- To:
- Subject: Re: [cgal-discuss] surface-parametrization
- Date: Thu, 07 Jul 2011 18:54:49 +0200
amich randa wrote:
how can i run it with this option i can not do anythingI am sorry, I don't know what to add.
Please either try the demo or ask to your favorite
search engine how to run a program compiled with visual
in command-line mode on windows.
Sebastien.
2011/7/7 Sebastien Loriot (GeometryFactory) <sloriot.ml <http://sloriot.ml>@gmail.com <http://gmail.com>>
This is a command-line program, you need to do run the exe with
option -h
You probably need to use the precompiled demo instead.
download here the polyhedron demo that among other things
do the surface mesh parametrization.
http://www.cgal.org/demo/3.8/__polyhedron_3.zip
<http://www.cgal.org/demo/3.8/polyhedron_3.zip>
You need to extract these dll in the same directory than
the demo
http://www.cgal.org/demo/3.8/__CGAL-demoDLLs.zip
<http://www.cgal.org/demo/3.8/CGAL-demoDLLs.zip>
Sebastien.
amich randa wrote:
where can i find this help menu please ?
<http://sloriot.ml> <http://sloriot.ml>@gmail.com
<http://gmail.com> <http://gmail.com>>
Here is the help menu:
./polyhedron_ex_____parameterization --help
PARAMETERIZATION
Allowed options:
-h [ --help ] prints this help message
-t [ --type ] arg (=floater) parameterization method: floater,
conformal,
barycentric, authalic or lscm
-b [ --border ] arg (=circle) border shape: circle, square
or 2pts
(lscm
only)
-s [ --solver ] arg (=opennl) solver: opennl or taucs
-i [ --input ] arg input mesh (OFF)
-o [ --output ] arg (=out.eps) output file (EPS or OBJ)
amich randa wrote:
sorry but i don't understand
<http://sloriot.ml>
<http://gmail.com>
amich randa wrote:
I am beginner with cgal;
I compiled the first example with c-make after I know
what to do
to achieve this parameterization
and how if for example I use
'polyhedron_ex_______parameterization.cpp' I
realize my
littleparameterization and where I can insert the
inputfile
type ./polyhedron_ex_______parameterization -h for a
detailed
description of
the command line.
Sebastien.
-- You are currently subscribed to cgal-discuss.
https://lists-sop.inria.fr/______wws/info/cgal-discuss
<https://lists-sop.inria.fr/____wws/info/cgal-discuss>
<https://lists-sop.inria.fr/__wws/info/cgal-discuss>>
<https://lists-sop.inria.fr/wws/info/cgal-discuss>>>
-- */Randa Amich
Élève ingénieur en 3eme année informatique
École Nationale des Sciences de l'Informatique
Master de Recherche Informatique
Tel:(+216) 20 67 04 71/*
*/Mail :
<mailto:>
<mailto:
<mailto:>>
<mailto:
<mailto:>
<mailto:
<mailto:>>__>__/*
-- */Randa Amich
*/Mail :
<mailto:>
<mailto:
<mailto:>>__/*
*/Randa Amich
*/Mail :
<mailto:>/*
- [cgal-discuss] surface-parametrization, amich randa, 07/07/2011
- Re: [cgal-discuss] surface-parametrization, Sebastien Loriot (GeometryFactory), 07/07/2011
- Re: [cgal-discuss] surface-parametrization, amich randa, 07/07/2011
- Re: [cgal-discuss] surface-parametrization, Giles Bathgate, 07/07/2011
- Re: [cgal-discuss] surface-parametrization, amich randa, 07/08/2011
