- To:
- Subject: Re: [cgal-discuss] Meshing 3D segmented domain with 1D sharp feature
- Date: Fri, 29 Jul 2011 13:58:24 +0200
On lundi 25 juillet 2011 12:46:16
wrote:
> Hello everybody, I am really new to CGAL and now I try to learn 3D mesh
> generation of the segmented 3D images.
> In the manual (Chapter 49: 3D Mesh Generation) I have found the following
> sentence :
> " The current implementation provides classes to represent domains bounded
> by isosurfaces of implicit functions, polyhedral domains and domains
> defined through 3D labeled images. Currently, 1-dimensional features may
> be defined as segments and polyline segments. "
> Please, does it mean that a 1D-feature (line) can be preserved also using
> meshing of segmented 3D image?
> I've tried it without success.
> I run succesfully two examples shown in the manual: "mesh_3D_image.cpp" and
> "mesh_two_implicit_spheres_with_balls.cpp", in the latter it is
> demonstrated how an edge (polyline) can be preserved. Then I've tried to
> modify the file "mesh_3D_image.cpp" to implement 1D sharp feature when
> using the segmented image. .
> For that I use input image: "domain.inr", which describes a simple cube of
> sizes 128x128x128 (one material only).
> Please, can you see what I am missing, or some hints or suggestions?
> Thank you, Ivan.
The documentation probably does not say that explicitly but you must specify
the parameter 'edge_size' of the Mesh_criteria criteria object, if you use a
domain with 1D-features. For example, with your example, I have used:
// Mesh criteria
Mesh_criteria criteria(edge_size= 3, facet_angle=30, facet_size=6,
facet_distance=4, cell_radius_edge=3, cell_size=4);
What is more, in the case the 1D-features are a single segment, there was a
bug in CGAL-3.8. Apply the attached patch "Triangulation_3-r64962.patch" to
your CGAL installation, or override the file
"include/CGAL/Triangulation_data_structure_3.h" with the one I attach.
Using those two modifications, I managed to mesh the cube, with one sharp
edge
preserved.
Laurent Rineau, PhD
Index: include/CGAL/Triangulation_data_structure_3.h =================================================================== --- include/CGAL/Triangulation_data_structure_3.h (revision 64961) +++ include/CGAL/Triangulation_data_structure_3.h (revision 64962) @@ -882,8 +882,8 @@ CGAL_triangulation_assertion( number_of_vertices() >= 3); Cell_handle n0 = v->cell(); Cell_handle n1 = n0->neighbor(1-n0->index(v)); - *edges++ = Edge(n0, n0->index(v), 1-n0->index(v)); - *edges++ = Edge(n1, n1->index(v), 1-n1->index(v)); + if(!f(n0->vertex(1-n0->index(v)))) *edges++ = Edge(n0, n0->index(v), 1-n0->index(v)); + if(!f(n1->vertex(1-n1->index(v)))) *edges++ = Edge(n1, n1->index(v), 1-n1->index(v)); return edges; } return visit_incident_cells<Vertex_extractor<Edge_feeder_treatment<OutputIterator>, @@ -919,8 +919,10 @@ CGAL_triangulation_assertion( number_of_vertices() >= 3); Cell_handle n0 = v->cell(); Cell_handle n1 = n0->neighbor(1-n0->index(v)); - *vertices++ = n0->vertex(1-n0->index(v)); - *vertices++ = n1->vertex(1-n1->index(v)); + Vertex_handle v1 = n0->vertex(1-n0->index(v)); + Vertex_handle v2 = n1->vertex(1-n1->index(v)); + if(!f(v1)) *vertices++ = v1; + if(!f(v2)) *vertices++ = v2; return vertices; } return visit_incident_cells<Vertex_extractor<Vertex_feeder_treatment<OutputIterator>,
// Copyright (c) 1999-2005 INRIA Sophia-Antipolis (France). // All rights reserved. // // This file is part of CGAL (www.cgal.org); you may redistribute it under // the terms of the Q Public License version 1.0. // See the file LICENSE.QPL distributed with CGAL. // // Licensees holding a valid commercial license may use this file in // accordance with the commercial license agreement provided with the software. // // This file is provided AS IS with NO WARRANTY OF ANY KIND, INCLUDING THE // WARRANTY OF DESIGN, MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE. // // $URL: svn+ssh://scm.gforge.inria.fr/svn/cgal/trunk/Triangulation_3/include/CGAL/Triangulation_data_structure_3.h $ // $Id: Triangulation_data_structure_3.h 60298 2010-12-10 17:02:10Z lrineau $ // // Author(s) : Monique Teillaud <> // Sylvain Pion // combinatorial triangulation of the boundary of a polytope // of dimension d in dimension d+1 // for -1 <= d <= 3 #ifndef CGAL_TRIANGULATION_DATA_STRUCTURE_3_H #define CGAL_TRIANGULATION_DATA_STRUCTURE_3_H #include <CGAL/basic.h> #include <utility> #include <map> #include <set> #include <vector> #include <stack> #include <CGAL/utility.h> #include <CGAL/iterator.h> #include <CGAL/triangulation_assertions.h> #include <CGAL/Triangulation_utils_3.h> #include <CGAL/Compact_container.h> #include <CGAL/Triangulation_ds_cell_base_3.h> #include <CGAL/Triangulation_ds_vertex_base_3.h> #include <CGAL/Triangulation_simplex_3.h> #include <CGAL/internal/Triangulation_ds_iterators_3.h> #include <CGAL/internal/Triangulation_ds_circulators_3.h> #ifdef CGAL_HAS_THREADS # include <boost/thread/tss.hpp> #endif namespace CGAL { // TODO : noms : Vb != Vertex_base : clarifier. template < class Vb = Triangulation_ds_vertex_base_3<>, class Cb = Triangulation_ds_cell_base_3<> > class Triangulation_data_structure_3 : public Triangulation_utils_3 { typedef Triangulation_data_structure_3<Vb,Cb> Tds; public: // Tools to change the Vertex and Cell types of the TDS. template < typename Vb2 > struct Rebind_vertex { typedef Triangulation_data_structure_3<Vb2, Cb> Other; }; template < typename Cb2 > struct Rebind_cell { typedef Triangulation_data_structure_3<Vb, Cb2> Other; }; // Put this TDS inside the Vertex and Cell types. typedef typename Vb::template Rebind_TDS<Tds>::Other Vertex; typedef typename Cb::template Rebind_TDS<Tds>::Other Cell; class Cell_data { unsigned char conflict_state; public: Cell_data() : conflict_state(0) {} void clear() { conflict_state = 0; } void mark_in_conflict() { conflict_state = 1; } void mark_on_boundary() { conflict_state = 2; } void mark_processed() { conflict_state = 1; } bool is_clear() const { return conflict_state == 0; } bool is_in_conflict() const { return conflict_state == 1; } bool is_on_boundary() const { return conflict_state == 2; } bool processed() const { return conflict_state == 1; } }; private: friend class internal::Triangulation_ds_facet_iterator_3<Tds>; friend class internal::Triangulation_ds_edge_iterator_3<Tds>; friend class internal::Triangulation_ds_cell_circulator_3<Tds>; friend class internal::Triangulation_ds_facet_circulator_3<Tds>; public: typedef Compact_container<Cell> Cell_range; typedef Compact_container<Vertex> Vertex_range; typedef typename Cell_range::size_type size_type; typedef typename Cell_range::difference_type difference_type; typedef typename Cell_range::iterator Cell_iterator; typedef typename Vertex_range::iterator Vertex_iterator; typedef internal::Triangulation_ds_facet_iterator_3<Tds> Facet_iterator; typedef internal::Triangulation_ds_edge_iterator_3<Tds> Edge_iterator; typedef internal::Triangulation_ds_cell_circulator_3<Tds> Cell_circulator; typedef internal::Triangulation_ds_facet_circulator_3<Tds> Facet_circulator; //private: // In 2D only : typedef internal::Triangulation_ds_face_circulator_3<Tds> Face_circulator; typedef Vertex_iterator Vertex_handle; typedef Cell_iterator Cell_handle; typedef std::pair<Cell_handle, int> Facet; typedef Triple<Cell_handle, int, int> Edge; typedef Triangulation_simplex_3<Tds> Simplex; #ifndef CGAL_TDS_USE_OLD_CREATE_STAR_3 //internally used for create_star_3 (faster than a tuple) struct iAdjacency_info{ int v1; Cell_handle v2; int v3; Cell_handle v4; int v5; int v6; iAdjacency_info(){} iAdjacency_info(int a1,Cell_handle a2,int a3,Cell_handle a4,int a5 ,int a6): v1(a1),v2(a2),v3(a3),v4(a4),v5(a5),v6(a6) {} void update_variables(int& a1,Cell_handle& a2,int& a3,Cell_handle& a4,int& a5 ,int& a6) { a1=v1; a2=v2; a3=v3; a4=v4; a5=v5; a6=v6; } }; #endif public: Triangulation_data_structure_3() : _dimension(-2) {} Triangulation_data_structure_3(const Tds & tds) { copy_tds(tds); } Tds & operator= (const Tds & tds) { if (&tds != this) { Tds tmp(tds); swap(tmp); } return *this; } size_type number_of_vertices() const { return vertices().size(); } int dimension() const {return _dimension;} size_type number_of_cells() const { if ( dimension() < 3 ) return 0; return cells().size(); } size_type number_of_facets() const { if ( dimension() < 2 ) return 0; return std::distance(facets_begin(), facets_end()); } size_type number_of_edges() const { if ( dimension() < 1 ) return 0; return std::distance(edges_begin(), edges_end()); } // USEFUL CONSTANT TIME FUNCTIONS // SETTING void set_dimension(int n) { _dimension = n; } Vertex_handle create_vertex(const Vertex &v) { return vertices().insert(v); } Vertex_handle create_vertex() { return vertices().emplace(); } Vertex_handle create_vertex(Vertex_handle v) { return create_vertex(*v); } Cell_handle create_cell(const Cell &c) { return cells().insert(c); } Cell_handle create_cell() { return cells().emplace(); } Cell_handle create_cell(Cell_handle c) { return create_cell(*c); } Cell_handle create_cell(Vertex_handle v0, Vertex_handle v1, Vertex_handle v2, Vertex_handle v3) { return cells().emplace(v0, v1, v2, v3); } Cell_handle create_cell(Vertex_handle v0, Vertex_handle v1, Vertex_handle v2, Vertex_handle v3, Cell_handle n0, Cell_handle n1, Cell_handle n2, Cell_handle n3) { return cells().emplace(v0, v1, v2, v3, n0, n1, n2, n3); } Cell_handle create_face() { CGAL_triangulation_precondition(dimension()<3); return create_cell(); } Cell_handle create_face(Vertex_handle v0, Vertex_handle v1, Vertex_handle v2) { CGAL_triangulation_precondition(dimension()<3); return cells().emplace(v0, v1, v2, Vertex_handle()); } // The following functions come from TDS_2. Cell_handle create_face(Cell_handle f0, int i0, Cell_handle f1, int i1, Cell_handle f2, int i2) { CGAL_triangulation_precondition(dimension() <= 2); Cell_handle newf = create_face(f0->vertex(cw(i0)), f1->vertex(cw(i1)), f2->vertex(cw(i2))); set_adjacency(newf, 2, f0, i0); set_adjacency(newf, 0, f1, i1); set_adjacency(newf, 1, f2, i2); return newf; } Cell_handle create_face(Cell_handle f0, int i0, Cell_handle f1, int i1) { CGAL_triangulation_precondition(dimension() <= 2); Cell_handle newf = create_face(f0->vertex(cw(i0)), f1->vertex(cw(i1)), f1->vertex(ccw(i1))); set_adjacency(newf, 2, f0, i0); set_adjacency(newf, 0, f1, i1); return newf; } Cell_handle create_face(Cell_handle f, int i, Vertex_handle v) { CGAL_triangulation_precondition(dimension() <= 2); Cell_handle newf = create_face(f->vertex(cw(i)), f->vertex(ccw(i)), v); set_adjacency(newf, 2, f, i); return newf; } // not documented void read_cells(std::istream& is, std::map< std::size_t, Vertex_handle > &V, std::size_t & m, std::map< std::size_t, Cell_handle > &C ); // not documented void print_cells(std::ostream& os, const std::map<Vertex_handle, std::size_t> &V ) const; // ACCESS FUNCTIONS void delete_vertex( Vertex_handle v ) { CGAL_triangulation_expensive_precondition( is_vertex(v) ); vertices().erase(v); } void delete_cell( Cell_handle c ) { CGAL_triangulation_expensive_precondition( is_simplex(c) ); cells().erase(c); } template <class InputIterator> void delete_vertices(InputIterator begin, InputIterator end) { for(; begin != end; ++begin) delete_vertex(*begin); } template <class InputIterator> void delete_cells(InputIterator begin, InputIterator end) { for(; begin != end; ++begin) delete_cell(*begin); } // QUERIES bool is_simplex(Cell_handle c) const; // undocumented for now bool is_vertex(Vertex_handle v) const; bool is_edge(Cell_handle c, int i, int j) const; bool is_edge(Vertex_handle u, Vertex_handle v, Cell_handle & c, int & i, int & j) const; bool is_edge(Vertex_handle u, Vertex_handle v) const; bool is_facet(Cell_handle c, int i) const; bool is_facet(Vertex_handle u, Vertex_handle v, Vertex_handle w, Cell_handle & c, int & i, int & j, int & k) const; bool is_cell(Cell_handle c) const; bool is_cell(Vertex_handle u, Vertex_handle v, Vertex_handle w, Vertex_handle t, Cell_handle & c, int & i, int & j, int & k, int & l) const; bool is_cell(Vertex_handle u, Vertex_handle v, Vertex_handle w, Vertex_handle t) const; bool has_vertex(const Facet & f, Vertex_handle v, int & j) const; bool has_vertex(Cell_handle c, int i, Vertex_handle v, int & j) const; bool has_vertex(const Facet & f, Vertex_handle v) const; bool has_vertex(Cell_handle c, int i, Vertex_handle v) const; bool are_equal(Cell_handle c, int i, Cell_handle n, int j) const; bool are_equal(const Facet & f, const Facet & g) const; bool are_equal(const Facet & f, Cell_handle n, int j) const; // MODIFY bool flip(Cell_handle c, int i); bool flip(const Facet &f) { return flip( f.first, f.second); } void flip_flippable(Cell_handle c, int i); void flip_flippable(const Facet &f) { flip_flippable( f.first, f.second ); } bool flip(Cell_handle c, int i, int j); bool flip(const Edge &e) { return flip( e.first, e.second, e.third ); } void flip_flippable(Cell_handle c, int i, int j); void flip_flippable(const Edge &e) { flip_flippable( e.first, e.second, e.third ); } private: // common to flip and flip_flippable void flip_really(Cell_handle c, int i, Cell_handle n, int in); void flip_really(Cell_handle c, int i, int j, Cell_handle c1, Vertex_handle v1, int i1, int j1, int next1, Cell_handle c2, Vertex_handle v2, int i2, int j2, int next2, Vertex_handle v3); Cell_handle create_star_3(Vertex_handle v, Cell_handle c, int li, int prev_ind2 = -1); Cell_handle create_star_2(Vertex_handle v, Cell_handle c, int li); public: // Internal function : assumes the conflict cells are marked. template <class CellIt> Vertex_handle _insert_in_hole(CellIt cell_begin, CellIt cell_end, Cell_handle begin, int i, Vertex_handle newv) { CGAL_triangulation_precondition(begin != Cell_handle()); // if begin == NULL (default arg), we could compute one by walking in // CellIt. At the moment, the functionality is not available, you have // to specify a starting facet. Cell_handle cnew; if (dimension() == 3) cnew = create_star_3(newv, begin, i); else cnew = create_star_2(newv, begin, i); newv->set_cell(cnew); delete_cells(cell_begin, cell_end); return newv; } // Internal function : assumes the conflict cells are marked. template <class CellIt> Vertex_handle _insert_in_hole(CellIt cell_begin, CellIt cell_end, Cell_handle begin, int i) { return _insert_in_hole(cell_begin, cell_end, begin, i, create_vertex()); } // Mark the cells in conflict, then calls the internal function. template <class CellIt> Vertex_handle insert_in_hole(CellIt cell_begin, CellIt cell_end, Cell_handle begin, int i, Vertex_handle newv) { for (CellIt cit = cell_begin; cit != cell_end; ++cit) (*cit)->tds_data().mark_in_conflict(); return _insert_in_hole(cell_begin, cell_end, begin, i, newv); } // Mark the cells in conflict, then calls the internal function. template <class CellIt> Vertex_handle insert_in_hole(CellIt cell_begin, CellIt cell_end, Cell_handle begin, int i) { return insert_in_hole(cell_begin, cell_end, begin, i, create_vertex()); } //INSERTION Vertex_handle insert_in_cell(Cell_handle c); Vertex_handle insert_in_facet(const Facet & f) { return insert_in_facet(f.first, f.second); } Vertex_handle insert_in_facet(Cell_handle c, int i); Vertex_handle insert_in_edge(const Edge & e) { return insert_in_edge(e.first, e.second, e.third); } Vertex_handle insert_in_edge(Cell_handle c, int i, int j); Vertex_handle insert_increase_dimension(Vertex_handle star =Vertex_handle()); // REMOVAL private: Cell_handle remove_degree_4(Vertex_handle v); Cell_handle remove_degree_3(Vertex_handle v); Cell_handle remove_degree_2(Vertex_handle v); public: Cell_handle remove_from_maximal_dimension_simplex(Vertex_handle v); void remove_decrease_dimension(Vertex_handle v) { remove_decrease_dimension (v, v); } void remove_decrease_dimension(Vertex_handle v, Vertex_handle w); void decrease_dimension(Cell_handle f, int i); // Change orientation of the whole TDS. void reorient() { CGAL_triangulation_precondition(dimension() >= 1); for (Cell_iterator i = cells().begin(); i != cells().end(); ++i) change_orientation(i); } // ITERATOR METHODS Cell_iterator cells_begin() const { if ( dimension() < 3 ) return cells_end(); return cells().begin(); } Cell_iterator cells_end() const { return cells().end(); } Cell_iterator raw_cells_begin() const { return cells().begin(); } Cell_iterator raw_cells_end() const { return cells().end(); } Facet_iterator facets_begin() const { if ( dimension() < 2 ) return facets_end(); return Facet_iterator(this); } Facet_iterator facets_end() const { return Facet_iterator(this, 1); } Edge_iterator edges_begin() const { if ( dimension() < 1 ) return edges_end(); return Edge_iterator(this); } Edge_iterator edges_end() const { return Edge_iterator(this,1); } Vertex_iterator vertices_begin() const { return vertices().begin(); } Vertex_iterator vertices_end() const { return vertices().end(); } // CIRCULATOR METHODS // cells around an edge Cell_circulator incident_cells(const Edge & e) const { CGAL_triangulation_precondition( dimension() == 3 ); return Cell_circulator(e); } Cell_circulator incident_cells(Cell_handle ce, int i, int j) const { CGAL_triangulation_precondition( dimension() == 3 ); return Cell_circulator(ce, i, j); } Cell_circulator incident_cells(const Edge &e, Cell_handle start) const { CGAL_triangulation_precondition( dimension() == 3 ); return Cell_circulator(e, start); } Cell_circulator incident_cells(Cell_handle ce, int i, int j, Cell_handle start) const { CGAL_triangulation_precondition( dimension() == 3 ); return Cell_circulator(ce, i, j, start); } //facets around an edge Facet_circulator incident_facets(const Edge & e) const { CGAL_triangulation_precondition( dimension() == 3 ); return Facet_circulator(e); } Facet_circulator incident_facets(Cell_handle ce, int i, int j) const { CGAL_triangulation_precondition( dimension() == 3 ); return Facet_circulator(ce, i, j); } Facet_circulator incident_facets(const Edge & e, const Facet & start) const { CGAL_triangulation_precondition( dimension() == 3 ); return Facet_circulator(e, start); } Facet_circulator incident_facets(Cell_handle ce, int i, int j, const Facet & start) const { CGAL_triangulation_precondition( dimension() == 3 ); return Facet_circulator(ce, i, j, start); } Facet_circulator incident_facets(const Edge & e, Cell_handle start, int f) const { CGAL_triangulation_precondition( dimension() == 3 ); return Facet_circulator(e, start, f); } Facet_circulator incident_facets(Cell_handle ce, int i, int j, Cell_handle start, int f) const { CGAL_triangulation_precondition( dimension() == 3 ); return Facet_circulator(ce, i, j, start, f); } // 2D : circulates on the faces adjacent to a vertex. Face_circulator incident_faces(Vertex_handle v) const { CGAL_triangulation_precondition( dimension() == 2 ); return Face_circulator(v, v->cell()); } // around a vertex private: template <class IncidentCellIterator, class IncidentFacetIterator> std::pair<IncidentCellIterator, IncidentFacetIterator> incident_cells_3(Vertex_handle v, Cell_handle d, std::pair<IncidentCellIterator, IncidentFacetIterator> it) const { CGAL_triangulation_precondition(dimension() == 3); std::stack<Cell_handle> cell_stack; cell_stack.push(d); d->tds_data().mark_in_conflict(); *it.first++ = d; do { Cell_handle c = cell_stack.top(); cell_stack.pop(); for (int i=0; i<4; ++i) { if (c->vertex(i) == v) continue; Cell_handle next = c->neighbor(i); if (c < next) *it.second++ = Facet(c, i); // Incident facet. if (! next->tds_data().is_clear()) continue; cell_stack.push(next); next->tds_data().mark_in_conflict(); *it.first++ = next; } } while(!cell_stack.empty()); return it; } template <class OutputIterator> void incident_cells_2(Vertex_handle v, Cell_handle c, OutputIterator cells) const { CGAL_triangulation_precondition(dimension() == 2); // TODO : in 2D, there's no real need for tds_data, we could use // a smarter algorithm. We could use the 2D Face_circulator. // Should we just have this Face_circulator ? // Flag values : // 1 : incident cell already visited // 0 : unknown c->tds_data().mark_in_conflict(); *cells++ = c; for (int i=0; i<3; ++i) { if (c->vertex(i) == v) continue; Cell_handle next = c->neighbor(i); if (! next->tds_data().is_clear()) continue; incident_cells_2(v, next, cells); } } public: class False_filter { public: False_filter() {} template<class T> bool operator() (T) { return false; } }; // Visitor for visit_incident_cells: // outputs the facets template <class OutputIterator, class Filter> class Facet_extractor { OutputIterator output; Filter filter; public: Facet_extractor(Vertex_handle, OutputIterator _output, const Tds*, Filter _filter): output(_output), filter(_filter){} void operator() (Cell_handle) {} OutputIterator result() { return output; } class Facet_it { OutputIterator& output; Filter& filter; public: Facet_it(OutputIterator& _output, Filter& _filter): output(_output), filter(_filter) {} Facet_it& operator*() {return *this;}; Facet_it& operator++() {return *this;}; Facet_it operator++(int) {return *this;}; template<class T> Facet_it& operator=(const T& e) { if(filter(e)) return *this; *output++ = e; return *this; } Facet_it& operator=(const Facet_it& f) { output = f.output; filter = f.filter; return *this; } }; Facet_it facet_it() { return Facet_it(output, filter); } }; // Visitor for visit_incident_cells: // outputs the cells template <class OutputIterator, class Filter> class Cell_extractor { OutputIterator output; Filter filter; public: Cell_extractor(Vertex_handle, OutputIterator _output, const Tds*, Filter _filter): output(_output), filter(_filter) {} void operator()(Cell_handle c) { if(filter(c)) return; *output++ = c; } CGAL::Emptyset_iterator facet_it() {return CGAL::Emptyset_iterator();} OutputIterator result() { return output; } }; // Visitor for visit_incident_cells: // WARNING: 2D ONLY // outputs the faces obtained as degenerated cells template <class OutputIterator, class Filter> class DegCell_as_Facet_extractor { OutputIterator output; Filter filter; public: DegCell_as_Facet_extractor(Vertex_handle, OutputIterator _output, const Tds*, Filter _filter): output(_output), filter(_filter) {} void operator()(Cell_handle c) { Facet f = Facet(c,3); if(filter(f)) return; *output++ = f; } CGAL::Emptyset_iterator facet_it() {return CGAL::Emptyset_iterator();} OutputIterator result() { return output; } }; // Visitor for visit_incident_cells: // outputs the result of Treatment applied to the vertices template<class Treatment, class OutputIterator, class Filter> class Vertex_extractor { Vertex_handle