cgal-discuss - Re: [cgal-discuss] Re: intersection of 2 Nef_Polyhedron
  • To:
  • Subject: Re: [cgal-discuss] Re: intersection of 2 Nef_Polyhedron
  • Date: Thu, 30 Jun 2011 19:11:06 +0200
thierry Fernandez wrote:
I compile in release mode.
Yes I use OFF_to_nef_3.
As I said OFF_to_nef_3 is slower.
First construct a polyhedron (if your input is a 2-manifold) and then
build nef from the polyhedron.
For which application are you using nef?
Sebastien.
2011/6/30 Sebastien Loriot (GeometryFactory) <sloriot.ml <http://sloriot.ml>@gmail.com <http://gmail.com>>
tfern90 wrote:
it's a bit faster, but still too: 1 second
View this message in context:
http://cgal-discuss.949826.n4.__nabble.com/intersection-of-2-__Nef-Polyhedron-__tp3635879p3636030.html
<http://cgal-discuss.949826.n4.nabble.com/intersection-of-2-Nef-Polyhedron-tp3635879p3636030.html>
Try upgrading your computer.
Did you compile with optimizations and release mode?
how do you import your model as a nef polyhedron? using the
constructor from polyhedron or OFF_to_nef_3 (the former being faster)?
Sebastien.
-- You are currently subscribed to cgal-discuss.
https://lists-sop.inria.fr/__wws/info/cgal-discuss
<https://lists-sop.inria.fr/wws/info/cgal-discuss>
