cgal-discuss - [cgal-discuss] Re: intersection of 2 Nef_Polyhedron
  • To:
  • Subject: [cgal-discuss] Re: intersection of 2 Nef_Polyhedron
  • Date: Thu, 30 Jun 2011 23:20:09 -0700 (PDT)
I originally built the polyhedron with a off  file and an ifstream object.
After converted to Nef.
 I did not have good results
I'll try again.
I work at Orange labs and we calculate the intersections between buildings and optical beams.
2011/6/30 Sebastien Loriot (GeometryFactory) [via cgal-discuss] <[hidden email]>
thierry Fernandez wrote:
> I compile in release mode.
> Yes I use OFF_to_nef_3.
As I said OFF_to_nef_3 is slower.
First construct a polyhedron (if your input is a 2-manifold) and then
build nef from the polyhedron.
For which application are you using nef?
Sebastien.
> 2011/6/30 Sebastien Loriot (GeometryFactory) <sloriot.ml
> <http://sloriot.ml>@gmail.com <http://gmail.com>>
>     tfern90 wrote:
>         it's a bit faster, but still too: 1 second
>         View this message in context:
>         http://cgal-discuss.949826.n4.__nabble.com/intersection-of-2-__Nef-Polyhedron-__tp3635879p3636030.html
>         <http://cgal-discuss.949826.n4.nabble.com/intersection-of-2-Nef-Polyhedron-tp3635879p3636030.html>
>         Sent from the cgal-discuss mailing list archive at Nabble.com.
>     Try upgrading your computer.
>     Did you compile with optimizations and release mode?
>     how do you import your model as a nef polyhedron? using the
>     constructor from polyhedron or OFF_to_nef_3 (the former being faster)?
>     Sebastien.
>     You are currently subscribed to cgal-discuss.
>     To unsubscribe or access the archives, go to
>     https://lists-sop.inria.fr/__wws/info/cgal-discuss
>     <https://lists-sop.inria.fr/wws/info/cgal-discuss>
If you reply to this email, your message will be added to the discussion below:
http://cgal-discuss.949826.n4.nabble.com/intersection-of-2-Nef-Polyhedron-tp3635879p3636312.html
To unsubscribe from intersection of 2 Nef_Polyhedron, click here.
View this message in context: Re: intersection of 2 Nef_Polyhedron
  • [cgal-discuss] Re: intersection of 2 Nef_Polyhedron, tfern90, 07/01/2011