v; std::set<Vertex_handle> tmp_vertices; Treatment treat; const Tds* t; Filter filter; public: Vertex_extractor(Vertex_handle _v, OutputIterator _output, const Tds* _t, Filter _filter): v(_v), treat(_output), t(_t), filter(_filter) {} void operator()(Cell_handle c) { for (int j=0; j<= t->dimension(); ++j) { Vertex_handle w = c->vertex(j); if(filter(w)) continue; if (w != v) if(tmp_vertices.insert(w).second) { treat(c, v, j); } } } CGAL::Emptyset_iterator facet_it() {return CGAL::Emptyset_iterator();} OutputIterator result() { return treat.result(); } }; // Treatment for Vertex_extractor: // outputs the vertices template<class OutputIterator> class Vertex_feeder_treatment { OutputIterator output; public: Vertex_feeder_treatment(OutputIterator _output): output(_output) {}; void operator()(Cell_handle c, Vertex_handle, int index) { *output++ = c->vertex(index); } OutputIterator result() { return output; } }; // Treatment for Vertex_extractor: // outputs the edges corresponding to the vertices template<class OutputIterator> class Edge_feeder_treatment { OutputIterator output; public: Edge_feeder_treatment(OutputIterator _output): output(_output) {}; void operator()(Cell_handle c, Vertex_handle v, int index) { *output++ = Edge(c, c->index(v), index); } OutputIterator result() { return output; } }; template <class Filter, class OutputIterator> OutputIterator incident_cells(Vertex_handle v, OutputIterator cells, Filter f = Filter()) const { return visit_incident_cells<Cell_extractor<OutputIterator, Filter>, OutputIterator>(v, cells, f); } template <class OutputIterator> OutputIterator incident_cells(Vertex_handle v, OutputIterator cells) const { return incident_cells<False_filter>(v, cells); } template <class Filter, class OutputIterator> OutputIterator incident_facets(Vertex_handle v, OutputIterator facets, Filter f = Filter()) const { CGAL_triangulation_precondition( dimension() > 1 ); if(dimension() == 3) return visit_incident_cells<Facet_extractor<OutputIterator, Filter>, OutputIterator>(v, facets, f); else return visit_incident_cells<DegCell_as_Facet_extractor<OutputIterator, Filter>, OutputIterator>(v, facets, f); } template <class OutputIterator> OutputIterator incident_facets(Vertex_handle v, OutputIterator facets) const { return incident_facets<False_filter>(v, facets); } template <class Filter, class OutputIterator> OutputIterator incident_edges(Vertex_handle v, OutputIterator edges, Filter f = Filter()) const { CGAL_triangulation_precondition( v != Vertex_handle() ); CGAL_triangulation_precondition( dimension() >= 1 ); CGAL_triangulation_expensive_precondition( is_vertex(v) ); CGAL_triangulation_expensive_precondition( is_valid() ); if (dimension() == 1) { CGAL_triangulation_assertion( number_of_vertices() >= 3); Cell_handle n0 = v->cell(); Cell_handle n1 = n0->neighbor(1-n0->index(v)); if(!f(n0->vertex(1-n0->index(v)))) *edges++ = Edge(n0, n0->index(v), 1-n0->index(v)); if(!f(n1->vertex(1-n1->index(v)))) *edges++ = Edge(n1, n1->index(v), 1-n1->index(v)); return edges; } return visit_incident_cells<Vertex_extractor<Edge_feeder_treatment<OutputIterator>, OutputIterator, Filter>, OutputIterator>(v, edges, f); } template <class OutputIterator> OutputIterator incident_edges(Vertex_handle v, OutputIterator edges) const { return incident_edges<False_filter>(v, edges); } template <class Filter, class OutputIterator> OutputIterator adjacent_vertices(Vertex_handle v, OutputIterator vertices, Filter f = Filter()) const { CGAL_triangulation_precondition( v != Vertex_handle() ); CGAL_triangulation_precondition( dimension() >= -1 ); CGAL_triangulation_expensive_precondition( is_vertex(v) ); CGAL_triangulation_expensive_precondition( is_valid() ); if (dimension() == -1) return vertices; if (dimension() == 0) { *vertices++ = v->cell()->neighbor(0)->vertex(0); return vertices; } if (dimension() == 1) { CGAL_triangulation_assertion( number_of_vertices() >= 3); Cell_handle n0 = v->cell(); Cell_handle n1 = n0->neighbor(1-n0->index(v)); Vertex_handle v1 = n0->vertex(1-n0->index(v)); Vertex_handle v2 = n1->vertex(1-n1->index(v)); if(!f(v1)) *vertices++ = v1; if(!f(v2)) *vertices++ = v2; return vertices; } return visit_incident_cells<Vertex_extractor<Vertex_feeder_treatment<OutputIterator>, OutputIterator, Filter>, OutputIterator>(v, vertices, f); } // old name - kept for backwards compatibility but not documented template <class OutputIterator> OutputIterator incident_vertices(Vertex_handle v, OutputIterator vertices) const { return adjacent_vertices<False_filter>(v, vertices); } // correct name template <class OutputIterator> OutputIterator adjacent_vertices(Vertex_handle v, OutputIterator vertices) const { return adjacent_vertices<False_filter>(v, vertices); } template <class Visitor, class OutputIterator, class Filter> OutputIterator visit_incident_cells(Vertex_handle v, OutputIterator output, Filter f) const { CGAL_triangulation_precondition( v != Vertex_handle() ); CGAL_triangulation_expensive_precondition( is_vertex(v) ); if ( dimension() < 2 ) return output; Visitor visit(v, output, this, f); std::vector<Cell_handle> tmp_cells; tmp_cells.reserve(64); if ( dimension() == 3 ) incident_cells_3(v, v->cell(), std::make_pair(std::back_inserter(tmp_cells), visit.facet_it())); else incident_cells_2(v, v->cell(), std::back_inserter(tmp_cells)); typename std::vector<Cell_handle>::iterator cit; for(cit = tmp_cells.begin(); cit != tmp_cells.end(); ++cit) { (*cit)->tds_data().clear(); visit(*cit); } return visit.result(); } size_type degree(Vertex_handle v) const; // CHECKING bool is_valid(bool verbose = false, int level = 0) const; bool is_valid(Vertex_handle v, bool verbose = false, int level = 0) const; bool is_valid(Cell_handle c, bool verbose = false, int level = 0) const; // Helping functions Vertex_handle copy_tds(const Tds & tds, Vertex_handle vert = Vertex_handle() ); // returns the new vertex corresponding to vert in the new tds void swap(Tds & tds); void clear(); void set_adjacency(Cell_handle c0, int i0, Cell_handle c1, int i1) const { CGAL_triangulation_assertion(i0 >= 0 && i0 <= dimension()); CGAL_triangulation_assertion(i1 >= 0 && i1 <= dimension()); CGAL_triangulation_assertion(c0 != c1); c0->set_neighbor(i0,c1); c1->set_neighbor(i1,c0); } int mirror_index(Cell_handle c, int i) const { CGAL_triangulation_precondition ( i>=0 && i<4 ); return c->neighbor(i)->index(c); } Vertex_handle mirror_vertex(Cell_handle c, int i) const { return c->neighbor(i)->vertex(mirror_index(c, i)); } Facet mirror_facet(Facet f) const { Cell_handle neighbor_cell = f.first->neighbor(f.second); const int opposite_index = neighbor_cell->index(f.first); return Facet(neighbor_cell, opposite_index); } // We need the const_cast<>s because TDS is not const-correct. Cell_range & cells() { return _cells; } Cell_range & cells() const { return const_cast<Tds*>(this)->_cells; } Vertex_range & vertices() {return _vertices;} Vertex_range & vertices() const { return const_cast<Tds*>(this)->_vertices; } private: // Change the orientation of the cell by swapping indices 0 and 1. void change_orientation(Cell_handle c) const { Vertex_handle tmp_v = c->vertex(0); c->set_vertex(0, c->vertex(1)); c->set_vertex(1, tmp_v); Cell_handle tmp_c = c->neighbor(0); c->set_neighbor(0, c->neighbor(1)); c->set_neighbor(1, tmp_c); } // in dimension i, number of vertices >= i+2 // ( the boundary of a simplex in dimension i+1 has i+2 vertices ) int _dimension; Cell_range _cells; Vertex_range _vertices; // used by is-valid : bool count_vertices(size_type &i, bool verbose = false, int level = 0) const; // counts AND checks the validity bool count_facets(size_type &i, bool verbose = false, int level = 0) const; // counts but does not check bool count_edges(size_type &i, bool verbose = false, int level = 0) const; // counts but does not check bool count_cells(size_type &i, bool verbose = false, int level = 0) const; // counts AND checks the validity }; #ifdef CGAL_TDS_USE_OLD_CREATE_STAR_3 template <class Vb, class Cb > typename Triangulation_data_structure_3<Vb,Cb>::Cell_handle Triangulation_data_structure_3<Vb,Cb>:: create_star_3(Vertex_handle v, Cell_handle c, int li, int prev_ind2) { CGAL_triangulation_precondition( dimension() == 3); CGAL_triangulation_precondition( c->tds_data().is_in_conflict() ); CGAL_triangulation_precondition( ! c->neighbor(li)->tds_data().is_in_conflict() ); Cell_handle cnew = create_cell(c->vertex(0), c->vertex(1), c->vertex(2), c->vertex(3)); cnew->set_vertex(li, v); Cell_handle c_li = c->neighbor(li); set_adjacency(cnew, li, c_li, c_li->index(c)); // Look for the other neighbors of cnew. for (int ii=0; ii<4; ++ii) { if (ii == prev_ind2 || cnew->neighbor(ii) != Cell_handle()) continue; cnew->vertex(ii)->set_cell(cnew); // Indices of the vertices of cnew such that ii,vj1,vj2,li positive. Vertex_handle vj1 = c->vertex(next_around_edge(ii, li)); Vertex_handle vj2 = c->vertex(next_around_edge(li, ii)); Cell_handle cur = c; int zz = ii; Cell_handle n = cur->neighbor(zz); // turn around the oriented edge vj1 vj2 while ( n->tds_data().is_in_conflict() ) { CGAL_triangulation_assertion( n != c ); cur = n; zz = next_around_edge(n->index(vj1), n->index(vj2)); n = cur->neighbor(zz); } // Now n is outside region, cur is inside. n->tds_data().clear(); // Reset the flag for boundary cells. int jj1 = n->index(vj1); int jj2 = n->index(vj2); Vertex_handle vvv = n->vertex(next_around_edge(jj1, jj2)); Cell_handle nnn = n->neighbor(next_around_edge(jj2, jj1)); int zzz = nnn->index(vvv); if (nnn == cur) { // Neighbor relation is reciprocal, ie // the cell we are looking for is not yet created. nnn = create_star_3(v, nnn, zz, zzz); } set_adjacency(nnn, zzz, cnew, ii); } return cnew; } #else //This function used to be recursive. //This design resulted in call stack overflow in some cases. //When we rewrote it, to emulate the class stack, we use a c++ stack. //The stack used is a enriched std::vector that call reserve(N) when constructed //(faster that testing capacity>N at each call of create_star_3). //We use the class iAdjacency_info instead of a tuple because //at the moment we made the change it was faster like this. //The stack is a static variable of the function because it was also //faster when we tested it. template <class Vb, class Cb > typename Triangulation_data_structure_3<Vb,Cb>::Cell_handle Triangulation_data_structure_3<Vb,Cb>:: create_star_3(Vertex_handle v, Cell_handle c, int li, int prev_ind2) { CGAL_triangulation_precondition( dimension() == 3); CGAL_triangulation_precondition( c->tds_data().is_in_conflict() ); CGAL_triangulation_precondition( ! c->neighbor(li)->tds_data().is_in_conflict() ); Cell_handle cnew = create_cell(c->vertex(0), c->vertex(1), c->vertex(2), c->vertex(3)); cnew->set_vertex(li, v); Cell_handle c_li = c->neighbor(li); set_adjacency(cnew, li, c_li, c_li->index(c)); #ifdef CGAL_HAS_THREADS static boost::thread_specific_ptr< std::vector<iAdjacency_info> > stack_safe_ptr; if (stack_safe_ptr.get() == NULL) { stack_safe_ptr.reset(new std::vector<iAdjacency_info>()); stack_safe_ptr.get()->reserve(64); } std::vector<iAdjacency_info>& adjacency_info_stack=* stack_safe_ptr.get(); #else static std::vector<iAdjacency_info> adjacency_info_stack; adjacency_info_stack.reserve(64); #endif int ii=0; do { // Look for the