C1083: Cannot open include file: 'qpopupmenu.h': No such
file or directory
1>Build Time 0:05
1>Build log was saved at
"file://d:\nixx\Project\CGALTest\Release\BuildLog.htm"
1>CGALTest - 1 error(s), 0 warning(s)
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
Indeed, there was no qpopupmenu.h in Qt directory. I searched on
Qt-related forums, and found here
http://doc.trolltech.com/4.7/porting4.html#qpopupmenu
that "For most purposes, QPopupMenu has been replaced by QMenu in Qt
4. For compatibility with older applications, Q3PopupMenu provides the
old API and features that are specific to pop-up menus. Note that,
when using Q3PopupMenu, the menu's actions must be Q3Actions."
So:
1) I am wondering whether this is obsolete and will be replaced in the
next release? Or is it simply my mistake?
2) I suppose to correct this I have to edit Qt_widget_OpenGL.h and
rebuild the whole CGAL again. Is there a simple workaround for this
problem without doing this?
Thank you.
Best regards,
Nicholas
- [cgal-discuss] Cannot open include file: 'qpopupmenu.h', Nicholas Mario Wardhana, 06/24/2011
- Re: [cgal-discuss] Cannot open include file: 'qpopupmenu.h', Sebastien Loriot (GeometryFactory), 06/27/2011
- Re: [cgal-discuss] Cannot open include file: 'qpopupmenu.h', Nicholas Mario Wardhana, 06/27/2011
