cgal-discuss - Re: [cgal-discuss] problem with file .off
  • To:
  • Subject: Re: [cgal-discuss] problem with file .off
  • Date: Thu, 21 Jul 2011 00:22:00 +0200
i use to convert obj to off file quick3d professional
2011/7/20 Sebastien Loriot (GeometryFactory) <sloriot.ml@gmail.com>
Your conversion is probably not correct. What is the off file
that is incorrect?
Sebastien.
On 07/19/2011 05:04 PM, amich randa wrote:
hi!
i try to compile the function "polyhedron_ex_parameterization" from
"Surface_mesh_parameterization" wich need as input file .off when i use
file . off from the directory data i have no problem but i use other
files wich converted from .obj file to .off file it doesn't work and the
function consider it as not a mesh file
how can i fix this problem
*/Randa Amich
Élève ingénieur en 3eme année informatique
École Nationale des Sciences de l'Informatique
Master de  Recherche Informatique
Tel:(+216) 20 67 04 71/*
*/Mail : <mailto:>/*
Randa Amich
Mail :