other neighbors of cnew. if ( ! (ii == prev_ind2 || cnew->neighbor(ii) != Cell_handle()) ){ cnew->vertex(ii)->set_cell(cnew); // Indices of the vertices of cnew such that ii,vj1,vj2,li positive. Vertex_handle vj1 = c->vertex(next_around_edge(ii, li)); Vertex_handle vj2 = c->vertex(next_around_edge(li, ii)); Cell_handle cur = c; int zz = ii; Cell_handle n = cur->neighbor(zz); // turn around the oriented edge vj1 vj2 while ( n->tds_data().is_in_conflict() ) { CGAL_triangulation_assertion( n != c ); cur = n; zz = next_around_edge(n->index(vj1), n->index(vj2)); n = cur->neighbor(zz); } // Now n is outside region, cur is inside. n->tds_data().clear(); // Reset the flag for boundary cells. int jj1 = n->index(vj1); int jj2 = n->index(vj2); Vertex_handle vvv = n->vertex(next_around_edge(jj1, jj2)); Cell_handle nnn = n->neighbor(next_around_edge(jj2, jj1)); int zzz = nnn->index(vvv); if (nnn == cur) { // Neighbor relation is reciprocal, ie // the cell we are looking for is not yet created. //re-run the loop adjacency_info_stack.push_back( iAdjacency_info(zzz,cnew,ii,c,li,prev_ind2) ); c=nnn; li=zz; prev_ind2=zzz; ii=0; //copy-pasted from beginning to avoid if ii==0 CGAL_triangulation_precondition( c->tds_data().is_in_conflict() ); CGAL_triangulation_precondition( ! c->neighbor(li)->tds_data().is_in_conflict() ); cnew = create_cell(c->vertex(0),c->vertex(1),c->vertex(2),c->vertex(3)); cnew->set_vertex(li, v); c_li = c->neighbor(li); set_adjacency(cnew, li, c_li, c_li->index(c)); continue; } set_adjacency(nnn, zzz, cnew, ii); } while (++ii==4){ if ( adjacency_info_stack.empty() ) return cnew; Cell_handle nnn=cnew; int zzz; adjacency_info_stack.back().update_variables(zzz,cnew,ii,c,li,prev_ind2); adjacency_info_stack.pop_back(); set_adjacency(nnn, zzz, cnew, ii); } } while (true); } #endif template <class Vb, class Cb > typename Triangulation_data_structure_3<Vb,Cb>::Cell_handle Triangulation_data_structure_3<Vb,Cb>:: create_star_2(Vertex_handle v, Cell_handle c, int li ) { CGAL_triangulation_assertion( dimension() == 2 ); Cell_handle cnew; // i1 i2 such that v,i1,i2 positive int i1=ccw(li); // traversal of the boundary of region in ccw order to create all // the new facets Cell_handle bound = c; Vertex_handle v1 = c->vertex(i1); int ind = c->neighbor(li)->index(c); // to be able to find the // first cell that will be created Cell_handle cur; Cell_handle pnew = Cell_handle(); do { cur = bound; // turn around v2 until we reach the boundary of region while ( cur->neighbor(cw(i1))->tds_data().is_in_conflict() ) { // neighbor in conflict cur = cur->neighbor(cw(i1)); i1 = cur->index( v1 ); } cur->neighbor(cw(i1))->tds_data().clear(); // here cur has an edge on the boundary of region cnew = create_face( v, v1, cur->vertex( ccw(i1) ) ); set_adjacency(cnew, 0, cur->neighbor(cw(i1)), cur->neighbor(cw(i1))->index(cur)); cnew->set_neighbor(1, Cell_handle()); cnew->set_neighbor(2, pnew); // pnew is null at the first iteration v1->set_cell(cnew); //pnew->set_neighbor( cw(pnew->index(v1)), cnew ); if (pnew != Cell_handle()) { pnew->set_neighbor( 1, cnew );} bound = cur; i1 = ccw(i1); v1 = bound->vertex(i1); pnew = cnew; //} while ( ( bound != c ) || ( li != cw(i1) ) ); } while ( v1 != c->vertex(ccw(li)) ); // missing neighbors between the first and the last created cells cur = c->neighbor(li)->neighbor(ind); // first created cell set_adjacency(cnew, 1, cur, 2); return cnew; } template < class Vb, class Cb> std::istream& operator>>(std::istream& is, Triangulation_data_structure_3<Vb,Cb>& tds) // reads : // the dimension // the number of vertices // the number of cells // the cells by the indices of their vertices // the neighbors of each cell by their index in the preceding list of cells // when dimension < 3 : the same with faces of maximal dimension { typedef Triangulation_data_structure_3<Vb,Cb> Tds; typedef typename Tds::Vertex_handle Vertex_handle; typedef typename Tds::Cell_handle Cell_handle; tds.clear(); std::size_t n; int d; if(is_ascii(is)) is >> d >> n; else { read(is, n); read(is,d); } tds.set_dimension(d); if(n == 0) return is; std::map<std::size_t , Vertex_handle > V; // creation of the vertices for (std::size_t i=0; i < n; i++) { // is >> p; // V[i] = tds.create_vertex(); // V[i]->set_point(p); V[i] = tds.create_vertex(); } std::map< std::size_t, Cell_handle > C; std::size_t m; tds.read_cells(is, V, m, C); CGAL_triangulation_assertion( tds.is_valid() ); return is; } template < class Vb, class Cb> std::ostream& operator<<(std::ostream& os, const Triangulation_data_structure_3<Vb,Cb> &tds) // writes : // the dimension // the number of vertices // the number of cells // the cells by the indices of their vertices // the neighbors of each cell by their index in the preceding list of cells // when dimension < 3 : the same with faces of maximal dimension { typedef Triangulation_data_structure_3<Vb,Cb> Tds; typedef typename Tds::size_type size_type; typedef typename Tds::Vertex_handle Vertex_handle; typedef typename Tds::Vertex_iterator Vertex_iterator; std::map<Vertex_handle, size_type> V; // outputs dimension and number of vertices size_type n = tds.number_of_vertices(); if (is_ascii(os)) os << tds.dimension() << std::endl << n << std::endl; else { write(os,tds.dimension()); write(os,n); } if (n == 0) return os; // index the vertices size_type i = 0; for (Vertex_iterator it=tds.vertices_begin(); it != tds.vertices_end(); ++it) V[it] = i++; CGAL_triangulation_assertion( i == n ); tds.print_cells(os, V); return os; } template < class Vb, class Cb> bool Triangulation_data_structure_3<Vb,Cb>:: is_simplex( Cell_handle c ) const { switch(dimension()) { case 3 : return is_cell(c); case 2 : return is_facet(c, 3); case 1 : return is_edge(c, 0, 1); case 0 : return is_vertex(c->vertex(0)); case -1 : return c == cells().begin(); } return false; } template < class Vb, class Cb> bool Triangulation_data_structure_3<Vb,Cb>:: is_vertex(Vertex_handle v) const { return vertices().owns_dereferencable(v); } template < class Vb, class Cb> bool Triangulation_data_structure_3<Vb,Cb>:: is_edge(Vertex_handle u, Vertex_handle v, Cell_handle &c, int &i, int &j) const // returns false when dimension <1 or when indices wrong { CGAL_triangulation_expensive_precondition( is_vertex(u) && is_vertex(v) ); if (u==v) return false; std::vector<Cell_handle> cells; cells.reserve(64); incident_cells(u, std::back_inserter(cells)); for (typename std::vector<Cell_handle>::iterator cit = cells.begin(); cit != cells.end(); ++cit) if ((*cit)->has_vertex(v, j)) { c = *cit; i = c->index(u); return true; } return false; } template < class Vb, class Cb> bool Triangulation_data_structure_3<Vb,Cb>:: is_edge(Vertex_handle u, Vertex_handle v) const { Cell_handle c; int i, j; return is_edge(u, v, c, i, j); } template < class Vb, class Cb> bool Triangulation_data_structure_3<Vb,Cb>:: is_edge(Cell_handle c, int i, int j) const { if (dimension() < 1) return false; if ( i==j ) return false; if ( (i<0) || (j<0) ) return false; if ( (dimension() == 1) && ((i>1) || (j>1)) ) return false; if ( (dimension() == 2) && ((i>2) || (j>2)) ) return false; if ((i>3) || (j>3)) return false; return cells().owns_dereferencable(c); } template < class Vb, class Cb> bool Triangulation_data_structure_3<Vb,Cb>:: is_facet(Vertex_handle u, Vertex_handle v, Vertex_handle w, Cell_handle & c, int & i, int & j, int & k) const // returns false when dimension <2 or when indices wrong { CGAL_triangulation_expensive_precondition( is_vertex(u) && is_vertex(v) && is_vertex(w) ); if ( u==v || u==w || v==w ) return false; if (dimension() < 2) return false; std::vector<Cell_handle> cells; cells.reserve(64); incident_cells(u, std::back_inserter(cells)); for (typename std::vector<Cell_handle>::iterator cit = cells.begin(); cit != cells.end(); ++cit) if ((*cit)->has_vertex(v, j) && (*cit)->has_vertex(w, k)) { c = *cit; i = c->index(u); return true; } return false; } template < class Vb, class Cb> bool Triangulation_data_structure_3<Vb,Cb>:: is_facet(Cell_handle c, int i) const { CGAL_triangulation_precondition(i>=0 && i<4); if ( dimension() < 2 ) return false; if ( (dimension() == 2) && (i!=3) ) return false; return cells().owns_dereferencable(c); } template < class Vb, class Cb> bool Triangulation_data_structure_3<Vb,Cb>:: is_cell( Cell_handle c ) const // returns false when dimension <3 { if (dimension() < 3) return false; return cells().owns_dereferencable(c); } template < class Vb, class Cb> bool Triangulation_data_structure_3<Vb,Cb>:: is_cell(Vertex_handle u, Vertex_handle v, Vertex_handle w, Vertex_handle t, Cell_handle & c, int & i, int & j, int & k, int & l) const // returns false when dimension <3 { CGAL_triangulation_expensive_precondition( is_vertex(u) && is_vertex(v) && is_vertex(w) && is_vertex(t) ); if ( u==v || u==w || u==t || v==w || v==t || w==t ) return false; std::vector<Cell_handle> cells; cells.reserve(64); incident_cells(u, std::back_inserter(cells)); for (typename std::vector<Cell_handle>::iterator cit = cells.begin(); cit != cells.end(); ++cit) if ((*cit)->has_vertex(v, j) && (*cit)->has_vertex(w, k) && (*cit)->has_vertex(t, l)) { c = *cit; i = c->index(u); return true; } return false; } template < class Vb, class Cb> bool Triangulation_data_structure_3<Vb,Cb>:: is_cell(Vertex_handle u, Vertex_handle v, Vertex_handle w, Vertex_handle t) const // returns false when dimension <3 { Cell_handle c; int i, j, k, l; return is_cell(u, v, w, t, c, i, j, k, l); } template < class Vb, class Cb> inline bool Triangulation_data_structure_3<Vb,Cb>:: has_vertex(Cell_handle c, int i, Vertex_handle v, int & j) const // computes the index j of the vertex in the cell c giving the query // facet (c,i) // j has no meaning if false is returned { CGAL_triangulation_precondition( dimension() == 3 ); return ( c->has_vertex(v,j) && (j != i) ); } template < class Vb, class Cb> inline bool Triangulation_data_structure_3<Vb,Cb>:: has_vertex(Cell_handle c, int i, Vertex_handle v) const // checks whether the query facet (c,i) has vertex v { CGAL_triangulation_precondition( dimension() == 3 ); int j; return ( c->has_vertex(v,j) && (j != i) ); } template < class Vb, class Cb> inline bool Triangulation_data_structure_3<Vb,Cb>:: has_vertex(const Facet & f, Vertex_handle v, int & j) const { return has_vertex(f.first, f.second, v, j); } template < class Vb, class Cb> inline bool Triangulation_data_structure_3<Vb,Cb>:: has_vertex(const Facet & f, Vertex_handle v) const { return has_vertex(f.first, f.second, v); } template < class Vb, class Cb> bool Triangulation_data_structure_3<Vb,Cb>:: are_equal(Cell_handle c, int i, Cell_handle n, int j) const // tests whether facets c,i and n,j, have the same 3 vertices // the triangulation is supposed to be valid, the orientation of the // facets is not checked here // the neighbor relations between c and n are not tested either, // which allows to use this method before setting these relations // (see remove in Delaunay_3) // if ( c->neighbor(i) != n ) return false; // if ( n->neighbor(j) != c ) return false; { CGAL_triangulation_precondition( dimension() == 3 ); if ( (c==n) && (i==j) ) return true; int j1,j2,j3; return( n->has_vertex( c->vertex((i+1)&3), j1 ) && n->has_vertex( c->vertex((i+2)&3), j2 ) && n->has_vertex( c->vertex((i+3)&3), j3 ) && ( j1+j2+j3+j == 6 ) ); } template < class Vb, class Cb> bool Triangulation_data_structure_3<Vb,Cb>:: are_equal(const Facet & f, const Facet & g) const { return are_equal(f.first, f.second, g.first, g.second); } template < class Vb, class Cb> bool Triangulation_data_structure_3<Vb,Cb>:: are_equal(const Facet & f, Cell_handle n, int j) const { return are_equal(f.first, f.second, n, j); } template < class Vb, class Cb> bool Triangulation_data_structure_3<Vb,Cb>:: flip( Cell_handle c, int i ) // returns false if the facet is not flippable // true other wise and // flips facet i of cell c // c will be replaced by one of the new cells { CGAL_triangulation_precondition( (dimension() == 3) && (0<=i) && (i<4) && (number_of_vertices() >= 6) ); CGAL_triangulation_expensive_precondition( is_cell(c) ); Cell_handle n = c->neighbor(i); int in = n->index(c); // checks that the facet is flippable, // ie the future edge does not already exist if (is_edge(c->vertex(i), n->vertex(in))) return false; flip_really(c,i,n,in); return true; } template < class Vb, class Cb> void Triangulation_data_structure_3<Vb,Cb>:: flip_flippable(Cell_handle c, int i ) // flips facet i of cell c // c will be replaced by one of the new cells { CGAL_triangulation_precondition( (dimension() == 3) && (0<=i) && (i<4) && (number_of_vertices() >= 6) ); CGAL_triangulation_expensive_precondition( is_cell(c) ); Cell_handle n = c->neighbor(i); int in = n->index(c); // checks that the facet is flippable, // ie the future edge does not already exist CGAL_triangulation_expensive_precondition( !is_edge(c->vertex(i), n->vertex(in))); flip_really(c,i,n,in); } template < class Vb, class Cb> inline void Triangulation_data_structure_3<Vb,Cb>:: flip_really( Cell_handle c, int i, Cell_handle n, int in ) // private - used by flip and flip_flippable { int i1 = (i+1)&3; int i2 = (i+2)&3; int i3 = (i+3)&3; int in1 = n->index(c->vertex(i1)); int in2 = n->index(c->vertex(i2)); int in3 = n->index(c->vertex(i3)); set_adjacency(c, i, n->neighbor(in3), n->neighbor(in3)->index(n)); c->set_vertex( i3, n->vertex(in) ); set_adjacency(n, in, c->neighbor(i1), c->neighbor(i1)->index(c)); n->set_vertex( in1, c->vertex(i) ); Cell_handle cnew = create_cell(c->vertex(i), c->vertex(i1), n->vertex(in), n->vertex(in3)); set_adjacency(cnew, 0, n->neighbor(in2), n->neighbor(in2)->index(n)); set_adjacency(cnew, 1, n, in2); set_adjacency(cnew, 2, c->neighbor(i2), c->neighbor(i2)->index(c)); set_adjacency(cnew, 3, c, i2); set_adjacency(c, i1, n, in3); if ((i&1) != 0) change_orientation(cnew); c->vertex(i1)->set_cell(cnew); c->vertex(i2)->set_cell(c); n->vertex(in3)->set_cell(n); // to be implemented : 2d case // CGAL_triangulation_precondition( (0<=i) && (i<3) ); } template < class Vb, class Cb> bool Triangulation_data_structure_3<Vb,Cb>:: flip( Cell_handle c, int i, int j ) // returns false if the edge is not flippable // true otherwise and // flips edge i,j of cell c // c will be deleted { CGAL_triangulation_precondition( (dimension() == 3) && (0<=i) && (i<4) && (0<=j) && (j<4) && ( i != j ) && (number_of_vertices() >= 6) ); CGAL_triangulation_expensive_precondition( is_cell(c) ); // checks that the edge is flippable ie degree 3 int degree = 0; Cell_circulator ccir = incident_cells(c,i,j); Cell_circulator cdone = ccir; do { ++degree; ++ccir; } while ( ccir != cdone ); if ( degree != 3 ) return false; int next = next_around_edge(i,j); Cell_handle c1 = c->neighbor( next ); Vertex_handle v1 = c->vertex( next ); // will become vertex of c1 int i1 = c1->index( c->vertex(i) ); int j1 = c1->index( c->vertex(j) ); int next1 = next_around_edge(i1,j1); Cell_handle c2 = c1->neighbor( next1 ); Vertex_handle v2 = c1->vertex( next1 ); // will become vertex of c2 int i2 = c2->index( c->vertex(i) ); int j2 = c2->index( c->vertex(j) ); int next2 = next_around_edge(i2,j2); Vertex_handle v3 = c2->vertex( next2 ); // checks that the edge is flippable, // is the future cells do not already exist if ( is_cell(v1,v2,v3,c->vertex(i)) ) return false; if ( is_cell(v1,v2,v3,c->vertex(j)) ) return false; flip_really(c,i,j,c1,v1,i1,j1,next1,c2,v2,i2,j2,next2,v3); return true; } template < class Vb, class Cb> void Triangulation_data_structure_3<Vb,Cb>:: flip_flippable( Cell_handle c, int i, int j ) // flips edge i,j of cell c // c will be deleted { CGAL_triangulation_precondition( (dimension() == 3) && (0<=i) && (i<4) && (0<=j) && (j<4) && ( i != j ) && (number_of_vertices() >= 6) ); CGAL_triangulation_expensive_precondition( is_cell(c) ); // checks that the edge is flippable ie degree 3 CGAL_triangulation_precondition_code( int degree = 0; ); CGAL_triangulation_precondition_code ( Cell_circulator ccir = incident_cells(c,i,j); ); CGAL_triangulation_precondition_code( Cell_circulator cdone = ccir; ); CGAL_triangulation_precondition_code( do { ++degree; ++ccir; } while ( ccir != cdone ); ); CGAL_triangulation_precondition( degree == 3 ); int next = next_around_edge(i,j); Cell_handle c1 = c->neighbor( next ); Vertex_handle v1 = c->vertex( next ); // will become vertex of c1 int i1 = c1->index( c->vertex(i) ); int j1 = c1->index( c->vertex(j) ); int next1 = next_around_edge(i1,j1); Cell_handle c2 = c1->neighbor( next1 ); Vertex_handle v2 = c1->vertex( next1 ); // will become vertex of c2 int i2 = c2->index( c->vertex(i) ); int j2 = c2->index( c->vertex(j) ); int next2 = next_around_edge(i2,j2); Vertex_handle v3 = c2->vertex( next2 ); // checks that the edge is flippable, // is the future cells do not already exist CGAL_triangulation_expensive_precondition( !is_cell(v1,v2,v3,c->vertex(i)) ); CGAL_triangulation_expensive_precondition( !is_cell(v1,v2,v3,c->vertex(j)) ); flip_really(c,i,j,c1,v1,i1,j1,next1,c2,v2,i2,j2,next2,v3); } template < class Vb, class Cb> inline void Triangulation_data_structure_3<Vb,Cb>:: flip_really( Cell_handle c, int i, int j, Cell_handle c1, Vertex_handle v1, int i1, int j1, int next1, Cell_handle c2, Vertex_handle v2, int i2, int j2, int next2, Vertex_handle v3 ) { c->vertex(i)->set_cell(c1); c->vertex(j)->set_cell(c2); c1->set_vertex( j1, v1 ); v1->set_cell(c1); c2->set_vertex( i2, v2 ); v2->set_cell(c2); set_adjacency(c1, next1,c2->neighbor(j2), c2->neighbor(j2)->index(c2)); set_adjacency(c2,c2->index(v1),c1->neighbor(i1),c1->neighbor(i1)->index(c1)); set_adjacency(c1, i1, c2, j2); set_adjacency(c1, 6-i1-j1-next1, c->neighbor(j), c->neighbor(j)->index(c)); set_adjacency(c2, next2, c->neighbor(i), c->neighbor(i)->index(c)); v3->set_cell( c2 ); delete_cell( c ); } template < class Vb, class Cb > void Triangulation_data_structure_3<Vb,Cb>:: read_cells(std::istream& is, std::map< std::size_t, Vertex_handle > &V, std::size_t & m, std::map< std::size_t, Cell_handle > &C) { // creation of the cells and neighbors switch (dimension()) { case 3: case 2: case 1: { if(is_ascii(is)) is >> m; else read(is, m); for(std::size_t i = 0; i < m; i++) { Cell_handle c = create_cell(); for (int k=0; k<=dimension(); ++k) { std::size_t ik; if(is_ascii(is)) is >> ik; else read(is, ik); c->set_vertex(k, V[ik]); V[ik]->set_cell(c); } C[i] = c; } for(std::size_t j = 0; j < m; j++) { Cell_handle c = C[j]; for (int k=0; k<=dimension(); ++k) { std::size_t ik; if(is_ascii(is)) is >> ik; else read(is, ik); c->set_neighbor(k, C[ik]); } } break; } case 0: { m = 2; // CGAL_triangulation_assertion( n == 2 ); for (int i=0; i < 2; i++) { Cell_handle c = create_face(V[i], Vertex_handle(), Vertex_handle()); C[i] = c; V[i]->set_cell(c); } for (int j=0; j < 2; j++) { Cell_handle c = C[j]; c->set_neighbor(0, C[1-j]); } break; } case -1: { m = 1; // CGAL_triangulation_assertion( n == 1 ); Cell_handle c = create_face(V[0], Vertex_handle(), Vertex_handle()); C[0] = c; V[0]->set_cell(c); break; } } } template < class Vb, class Cb> void Triangulation_data_structure_3<Vb,Cb>:: print_cells(std::ostream& os, const std::map<Vertex_handle, std::size_t> &V ) const { std::map<Cell_handle, std::size_t > C; std::size_t i = 0; switch ( dimension() ) { case 3: { std::size_t m = number_of_cells(); if(is_ascii(os)) os << m << std::endl; else write(os, m); // write the cells Cell_iterator it; for(it = cells_begin(); it != cells_end(); ++it) { C[it] = i++; for(int j = 0; j < 4; j++){ if(is_ascii(os)) { os << V.find(it->vertex(j))->second; if ( j==3 ) os << std::endl; else os << ' '; } else write(os, V.find(it->vertex(j))->second); } } CGAL_triangulation_assertion( i == m ); // write the neighbors for(it = cells_begin(); it != cells_end(); ++it) { for (int j = 0; j < 4; j++) { if(is_ascii(os)){ os << C[it->neighbor(j)]; if(j==3) os << std::endl; else os << ' '; } else write(os, C[it->neighbor(j)]); } } break; } case 2: { size_type m = number_of_facets(); if(is_ascii(os)) os << m << std::endl; else write(os, m); // write the facets Facet_iterator it; for(it = facets_begin(); it != facets_end(); ++it) { C[(*it).first] = i++; for(int j = 0; j < 3; j++){ if(is_ascii(os)) { os << V.find((*it).first->vertex(j))->second; if ( j==2 ) os << std::endl; else os << ' '; } else { write(os, V.find((*it).first->vertex(j))->second); } } } CGAL_triangulation_assertion( i == m ); // write the neighbors for(it = facets_begin(); it != facets_end(); ++it) { for (int j = 0; j < 3; j++) { if(is_ascii(os)){ os << C[(*it).first->neighbor(j)]; if(j==2) os << std::endl; else os << ' '; } else { write(os, C[(*it).first->neighbor(j)]); } } } break; } case 1: { size_type m = number_of_edges(); if(is_ascii(os)) os << m << std::endl; else write(os, m); // write the edges Edge_iterator it; for(it = edges_begin(); it != edges_end(); ++it) { C[(*it).first] = i++; for(int j = 0; j < 2; j++){ if(is_ascii(os)) { os << V.find((*it).first->vertex(j))->second; if ( j==1 ) os << std::endl; else os << ' '; } else { write(os, V.find((*it).first->vertex(j))->second); } } } CGAL_triangulation_assertion( i == m ); // write the neighbors for(it = edges_begin(); it != edges_end(); ++it) { for (int j = 0; j < 2; j++) { if(is_ascii(os)){ os << C[(*it).first->neighbor(j)]; if(j==1) os << std::endl; else os << ' '; } else { write(os, C[(*it).first->neighbor(j)]); } } } break; } } } template <class Vb, class Cb > typename Triangulation_data_structure_3<Vb,Cb>::Vertex_handle Triangulation_data_structure_3<Vb,Cb>:: insert_in_cell(Cell_handle c) { CGAL_triangulation_precondition( dimension() == 3 ); CGAL_triangulation_precondition( c != Cell_handle() ); CGAL_triangulation_expensive_precondition( is_cell(c) ); Vertex_handle v = create_vertex(); Vertex_handle v0 = c->vertex(0); Vertex_handle v1 = c->vertex(1); Vertex_handle v2 = c->vertex(2); Vertex_handle v3 = c->vertex(3); Cell_handle n1 = c->neighbor(1); Cell_handle n2 = c->neighbor(2); Cell_handle n3 = c->neighbor(3); // c will be modified to have v,v1,v2,v3 as vertices Cell_handle c3 = create_cell(v0,v1,v2,v); Cell_handle c2 = create_cell(v0,v1,v,v3); Cell_handle c1 = create_cell(v0,v,v2,v3); set_adjacency(c3, 0, c, 3); set_adjacency(c2, 0, c, 2); set_adjacency(c1, 0, c, 1); set_adjacency(c2, 3, c3, 2); set_adjacency(c1, 3, c3, 1); set_adjacency(c1, 2, c2, 1); set_adjacency(n1, n1->index(c), c1, 1); set_adjacency(n2, n2->index(c), c2, 2); set_adjacency(n3, n3->index(c), c3, 3); c->set_vertex(0,v); v0->set_cell(c1); v->set_cell(c); return v; } template <class Vb, class Cb > typename Triangulation_data_structure_3<Vb,Cb>::Vertex_handle