cgal-discuss - Re: [cgal-discuss] Kernel
  • To:
  • Subject: Re: [cgal-discuss] Kernel
  • Date: Fri, 24 Jun 2011 15:18:10 +0200
wrote:
Hi,
thank you for your reply!
<In your code, I would say that the intersection does not show up
<because the intersection is computed using a kernel with inexact
<constructions.
The kernel choice was one of my guesses. I had found a segmentation fault
using a CGAL::Simple_cartesian<double> (as in AABB examples) and a lot of
errors in make_mesh/refine_mesh when choosing a
CGAL::Exact_predicates_exact_constructions_kernel (or
Exact_predicates_exact_constructions_kernel_with_sqrt).
Thanks again
You need a kernel with exact constructions only for computing the intersection points.
You probably need to use CGAL::Cartesian_converter
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Kernel_23_ref/Class_Cartesian_converter.html
Sebastien.
  • [cgal-discuss] Kernel, cecilia, 06/24/2011
    • Re: [cgal-discuss] Kernel, Sebastien Loriot (GeometryFactory), 06/24/2011
