- To:
- Subject: Re: [cgal-discuss] problem conserning about extensible kernel
- Date: Tue, 19 Jul 2011 15:14:32 +0800
Thank you very much!
2011/7/18 Sebastien Loriot (GeometryFactory) <sloriot.ml@gmail.com>
The type-equality wrapper (making Kernel::Point_2 and Point_2<Kernel> identical, C_Point_2 in your case) only exposes constructors of
Point_2<Kernel>.
We are currently thinking about a solution to blindly (but type-safely)
forward constructors.
In your case, C_Kernel::Point_2 (which is CGAL::Point_2<C_Kernel>)
inherits from C_Point2. You can do something like this for example:
Point p(C_Point2(1.0f,2.0f,3,2));
In passing x() const should return a const reference otherwise
const cartesian iterator is using a reference to a temporary
(same for y() const)
Sebastien.--
Yue Biek wrote:
Hi,
When I study the Extensible Kernel,I meet a problem,which described as follows:
I wish to create a C_Kernel for my C_Point2 class(all in the attachment), and I create a constructor initializer for the C_point2 class which takes four parameters.the pronlem turns out as i wish to initialize the point. part of the code in the *C_Kernel* is:
* typedef C_Point2 Point_2*
* in *main()* I just call the constructor initializer *
* Point p(1.0f,2.0f,3,2)*
then it turns out to wrong,complier says that the class has no constructor initializer that takes 4 parameters.
And i found the Point_2 is not the point which I defined in the C_Point2 ,But when i changed the code as
* typedef C_Point2 Point*.
Then the program go right. I wish to know why? May be my depict are not clear,a example has been attached
in the attachment and my complier is VS2008 in Win7. Thank you!
- [cgal-discuss] problem conserning about extensible kernel, Yue Biek, 07/16/2011
- Re: [cgal-discuss] problem conserning about extensible kernel, Sebastien Loriot (GeometryFactory), 07/18/2011
- Re: [cgal-discuss] problem conserning about extensible kernel, Yue Biek, 07/19/2011
