cgal-discuss - Re: [cgal-discuss] Dual of an Arrangement_with_history_2
  • To:
  • Subject: Re: [cgal-discuss] Dual of an Arrangement_with_history_2
  • Date: Fri, 1 Jul 2011 10:26:12 +0300
Sorry if you get this twice, wasn't sure that it was sent.
Hi Jan,
You have found several problems in the Arrangement package (at least two issues).
In the meantime (as a workaround), please include the following header when you trying to use BGL adaptation on arrangement with history.
I am assuming that you use version 3.8 or 3.7 (maybe it will work for 3.6).
Thanks,
Ophir
On Thu, Jun 30, 2011 at 7:01 PM, Kämper <> wrote:
Hello!
I would like to get the dual of an arrangement which is of type Arrangement_with_history_2.
So I try to declare and initalize a variable of type CGAL::Dual<Arrangement_with_history_2>
like this
"Dual_arrangement_2 dual (arr);"
(I defined typedef CGAL::Dual<Arrangement_with_history_2>    Dual_arrangement_2)
That gives me the following error:
"error: variable ‘Dual_arrangement_2 dual’ has initializer but incomplete type"
I also modified the example from the cgal manual to work with a Arrangement_with_history_2
and that also gave me the same incomplete type error.
So I assume that Duals cannot be created for Arrangement_with_histories or that there is something that needs
to be adapted to this purpose, right?
This wouldn't really make sense since one should be able to obtain the dual from for this extended type of Arrangement as well.
What would be the easiest fix for my problem?
Should I transform the arrangement_with_history into a normal Arrangement_2?
Thanks for everbodies help!
Jan
#ifndef DUAL_HISTORY_BUG
#define DUAL_HISTORY_BUG
namespace CGAL {
template <class GeomTraits_, class TopTraits_>
class Dual<Arrangement_on_surface_with_history_2<GeomTraits_,TopTraits_> >
public:
  typedef GeomTraits_                          Geometry_traits_2;
  typedef TopTraits_                           Topology_traits;
  typedef CGAL::Arrangement_on_surface_with_history_2<Geometry_traits_2, Topology_traits>
                                               Arrangement_on_surface_with_history_2;
  typedef typename Arrangement_on_surface_with_history_2::Size              Size;
  typedef typename Arrangement_on_surface_with_history_2::Face_handle       Vertex_handle;
  typedef typename Arrangement_on_surface_with_history_2::Halfedge_handle   Edge_handle;
  typedef typename Arrangement_on_surface_with_history_2::Face_iterator     Vertex_iterator;
  typedef typename Arrangement_on_surface_with_history_2::Halfedge_iterator Edge_iterator;
protected:
  typedef typename Arrangement_on_surface_with_history_2::Face_handle       Face_handle;
  typedef typename Arrangement_on_surface_with_history_2::Ccb_halfedge_circulator
                                                      Ccb_halfedge_circulator;
  typedef typename Arrangement_on_surface_with_history_2::Outer_ccb_iterator
                                                      Outer_ccb_iterator;
  typedef typename Arrangement_on_surface_with_history_2::Inner_ccb_iterator
                                                      Inner_ccb_iterator;
  /*! \class
   * Iterator over the neighbors of a dual vertex (a face in the primal
   * arrangement).
   * These neighbors are the adjacent faces along the outer boundaries of the
   * face and its inner boundaries.
  class Face_neighbor_iterator
    typedef Face_neighbor_iterator               Self;
  public:
    typedef std::forward_iterator_tag            iterator_category;
    typedef Edge_handle                          value_type;
    typedef value_type                           reference;
    typedef value_type*                          pointer;
    typedef int                                  difference_type;
  private:
    Outer_ccb_iterator       _outer_ccb_iter;
    Inner_ccb_iterator       _inner_ccb_iter;
    Ccb_halfedge_circulator  _ccb_curr;
    Ccb_halfedge_circulator  _ccb_first;
    Face_handle              _face;
    bool                     _out;
    Edge_handle              _hh;
    bool                     _end;
  public:
    /*! Default constructor. */
    Face_neighbor_iterator () :
      _end (true)
     * Constructor.
     * \param face The face (dual vertex).
     * \param out_edges Do we need the outgoing or the ingoing halfedges.
     * \param start Should we start traversing the edges.
     *              If false, we construct a past-the-end iterator.
    Face_neighbor_iterator (Face_handle face,
                            bool out_edges,
                            bool start) :
      _face (face),
      _out (out_edges),
      _end (! start)
      CGAL_precondition (! face->is_fictitious());
      if (start)
        _outer_ccb_iter = _face->outer_ccbs_begin();
        _inner_ccb_iter = _face->inner_ccbs_begin();
        if (_outer_ccb_iter != _face->outer_ccbs_end())
          // Start from the first outer CCB, if one exists.
          _ccb_curr = _ccb_first = *_outer_ccb_iter;
        else if (_inner_ccb_iter != face->inner_ccbs_end())
          // Otherwise, start from the first inner CCB.
          _ccb_curr = _ccb_first = *_inner_ccb_iter;
        else
          // In this case there are no CCBs to traverse:
          _end = true;
          return;
        _hh = this->_dereference();
        // In case the incident face of the twin halfedge is fictitious,
        // skip it and proceed to the next edge.
        if (_hh->is_fictitious())
          ++(*this);
      else // end iterator.
