- To:
- Subject: Re: [cgal-discuss] [Arrangement_2 Graph] Face_iterator
- Date: Thu, 21 Jul 2011 18:35:36 +0300
You can look at the header, but I don't think it matters. It just implements the functions specified by boost BGL.
On Thu, Jul 21, 2011 at 1:01 PM, Pierre Cagne <> wrote:
The face iterator goes in random order.
If you want to use spanning tree on the dual graph then do exactly that. Use the adaptation to BGL to receive a BGL graph of the dual arrangement, and use one of boost algorithms for spanning trees.
Thanks a lot.I saw in the doc how to have the dual of an arrangement graph. But I couldn't find any documentation about the template type CGAL::Dual<class Arr_graph> or it's internal representation... I will look into BLG as you say.--Pierre CagneEtudiant à l'Ecole Normale Supérieure de Paris
- [cgal-discuss] [Arrangement_2 Graph] Face_iterator, Pierre Cagne, 07/20/2011
- Re: [cgal-discuss] [Arrangement_2 Graph] Face_iterator, Ophir Setter, 07/20/2011
- Re: [cgal-discuss] [Arrangement_2 Graph] Face_iterator, Pierre Cagne, 07/21/2011
- Re: [cgal-discuss] [Arrangement_2 Graph] Face_iterator, Ophir Setter, 07/21/2011