Triangulation_data_structure_3<Vb,Cb>:: insert_in_facet(Cell_handle c, int i) { // inserts v in the facet opposite to vertex i of cell c CGAL_triangulation_precondition( c != Cell_handle() ); CGAL_triangulation_precondition( dimension() >= 2 ); Vertex_handle v = create_vertex(); switch ( dimension() ) { case 3: { CGAL_triangulation_expensive_precondition( is_cell(c) ); CGAL_triangulation_precondition( i == 0 || i == 1 || i == 2 || i == 3 ); // c will be modified to have v replacing vertex(i+3) int i1,i2,i3; if ( (i&1) == 0 ) { i1=(i+1)&3; i2=(i+2)&3; i3=6-i-i1-i2; } else { i1=(i+1)&3; i2=(i+3)&3; i3=6-i-i1-i2; } // i,i1,i2,i3 is well oriented // so v will "replace" the vertices in this order // when creating the new cells one after another from c Vertex_handle vi=c->vertex(i); Vertex_handle v1=c->vertex(i1); Vertex_handle v2=c->vertex(i2); Vertex_handle v3=c->vertex(i3); // new cell with v in place of i1 Cell_handle nc = c->neighbor(i1); Cell_handle cnew1 = create_cell(vi,v,v2,v3); set_adjacency(cnew1, 1, nc, nc->index(c)); set_adjacency(cnew1, 3, c, i1); v3->set_cell(cnew1); // new cell with v in place of i2 nc = c->neighbor(i2); Cell_handle cnew2 = create_cell(vi,v1,v,v3); set_adjacency(cnew2, 2, nc, nc->index(c)); set_adjacency(cnew2, 3, c, i2); set_adjacency(cnew1, 2, cnew2, 1); // v replaces i3 in c c->set_vertex(i3,v); // other side of facet containing v Cell_handle d = c->neighbor(i); int j = d->index(c); int j1=d->index(v1);// triangulation supposed to be valid int j2=d->index(v2); int j3=6-j-j1-j2; // then the orientation of j,j1,j2,j3 depends on the parity // of i-j // new cell with v in place of j1 Cell_handle nd = d->neighbor(j1); Cell_handle dnew1 = create_cell(d->vertex(j),v,v3,v2); set_adjacency(dnew1, 1, nd, nd->index(d)); set_adjacency(dnew1, 2, d, j1); set_adjacency(dnew1, 0, cnew1, 0); // new cell with v in place of j2 nd = d->neighbor(j2); Cell_handle dnew2 = create_cell(d->vertex(j),v1,v3,v); set_adjacency(dnew2, 3, nd, nd->index(d)); set_adjacency(dnew2, 2, d, j2); set_adjacency(dnew2, 0, cnew2, 0); set_adjacency(dnew1, 3, dnew2, 1); // v replaces i3 in d d->set_vertex(j3,v); v->set_cell(d); break; } case 2: { CGAL_triangulation_expensive_precondition( is_facet(c,i) ); Cell_handle n = c->neighbor(2); Cell_handle cnew = create_face(c->vertex(0),c->vertex(1),v); set_adjacency(cnew, 2, n, n->index(c)); set_adjacency(cnew, 0, c, 2); c->vertex(0)->set_cell(cnew); n = c->neighbor(1); Cell_handle dnew = create_face(c->vertex(0),v,c->vertex(2)); set_adjacency(dnew, 1, n, n->index(c)); set_adjacency(dnew, 0, c, 1); set_adjacency(dnew, 2, cnew, 1); c->set_vertex(0,v); v->set_cell(c); break; } } return v; } template <class Vb, class Cb > typename Triangulation_data_structure_3<Vb,Cb>::Vertex_handle Triangulation_data_structure_3<Vb,Cb>:: insert_in_edge(Cell_handle c, int i, int j) // inserts a vertex in the edge of cell c with vertices i and j { CGAL_triangulation_precondition( c != Cell_handle() ); CGAL_triangulation_precondition( i != j ); CGAL_triangulation_precondition( dimension() >= 1 ); switch ( dimension() ) { case 3: { CGAL_triangulation_expensive_precondition( is_cell(c) ); CGAL_triangulation_precondition( i>=0 && i<=3 && j>=0 && j<=3 ); std::vector<Cell_handle > cells; cells.reserve(32); Cell_circulator ccir = incident_cells(c, i, j); do { Cell_handle cc = ccir; cells.push_back(cc); cc->tds_data().mark_in_conflict(); ++ccir; } while (c != ccir); return _insert_in_hole(cells.begin(), cells.end(), c, i); } case 2: { CGAL_triangulation_expensive_precondition( is_edge(c,i,j) ); Vertex_handle v = create_vertex(); int k=3-i-j; // index of the third vertex of the facet Cell_handle d = c->neighbor(k); int kd = d->index(c); int id = d->index(c->vertex(i)); int jd = d->index(c->vertex(j)); Cell_handle cnew = create_cell(); cnew->set_vertex(i,c->vertex(i)); c->vertex(i)->set_cell(cnew); cnew->set_vertex(j,v); cnew->set_vertex(k,c->vertex(k)); c->set_vertex(i,v); Cell_handle dnew = create_cell(); dnew->set_vertex(id,d->vertex(id)); // d->vertex(id)->cell() is cnew OK dnew->set_vertex(jd,v); dnew->set_vertex(kd,d->vertex(kd)); d->set_vertex(id,v); Cell_handle nj = c->neighbor(j); set_adjacency(cnew, i, c, j); set_adjacency(cnew, j, nj, nj->index(c)); nj = d->neighbor(jd); set_adjacency(dnew, id, d, jd); set_adjacency(dnew, jd, nj, nj->index(d)); set_adjacency(cnew, k, dnew, kd); v->set_cell(cnew); return v; } default: // case 1: { Vertex_handle v = create_vertex(); CGAL_triangulation_expensive_precondition( is_edge(c,i,j) ); Cell_handle cnew = create_face(v, c->vertex(1), Vertex_handle()); c->vertex(1)->set_cell(cnew); c->set_vertex(1,v); set_adjacency(cnew, 0, c->neighbor(0), 1); set_adjacency(cnew, 1, c, 0); v->set_cell(cnew); return v; } } } template <class Vb, class Cb > typename Triangulation_data_structure_3<Vb,Cb>::Vertex_handle Triangulation_data_structure_3<Vb,Cb>:: insert_increase_dimension(Vertex_handle star) // star = vertex from which we triangulate the facet of the // incremented dimension // ( geometrically : star = infinite vertex ) // = NULL only used to insert the 1st vertex (dimension -2 to dimension -1) // changes the dimension { CGAL_triangulation_precondition( dimension() < 3); Vertex_handle v = create_vertex(); int dim = dimension(); if (dim != -2) { CGAL_triangulation_precondition( star != Vertex_handle() ); // In this case, this precondition is not relatively expensive. CGAL_triangulation_precondition( is_vertex(star) ); } // this is set now, so that it becomes allowed to reorient // new facets or cells by iterating on them (otherwise the // dimension is too small) set_dimension( dimension()+1 ); switch ( dim ) { case -2: // insertion of the first vertex // ( geometrically : infinite vertex ) { Cell_handle c = create_face(v, Vertex_handle(), Vertex_handle()); v->set_cell(c); break; } case -1: // insertion of the second vertex // ( geometrically : first finite vertex ) { Cell_handle d = create_face(v, Vertex_handle(), Vertex_handle()); v->set_cell(d); set_adjacency(d, 0, star->cell(), 0); break; } case 0: // insertion of the third vertex // ( geometrically : second finite vertex ) { Cell_handle c = star->cell(); Cell_handle d = c->neighbor(0); c->set_vertex(1,d->vertex(0)); d->set_vertex(1,v); d->set_neighbor(1,c); Cell_handle e = create_face( v, star, Vertex_handle() ); set_adjacency(e, 0, c, 1); set_adjacency(e, 1, d, 0); v->set_cell(d); break; } case 1: // general case : 4th vertex ( geometrically : 3rd finite vertex ) // degenerate cases geometrically : 1st non collinear vertex { Cell_handle c = star->cell(); int i = c->index(star); // i== 0 or 1 int j = (1-i); Cell_handle d = c->neighbor(j); c->set_vertex(2,v); Cell_handle e = c->neighbor(i); Cell_handle cnew = c; Cell_handle enew = Cell_handle(); while( e != d ){ enew = create_cell(); enew->set_vertex(i,e->vertex(j)); enew->set_vertex(j,e->vertex(i)); enew->set_vertex(2,star); set_adjacency(enew, i, cnew, j); // false at the first iteration of the loop where it should // be neighbor 2 // it is corrected after the loop set_adjacency(enew, 2, e, 2); // neighbor j will be set during next iteration of the loop e->set_vertex(2,v); e = e->neighbor(i); cnew = enew; } d->set_vertex(2,v); set_adjacency(enew, j, d, 2); // corrections for star->cell() : c = star->cell(); c->set_neighbor(2,c->neighbor(i)->neighbor(2)); c->set_neighbor(j,d); v->set_cell(d); break; } case 2: // general case : 5th vertex ( geometrically : 4th finite vertex ) // degenerate cases : geometrically 1st non coplanar vertex { // used to store the new cells, in order to be able to traverse only // them to find the missing neighbors. std::vector<Cell_handle > new_cells; new_cells.reserve(16); Cell_iterator it = cells_begin(); // allowed since the dimension has already been set to 3 v->set_cell(it); // ok since there is at least one ``cell'' for(; it != cells_end(); ++it) { // Here we must be careful since we create_cells in a loop controlled // by an iterator. So we first take care of the cells newly created // by the following test : if (it->neighbor(0) == Cell_handle()) continue; it->set_neighbor(3, Cell_handle()); it->set_vertex(3, v); if ( ! it->has_vertex(star) ) { Cell_handle cnew = create_cell( it->vertex(0), it->vertex(2), it->vertex(1), star); // The Intel compiler has a problem with passing "it" directly to // function "set_adjacency": the adjacency is not changed. Cell_handle ch_it = it; set_adjacency(cnew, 3, ch_it, 3); cnew->set_neighbor(0, Cell_handle()); new_cells.push_back(cnew); } } // traversal of the new cells only, to add missing neighbors for(typename std::vector<Cell_handle>::iterator ncit = new_cells.begin(); ncit != new_cells.end(); ++ncit) { Cell_handle n = (*ncit)->neighbor(3); // opposite to star for ( int i=0; i<3; i++ ) { int j; if ( i==0 ) j=0; else j=3-i; // vertex 1 and vertex 2 are always switched when // creating a new cell (see above) Cell_handle c = n->neighbor(i)->neighbor(3); if ( c != Cell_handle() ) { // i.e. star is not a vertex of n->neighbor(i) (*ncit)->set_neighbor(j, c); // opposite relation will be set when ncit arrives on c // this avoids to look for the correct index // and to test whether *ncit already has neighbor i } else { // star is a vertex of n->neighbor(i) set_adjacency(*ncit, j, n->neighbor(i), 3);//neighbor opposite to v } } } } }// end switch return v; } template <class Vb, class Cb > void Triangulation_data_structure_3<Vb,Cb>:: remove_decrease_dimension(Vertex_handle v, Vertex_handle w) { CGAL_triangulation_expensive_precondition( is_valid() ); CGAL_triangulation_precondition( dimension() >= -1 ); CGAL_triangulation_precondition( dimension() != 1 || number_of_vertices() == 3); CGAL_triangulation_precondition( number_of_vertices() > (size_type) dimension() + 1 ); CGAL_triangulation_precondition( degree(v) == number_of_vertices()-1 ); if (dimension() <= 0) { delete_cell(v->cell()); } else { // the cells incident to w are down graded one dimension // the other cells are deleted std::vector<Cell_handle> to_delete, to_downgrade; for (Cell_iterator ib = cells().begin(); ib != cells().end(); ++ib) { if ( ib->has_vertex(w) ) to_downgrade.push_back(ib); else to_delete.push_back(ib); } typename std::vector<Cell_handle>::iterator lfit=to_downgrade.begin(); for( ; lfit != to_downgrade.end(); ++lfit) { Cell_handle f = *lfit; int j = f->index(w); int k; if (f->has_vertex(v, k)) f->set_vertex(k, w); if (j != dimension()) { f->set_vertex(j, f->vertex(dimension())); f->set_neighbor(j, f->neighbor(dimension())); if (dimension() >= 1) change_orientation(f); } f->set_vertex(dimension(), Vertex_handle()); f->set_neighbor(dimension(), Cell_handle()); // Update vertex->cell() pointers. for (int i = 0; i < dimension(); ++i) f->vertex(i)->set_cell(f); } delete_cells(to_delete.begin(), to_delete.end()); } delete_vertex(v); set_dimension(dimension()-1); CGAL_triangulation_postcondition(is_valid()); } template <class Vb, class Cb > typename Triangulation_data_structure_3<Vb,Cb>::Cell_handle Triangulation_data_structure_3<Vb,Cb>:: remove_from_maximal_dimension_simplex(Vertex_handle v) { CGAL_triangulation_precondition(dimension() >= 1); CGAL_triangulation_precondition(degree(v) == (size_type) dimension() + 1); CGAL_triangulation_precondition(number_of_vertices() > (size_type) dimension() + 1); if (number_of_vertices() == (size_type) dimension() + 2) { remove_decrease_dimension(v); return Cell_handle(); } if (dimension() == 3) return remove_degree_4(v); if (dimension() == 2) return remove_degree_3(v); // dimension() == 1 return remove_degree_2(v); } template <class Vb, class Cb > typename Triangulation_data_structure_3<Vb,Cb>::Cell_handle Triangulation_data_structure_3<Vb,Cb>:: remove_degree_2(Vertex_handle v) { CGAL_triangulation_precondition(dimension() == 1); CGAL_triangulation_precondition(degree(v) == 2); CGAL_triangulation_precondition(number_of_vertices() >= 4); // Cells to be killed. Cell_handle c0, c1; // Indices of v in these cells. int i0, i1; c0 = v->cell(); i0 = c0->index(v); c1 = c0->neighbor(1-i0); i1 = c1->index(v); // New cell : we copy the content of c0, so we keep the orientation. Cell_handle newc = create_face(c0->vertex(0), c0->vertex(1), Vertex_handle()); newc->set_vertex(i0, c1->vertex(c1->index(c0))); set_adjacency(newc, i0, c0->neighbor(i0), mirror_index(c0, i0)); set_adjacency(newc, 1-i0, c1->neighbor(i1), mirror_index(c1, i1)); newc->vertex(0)->set_cell(newc); newc->vertex(1)->set_cell(newc); delete_cell(c0); delete_cell(c1); delete_vertex(v); return newc; } template <class Vb, class Cb > typename Triangulation_data_structure_3<Vb,Cb>::Cell_handle Triangulation_data_structure_3<Vb,Cb>:: remove_degree_3(Vertex_handle v) { CGAL_triangulation_precondition(dimension() == 2); CGAL_triangulation_precondition(degree(v) == 3); CGAL_triangulation_precondition(number_of_vertices() >= 5); // Cells to be killed. Cell_handle c0, c1, c2; // Indices of v in these cells. int i0, i1, i2; c0 = v->cell(); i0 = c0->index(v); c1 = c0->neighbor(cw(i0)); i1 = c1->index(v); c2 = c0->neighbor(ccw(i0)); i2 = c2->index(v); // New cell : we copy the content of c0, so we keep the orientation. Cell_handle newc = create_face(c0->vertex(0), c0->vertex(1), c0->vertex(2)); newc->set_vertex(i0, c1->vertex(c1->index(c0))); set_adjacency(newc, i0, c0->neighbor(i0), mirror_index(c0, i0)); set_adjacency(newc, cw(i0), c1->neighbor(i1), mirror_index(c1, i1)); set_adjacency(newc, ccw(i0), c2->neighbor(i2), mirror_index(c2, i2)); newc->vertex(0)->set_cell(newc); newc->vertex(1)->set_cell(newc); newc->vertex(2)->set_cell(newc); delete_cell(c0); delete_cell(c1); delete_cell(c2); delete_vertex(v); return newc; } template <class Vb, class Cb > typename Triangulation_data_structure_3<Vb,Cb>::Cell_handle Triangulation_data_structure_3<Vb,Cb>:: remove_degree_4(Vertex_handle v) { CGAL_triangulation_precondition(dimension() == 3); CGAL_triangulation_precondition(degree(v) == 4); CGAL_triangulation_precondition(number_of_vertices() >= 6); // Cells to be killed. Cell_handle c0, c1, c2, c3; // Indices of v in these cells. int i0, i1, i2, i3; c0 = v->cell(); i0 = c0->index(v); c1 = c0->neighbor(i0^1); i1 = c1->index(v); c2 = c0->neighbor(i0^2); i2 = c2->index(v); c3 = c0->neighbor(i0^3); i3 = c3->index(v); // New cell : we copy the content of c0, so we keep the orientation. Cell_handle newc = create_cell(c0->vertex(0), c0->vertex(1), c0->vertex(2), c0->vertex(3)); newc->set_vertex(i0, c1->vertex(c1->index(c0))); set_adjacency(newc, i0, c0->neighbor(i0), mirror_index(c0, i0)); set_adjacency(newc, i0^1, c1->neighbor(i1), mirror_index(c1, i1)); set_adjacency(newc, i0^2, c2->neighbor(i2), mirror_index(c2, i2)); set_adjacency(newc, i0^3, c3->neighbor(i3), mirror_index(c3, i3)); newc->vertex(0)->set_cell(newc); newc->vertex(1)->set_cell(newc); newc->vertex(2)->set_cell(newc); newc->vertex(3)->set_cell(newc); delete_cell(c0); delete_cell(c1); delete_cell(c2); delete_cell(c3); delete_vertex(v); return newc; } template <class Vb, class Cb > void Triangulation_data_structure_3<Vb,Cb>:: decrease_dimension(Cell_handle c, int i) { CGAL_triangulation_expensive_precondition( is_valid() );; CGAL_triangulation_precondition( dimension() >= 2); CGAL_triangulation_precondition( number_of_vertices() > (size_type) dimension() + 1 ); CGAL_triangulation_precondition( degree(c->vertex(i)) == number_of_vertices()-1 ); Vertex_handle v = c->vertex(i); Vertex_handle w = c->vertex(i); // the cells incident to w are down graded one dimension // the other cells are deleted std::vector<Cell_handle> to_delete, to_downgrade; for (Cell_iterator ib = cells().begin(); ib != cells().end(); ++ib) { if ( ib->has_vertex(w) ) to_downgrade.push_back(ib); else to_delete.push_back(ib); } typename std::vector<Cell_handle>::iterator lfit=to_downgrade.begin(); for( ; lfit != to_downgrade.end(); ++lfit) { Cell_handle f = *lfit; int j = f->index(w); int k; if (f->has_vertex(v, k)) f->set_vertex(k, w); if (j != dimension()) { f->set_vertex(j, f->vertex(dimension())); f->set_neighbor(j, f->neighbor(dimension())); if (dimension() >= 1) change_orientation(f); } f->set_vertex(dimension(), Vertex_handle()); f->set_neighbor(dimension(), Cell_handle()); // Update vertex->cell() pointers. for (int i = 0; i < dimension(); ++i) f->vertex(i)->set_cell(f); } delete_cells(to_delete.begin(), to_delete.end()); //delete_vertex(v); set_dimension(dimension()-1); if(dimension() == 2) { Cell_handle n0 = c->neighbor(0); Cell_handle n1 = c->neighbor(1); Cell_handle n2 = c->neighbor(2); Vertex_handle v0 = c->vertex(0); Vertex_handle v1 = c->vertex(1); Vertex_handle v2 = c->vertex(2); int i0 = 0, i1 = 0, i2 = 0; for(int i=0; i<3; i++) if(n0->neighbor(i) == c) { i0 = i; break; } for(int i=0; i<3; i++) if(n1->neighbor(i) == c) { i1 = i; break; } for(int i=0; i<3; i++) if(n2->neighbor(i) == c) { i2 = i; break; } Cell_handle c1 = create_cell(v, v0, v1, Vertex_handle()); Cell_handle c2 = create_cell(v, v1, v2, Vertex_handle()); c->set_vertex(0, v); c->set_vertex(1, v2); c->set_vertex(2, v0); c->set_vertex(3, Vertex_handle()); //Cell_handle c3 = create_cell(v, v2, v0, Vertex_handle()); Cell_handle c3 = c; c1->set_neighbor(0, n2); n2->set_neighbor(i2, c1); c1->set_neighbor(1, c2); c1->set_neighbor(2, c3); c1->set_neighbor(3, Cell_handle()); c2->set_neighbor(0, n0); n0->set_neighbor(i0, c2); c2->set_neighbor(1, c3); c2->set_neighbor(2, c1); c2->set_neighbor(3, Cell_handle()); c3->set_neighbor(0, n1); n1->set_neighbor(i1, c3); c3->set_neighbor(1, c1); c3->set_neighbor(2, c2); c3->set_neighbor(3, Cell_handle()); v->set_cell(c1); v0->set_cell(c1); v1->set_cell(c1); v2->set_cell(c2); } if(dimension() == 1) { Cell_handle n0 = c->neighbor(0); Cell_handle n1 = c->neighbor(1); Vertex_handle v0 = c->vertex(0); Vertex_handle v1 = c->vertex(1); int i0 = 0 , i1 = 0; for(int i=0; i<2; i++) if(n0->neighbor(i) == c) { i0 = i; break; } for(int i=0; i<2; i++) if(n1->neighbor(i) == c) { i1 = i; break; } Cell_handle c1 = create_cell(v0, v, Vertex_handle(), Vertex_handle()); c->set_vertex(0, v); c->set_vertex(1, v1); c->set_vertex(2, Vertex_handle()); c->set_vertex(3, Vertex_handle()); //Cell_handle c2 = create_cell(v, v1, Vertex_handle(), Vertex_handle()); Cell_handle c2 = c; c1->set_neighbor(0, c2); c1->set_neighbor(1, n1); n1->set_neighbor(i1, c1); c1->set_neighbor(2, Cell_handle()); c1->set_neighbor(3, Cell_handle()); c2->set_neighbor(0, n0); n0->set_neighbor(i0, c2); c2->set_neighbor(1, c1); c2->set_neighbor(2, Cell_handle()); c2->set_neighbor(3, Cell_handle()); v->set_cell(c1); v0->set_cell(c1); v1->set_cell(c2); } CGAL_triangulation_postcondition(is_valid()); } template <class Vb, class Cb > typename Triangulation_data_structure_3<Vb,Cb>::size_type Triangulation_data_structure_3<Vb,Cb>:: degree(Vertex_handle v) const { std::size_t res; adjacent_vertices(v, Counting_output_iterator(&res)); return res; } template <class Vb, class Cb > bool Triangulation_data_structure_3<Vb,Cb>:: is_valid(bool verbose, int level ) const { switch ( dimension() ) { case 3: { if(number_of_vertices() <= 4) { if (verbose) std::cerr << "wrong number of vertices" << std::endl; CGAL_triangulation_assertion(false); return false; } size_type vertex_count; if ( ! count_vertices(vertex_count,verbose,level) ) return false; if ( number_of_vertices() != vertex_count ) { if (verbose) std::cerr << "wrong number of vertices" << std::endl; CGAL_triangulation_assertion(false); return false; } size_type cell_count; if ( ! count_cells(cell_count,verbose,level) ) return false; size_type edge_count; if ( ! count_edges(edge_count,verbose,level) ) return false; size_type facet_count; if ( ! count_facets(facet_count,verbose,level) ) return false; // Euler relation if ( cell_count - facet_count + edge_count - vertex_count != 0 ) { if (verbose) std::cerr << "Euler relation unsatisfied" << std::endl; CGAL_triangulation_assertion(false); return false; } break; } case 2: { if(number_of_vertices() <= 3) { if (verbose) std::cerr << "wrong number of vertices" << std::endl; CGAL_triangulation_assertion(false); return false; } size_type vertex_count; if ( ! count_vertices(vertex_count,verbose,level) ) return false; if ( number_of_vertices() != vertex_count ) { if (verbose) std::cerr << "false number of vertices" << std::endl; CGAL_triangulation_assertion(false); return false; } size_type edge_count; if ( ! count_edges(edge_count,verbose,level) ) return false; // Euler for edges if ( edge_count != 3 * vertex_count - 6 ) { if (verbose) std::cerr << "Euler relation unsatisfied - edges/vertices" << std::endl; CGAL_triangulation_assertion(false); return false; } size_type facet_count; if ( ! count_facets(facet_count,verbose,level) ) return false; // Euler for facets if ( facet_count != 2 * vertex_count - 4 ) { if (verbose) std::cerr << "Euler relation unsatisfied - facets/vertices" << std::endl; CGAL_triangulation_assertion(false); return false; } break; } case 1: { if(number_of_vertices() <= 1) { if (verbose) std::cerr << "wrong number of vertices" << std::endl; CGAL_triangulation_assertion(false); return false; } size_type vertex_count; if ( ! count_vertices(vertex_count,verbose,level) ) return false; if ( number_of_vertices() != vertex_count ) { if (verbose) std::cerr << "false number of vertices" << std::endl; CGAL_triangulation_assertion(false); return false; } size_type edge_count; if ( ! count_edges(edge_count,verbose,level) ) return false; // Euler for edges if ( edge_count != vertex_count ) { if (verbose) std::cerr << "false number of edges" << std::endl; CGAL_triangulation_assertion(false); return false; } break; } case 0: { if ( number_of_vertices() < 2 ) { if (verbose) std::cerr << "less than 2 vertices but dimension 0" << std::endl; CGAL_triangulation_assertion(false); return false; } // no break; continue } case -1: { if ( number_of_vertices() < 1 ) { if (verbose) std::cerr << "no vertex but dimension -1" << std::endl; CGAL_triangulation_assertion(false); return false; } // vertex count size_type vertex_count; if ( ! count_vertices(vertex_count,verbose,level) ) return false; if ( number_of_vertices() != vertex_count ) { if (verbose) std::cerr << "false number of vertices" << std::endl; CGAL_triangulation_assertion(false); return false; } } } // end switch if (verbose) std::cerr << "valid data structure" << std::endl; return true; } template <class Vb, class Cb > bool Triangulation_data_structure_3<Vb,Cb>:: is_valid(Vertex_handle v, bool verbose, int level) const { bool result = v->is_valid(verbose,level); result = result && v->cell()->has_vertex(v); if ( ! result ) { if ( verbose ) std::cerr << "invalid vertex" << std::endl; CGAL_triangulation_assertion(false); } return