cgal-discuss - Re: [cgal-discuss] Nef3 Problem?
  • To:
  • Subject: Re: [cgal-discuss] Nef3 Problem?
  • Date: Tue, 05 Jul 2011 07:58:44 +0200
Hello,
The problem comes from the fact that notched is not closed,
thus it is interpreted as a skin.
Sebastien.
#include <CGAL/Simple_cartesian.h>
#include <CGAL/Polyhedron_3.h>
#include <CGAL/IO/Polyhedron_iostream.h>
#include <iostream>
#include <fstream>
typedef CGAL::Simple_cartesian<double> K;
typedef CGAL::Polyhedron_3<K> Polyhedron;
int main(int,char** argv)
std::ifstream in(argv[1]);
Polyhedron p;
in >> p;
if (p.is_closed()) std::cout << "closed" << std::endl;
Wayne C. Gramlich wrote:
Greetings:
I have been using the demo/nef_3_homogeneous program quite extensively
in my code and it has been *extremely* robust.
Recently I have come up with a relatively simple case where it fails
for me. The two attached files -- "cube.off" and "notched.off"
trigger tha failure as follows:
nef_3_homogeneous loadoff notched.off loadoff cube.off union vis
and the result looks correct. However, when I change the operation
from "union" to either "inters" or "diff", the result behaves as if
"notched.off" is just a skin, rather than a filled volume. I have
used the excellent "meshlab" program to verify that all the triangle
normals are pointed in the right direction for "notched.off".
I am running CGAL 3.8 on Ubuntu 10.4 with gcc 4.4.3 using the 32-bit
x86 hardware.
Does anybody have insight into what the issue might be?
Thank you,
-Wayne