        _outer_ccb_iter = _face->outer_ccbs_end();
        _inner_ccb_iter = _face->inner_ccbs_end();
    /*! Equality operators. */
    bool operator== (const Self& it) const
      return (this->_equal(it));
    bool operator!= (const Self& it) const
      return (! this->_equal(it));
    /*! Dereference operators. */
    reference operator* () const
      return (_hh);
    pointer operator-> () const
      return (&_hh);
    /* Increment operators. */
    Self& operator++ ()
      do
        this->_increment();
        if (_end)
          return (*this);
      } while (_hh->is_fictitious());
      return (*this);
    Self operator++ (int )
      Self tmp = *this;
      do
        this->_increment();
        if (_end)
          return (tmp);
      return (tmp);
  private:
    /*! Check two iterators for equality. */
    bool _equal (const Self& it) const
      return (_out == it._out && _face == it._face &&
              ((_end && it._end) ||
               (_outer_ccb_iter == it._outer_ccb_iter &&
                _inner_ccb_iter == it._inner_ccb_iter &&
                _ccb_curr == it._ccb_curr)));
    /*! Derefernce the current circulator. */
    Edge_handle _dereference () const
      if (_out)
        return (_ccb_curr);
      else
        return (_ccb_curr->twin());
    // Increments of the iterator.
    void _increment ()
      CGAL_assertion (! _end);
      // If we have not traversed the entire CCB in full, move to the next
      // halfedge along the current CCB.
      ++_ccb_curr;
      if (_ccb_curr != _ccb_first)
        return;
      // In this case we have completed the current CCB and we have to move
      // to the next one.
        // Try to move to the next outer CCB.
        ++_outer_ccb_iter;
          return;
        // In this case we start traversing the inner CCBs.
        if (_inner_ccb_iter != _face->inner_ccbs_end())
          CGAL_assertion (_inner_ccb_iter == _face->inner_ccbs_begin());
          return;
      else if (_inner_ccb_iter != _face->inner_ccbs_end())
        // In this case we have already traversed all outer CCBs (and at least
        // one inner CCB), so we try to move to the next inner CCB.
        ++_inner_ccb_iter;
          return;
      // In this case we finished traversing all outer and inner CCBs:
      _end = true;
      return;
  // Data members:
  mutable Arrangement_on_surface_with_history_2    *p_arr;    // The primal arrangement.
public:
  typedef Face_neighbor_iterator            Incident_edge_iterator;
  Dual () :
    p_arr (NULL)
  /*! Constructor from an arrangement. */
  Dual (const Arrangement_on_surface_with_history_2& arr) :
    p_arr (const_cast<Arrangement_on_surface_with_history_2 *> (&arr))
  /*! Get the primal arrangement (const version). */
  const Arrangement_on_surface_with_history_2* arrangement () const
    return (p_arr);
  /*! Get the primal arrangement (non-const version). */
    return (p_arr);
  /*! Get the number of vertices (face of the primal arrangement). */
  Size number_of_vertices () const
    return (p_arr->number_of_faces());
  /*! Traverse the vertices (faces of the primal arrangement). */
  Vertex_iterator vertices_begin () const
    return (p_arr->faces_begin());
  Vertex_iterator vertices_end () const
    return (p_arr->faces_end());
  /*! Get the number of edges. */
  Size number_of_edges () const
    return (p_arr->number_of_halfedges());
  /*! Traverse the edges. */
  Edge_iterator edges_begin () const
    return (p_arr->halfedges_begin());
  Edge_iterator edges_end () const
    return (p_arr->halfedges_end());
   * Get the dual vertex-degree (number of edges forming the face boundary).
  Size degree (Vertex_handle v) const
    Incident_edge_iterator   begin = Incident_edge_iterator (v, true, true);
    Incident_edge_iterator   end = Incident_edge_iterator (v, false, true);
    Size                     deg = 0;
    while (begin != end)
      deg++;
      ++begin;
    return (deg);
  /*! Traverse the outgoing edges of a given vertex. */
  Incident_edge_iterator out_edges_begin (Vertex_handle v) const
    return (Incident_edge_iterator (v, true, true));
  Incident_edge_iterator out_edges_end (Vertex_handle v) const
    return (Incident_edge_iterator (v, true, false));
  /*! Traverse the ingoing edges of a given vertex. */
  Incident_edge_iterator in_edges_begin (Vertex_handle v) const
    return (Incident_edge_iterator (v, false, true));
  Incident_edge_iterator in_edges_end (Vertex_handle v) const
    return (Incident_edge_iterator (v, false, false));
template <class Traits_, class Dcel_>
class Dual<Arrangement_with_history_2<Traits_, Dcel_> > :
  public Dual<CGAL::Arrangement_on_surface_with_history_2<
             typename CGAL::Arrangement_with_history_2<Traits_, Dcel_>::Geometry_traits_2,
             typename CGAL::Default_planar_topology<Traits_, Dcel_>::Traits> >
  typedef Traits_                                                     Traits_2;
  typedef Dcel_                                                       Dcel;
  typedef typename Default_planar_topology<Traits_2, Dcel>::Traits
  Topology_traits;
  typedef Dual<CGAL::Arrangement_on_surface_with_history_2<
                 typename CGAL::Arrangement_with_history_2<Traits_2, Dcel>::Geometry_traits_2,
                 Topology_traits> >  Base;
public:
  Dual () :
    Base()
  Dual (const CGAL::Arrangement_with_history_2<Traits_2, Dcel>& arr) :
      Base (arr)
#endif // DUAL_HISTORY_BUG