result; } template <class Vb, class Cb > bool Triangulation_data_structure_3<Vb,Cb>:: is_valid(Cell_handle c, bool verbose, int level) const { if ( ! c->is_valid(verbose, level) ) return false; switch (dimension()) { case -2: case -1: { if ( c->vertex(0) == Vertex_handle() ) { if (verbose) std::cerr << "vertex 0 NULL" << std::endl; CGAL_triangulation_assertion(false); return false; } is_valid(c->vertex(0),verbose,level); if ( c->vertex(1) != Vertex_handle() || c->vertex(2) != Vertex_handle()) { if (verbose) std::cerr << "vertex 1 or 2 != NULL" << std::endl; CGAL_triangulation_assertion(false); return false; } if ( c->neighbor(0) != Cell_handle() || c->neighbor(1) != Cell_handle() || c->neighbor(2) != Cell_handle()) { if (verbose) std::cerr << "one neighbor != NULL" << std::endl; CGAL_triangulation_assertion(false); return false; } break; } case 0: { if ( c->vertex(0) == Vertex_handle() ) { if (verbose) std::cerr << "vertex 0 NULL" << std::endl; CGAL_triangulation_assertion(false); return false; } is_valid(c->vertex(0),verbose,level); if ( c->neighbor (0) == Cell_handle() ) { if (verbose) std::cerr << "neighbor 0 NULL" << std::endl; CGAL_triangulation_assertion(false); return false; } if ( c->vertex(1) != Vertex_handle() || c->vertex(2) != Vertex_handle() ) { if (verbose) std::cerr << "vertex 1 or 2 != NULL" << std::endl; CGAL_triangulation_assertion(false); return false; } if ( c->neighbor(1) != Cell_handle() || c->neighbor(2) != Cell_handle() ) { if (verbose) std::cerr << "neighbor 1 or 2 != NULL" << std::endl; CGAL_triangulation_assertion(false); return false; } if ( ! c->neighbor(0)->has_vertex(c->vertex(0)) ) { if (verbose) std::cerr << "neighbor 0 does not have vertex 0" << std::endl; CGAL_triangulation_assertion(false); return false; } break; } case 1: { Vertex_handle v0 = c->vertex(0); Vertex_handle v1 = c->vertex(1); Cell_handle n0 = c->neighbor(0); Cell_handle n1 = c->neighbor(1); if ( v0 == Vertex_handle() || v1 == Vertex_handle() ) { if (verbose) std::cerr << "vertex 0 or 1 NULL" << std::endl; CGAL_triangulation_assertion(false); return false; } is_valid(c->vertex(0),verbose,level); is_valid(c->vertex(1),verbose,level); if ( n0 == Cell_handle() || n1 == Cell_handle() ) { if (verbose) std::cerr << "neighbor 0 or 1 NULL" << std::endl; CGAL_triangulation_assertion(false); return false; } if ( v0 != n1->vertex(1) ) { if (verbose) std::cerr << "neighbor 1 does not have vertex 0 as vertex 1" << std::endl; CGAL_triangulation_assertion(false); return false; } if ( v1 != n0->vertex(0) ) { if (verbose) std::cerr << "neighbor 0 does not have vertex 1 as vertex 0" << std::endl; CGAL_triangulation_assertion(false); return false; } if ( n0->neighbor(1) != c ) { if (verbose) std::cerr << "neighbor 0 does not have this as neighbor 1" << std::endl; CGAL_triangulation_assertion(false); return false; } if ( n1->neighbor(0) != c ) { if (verbose) std::cerr << "neighbor 1 does not have this as neighbor 0" << std::endl; CGAL_triangulation_assertion(false); return false; } break; } case 2: { if ( c->vertex(0) == Vertex_handle() || c->vertex(1) == Vertex_handle() || c->vertex(2) == Vertex_handle() ) { if (verbose) std::cerr << "vertex 0, 1, or 2 NULL" << std::endl; CGAL_triangulation_assertion(false); return false; } is_valid(c->vertex(0),verbose,level); is_valid(c->vertex(1),verbose,level); is_valid(c->vertex(2),verbose,level); int in; Cell_handle n; for(int i = 0; i < 3; i++) { n = c->neighbor(i); if ( n == Cell_handle() ) { if (verbose) std::cerr << "neighbor " << i << " NULL" << std::endl; CGAL_triangulation_assertion(false); return false; } if ( ! n->has_vertex(c->vertex(cw(i)),in ) ) { if (verbose) std::cerr << "vertex " << cw(i) << " not vertex of neighbor " << i << std::endl; CGAL_triangulation_assertion(false); return false; } in = cw(in); if ( n->neighbor(in) != c ) { if (verbose) std::cerr << "neighbor " << i << " does not have this as neighbor " << in << std::endl; CGAL_triangulation_assertion(false); return false; } if ( c->vertex(ccw(i)) != n->vertex(cw(in)) ) { if (verbose) std::cerr << "vertex " << ccw(i) << " is not vertex " << cw(in) << " of neighbor " << i << std::endl; CGAL_triangulation_assertion(false); return false; } } break; } case 3: { int i; for(i = 0; i < 4; i++) { if ( c->vertex(i) == Vertex_handle() ) { if (verbose) std::cerr << "vertex " << i << " NULL" << std::endl; CGAL_triangulation_assertion(false); return false; } is_valid(c->vertex(i),verbose,level); } for(i = 0; i < 4; i++) { Cell_handle n = c->neighbor(i); if ( n == Cell_handle() ) { if (verbose) std::cerr << "neighbor " << i << " NULL" << std::endl; CGAL_triangulation_assertion(false); return false; } int in = 5; // if ( ! n->has_neighbor(handle(), in) ) { if ( n->neighbor(0) == c) in = 0; if ( n->neighbor(1) == c) in = 1; if ( n->neighbor(2) == c) in = 2; if ( n->neighbor(3) == c) in = 3; if (in == 5) { if (verbose) std::cerr << "neighbor of c has not c as neighbor" << std::endl; CGAL_triangulation_assertion(false); return false; } int j1n,j2n,j3n; if ( ! n->has_vertex(c->vertex((i+1)&3),j1n) ) { if (verbose) { std::cerr << "vertex " << ((i+1)&3) << " not vertex of neighbor " << i << std::endl; } CGAL_triangulation_assertion(false); return false; } if ( ! n->has_vertex(c->vertex((i+2)&3),j2n) ) { if (verbose) { std::cerr << "vertex " << ((i+2)&3) << " not vertex of neighbor " << i << std::endl; } CGAL_triangulation_assertion(false); return false; } if ( ! n->has_vertex(c->vertex((i+3)&3),j3n) ) { if (verbose) { std::cerr << "vertex " << ((i+3)&3) << " not vertex of neighbor " << i << std::endl; } CGAL_triangulation_assertion(false); return false; } if ( in+j1n+j2n+j3n != 6) { if (verbose) { std::cerr << "sum of the indices != 6 " << std::endl; } CGAL_triangulation_assertion(false); return false; } // tests whether the orientations of this and n are consistent if ( ((i+in)&1) == 0 ) { // i and in have the same parity if ( j1n == ((in+1)&3) ) { if ( ( j2n != ((in+3)&3) ) || ( j3n != ((in+2)&3) ) ) { if (verbose) std::cerr << " pb orientation with neighbor " << i << std::endl; CGAL_triangulation_assertion(false); return false; } } if ( j1n == ((in+2)&3) ) { if ( ( j2n != ((in+1)&3) ) || ( j3n != ((in+3)&3) ) ) { if (verbose) std::cerr << " pb orientation with neighbor " << i << std::endl; CGAL_triangulation_assertion(false); return false; } } if ( j1n == ((in+3)&3) ) { if ( ( j2n != ((in+2)&3) ) || ( j3n != ((in+1)&3) ) ) { if (verbose) std::cerr << " pb orientation with neighbor " << i << std::endl; CGAL_triangulation_assertion(false); return false; } } } else { // i and in do not have the same parity if ( j1n == ((in+1)&3) ) { if ( ( j2n != ((in+2)&3) ) || ( j3n != ((in+3)&3) ) ) { if (verbose) std::cerr << " pb orientation with neighbor " << i << std::endl; CGAL_triangulation_assertion(false); return false; } } if ( j1n == ((in+2)&3) ) { if ( ( j2n != ((in+3)&3) ) || ( j3n != ((in+1)&3) ) ) { if (verbose) std::cerr << " pb orientation with neighbor " << i << std::endl; CGAL_triangulation_assertion(false); return false; } } if ( j1n == ((in+3)&3) ) { if ( ( j2n != ((in+1)&3) ) || ( j3n != ((in+2)&3) ) ) { if (verbose) std::cerr << " pb orientation with neighbor " << i << std::endl; CGAL_triangulation_assertion(false); return false; } } } } // end looking at neighbors }// end case dim 3 } // end switch return true; } template <class Vb, class Cb > typename Triangulation_data_structure_3<Vb,Cb>::Vertex_handle Triangulation_data_structure_3<Vb,Cb>:: copy_tds(const Tds & tds, Vertex_handle vert ) // returns the new vertex corresponding to vert in the new tds { CGAL_triangulation_expensive_precondition( vert == Vertex_handle() || tds.is_vertex(vert) ); clear(); size_type n = tds.number_of_vertices(); set_dimension(tds.dimension()); // Number of pointers to cell/vertex to copy per cell. int dim = (std::max)(1, dimension() + 1); if (n == 0) return vert; // Create the vertices. std::vector<Vertex_handle> TV(n); size_type i = 0; for (Vertex_iterator vit = tds.vertices_begin(); vit != tds.vertices_end(); ++vit) TV[i++] = vit; CGAL_triangulation_assertion( i == n ); std::map< Vertex_handle, Vertex_handle > V; std::map< Cell_handle, Cell_handle > F; for (size_type i=0; i <= n-1; ++i) V[ TV[i] ] = create_vertex(TV[i]); // Create the cells. for (Cell_iterator cit = tds.cells().begin(); cit != tds.cells_end(); ++cit) { F[cit] = create_cell(cit); for (int j = 0; j < dim; j++) F[cit]->set_vertex(j, V[cit->vertex(j)] ); } // Link the vertices to a cell. for (Vertex_iterator vit2 = tds.vertices_begin(); vit2 != tds.vertices_end(); ++vit2) V[vit2]->set_cell( F[vit2->cell()] ); // Hook neighbor pointers of the cells. for (Cell_iterator cit2 = tds.cells().begin(); cit2 != tds.cells_end(); ++cit2) { for (int j = 0; j < dim; j++) F[cit2]->set_neighbor(j, F[cit2->neighbor(j)] ); } CGAL_triangulation_postcondition( is_valid() ); return (vert != Vertex_handle()) ? V[vert] : vert; } template <class Vb, class Cb > void Triangulation_data_structure_3<Vb,Cb>:: swap(Tds & tds) { CGAL_triangulation_expensive_precondition(tds.is_valid() && is_valid()); std::swap(_dimension, tds._dimension); cells().swap(tds.cells()); vertices().swap(tds.vertices()); } template <class Vb, class Cb > void Triangulation_data_structure_3<Vb,Cb>:: clear() { cells().clear(); vertices().clear(); set_dimension(-2); } template <class Vb, class Cb > bool Triangulation_data_structure_3<Vb,Cb>:: count_vertices(size_type & i, bool verbose, int level) const // counts AND checks the validity { i = 0; for (Vertex_iterator it = vertices_begin(); it != vertices_end(); ++it) { if ( ! is_valid(it,verbose,level) ) { if (verbose) std::cerr << "invalid vertex" << std::endl; CGAL_triangulation_assertion(false); return false; } ++i; } return true; } template <class Vb, class Cb > bool Triangulation_data_structure_3<Vb,Cb>:: count_facets(size_type & i, bool verbose, int level) const // counts but does not check { i = 0; for (Facet_iterator it = facets_begin(); it != facets_end(); ++it) { if ( ! is_valid((*it).first,verbose, level) ) { if (verbose) std::cerr << "invalid facet" << std::endl; CGAL_triangulation_assertion(false); return false; } ++i; } return true; } template <class Vb, class Cb > bool Triangulation_data_structure_3<Vb,Cb>:: count_edges(size_type & i, bool verbose, int level) const // counts but does not check { i = 0; for (Edge_iterator it = edges_begin(); it != edges_end(); ++it) { if ( ! is_valid((*it).first,verbose, level) ) { if (verbose) std::cerr << "invalid edge" << std::endl; CGAL_triangulation_assertion(false); return false; } ++i; } return true; } template <class Vb, class Cb > bool Triangulation_data_structure_3<Vb,Cb>:: count_cells(size_type & i, bool verbose, int level) const // counts AND checks the validity { i = 0; for (Cell_iterator it = cells_begin(); it != cells_end(); ++it) { if ( ! is_valid(it,verbose, level) ) { if (verbose) std::cerr << "invalid cell" << std::endl; CGAL_triangulation_assertion(false); return false; } ++i; } return true; } } //namespace CGAL #endif // CGAL_TRIANGULATION_DATA_STRUCTURE_3_H
- [cgal-discuss] Meshing 3D segmented domain with 1D sharp feature, rychet, 07/25/2011
- Re: [cgal-discuss] Meshing 3D segmented domain with 1D sharp feature, Laurent Rineau (GeometryFactory), 07/29/2011
