- To:
- Subject: Re: [cgal-discuss] Arrangement_2 : problem during insertions
- Date: Wed, 3 Aug 2011 20:13:29 +0300
1/4=0
1/2=0
Try instead:
rat(1, 4)
rat(1, 2)
http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/NumberTypeSupport_ref/Class_Gmpq.html
Ophir
1/2=0
Try instead:
rat(1, 4)
rat(1, 2)
Ophir
On Wed, Aug 3, 2011 at 3:36 PM, Pierre Cagne <> wrote:
Hi,
I currently use the facilities of CGAL about line arrangements, and I'm experiencing an issue. When I want to insert a segment line whose the endpoints are already vertices of the graph, I'm having that kind of error :
terminate called after throwing an instance of 'CGAL::Precondition_exception'
what(): CGAL ERROR: precondition violation!
Expr: ! is_degen
File: /usr/macports/include/CGAL/Arr_segment_traits_2.h
Line: 149
Explanation: Cannot contruct a degenerate segment.
Abort trap
Here is a minimal example code to get this error :
#include <iostream>
#include <CGAL/Cartesian.h>
#include <CGAL/Arr_segment_traits_2.h>
#include <CGAL/Arrangement_2.h>
#include <CGAL/Gmpz.h>
#include <CGAL/Gmpq.h>
using namespace std;
typedef CGAL::Gmpz NT;
typedef CGAL::Gmpq rat;
typedef CGAL::Cartesian<rat> Kernel;
typedef CGAL::Arr_segment_traits_2<Kernel> Traits_2;
typedef Traits_2::Point_2 Point_2;
typedef Traits_2::X_monotone_curve_2 Segment_2;
typedef CGAL::Arrangement_2<Traits_2> Arrangement_2;
int main(void) {
Arrangement_2 arr;
CGAL::insert(arr, Segment_2 (Point_2 (rat(0),rat(0)), Point_2 (rat(1),rat(1))));
CGAL::insert(arr, Segment_2 (Point_2 (rat(1/4),rat(1/2)), Point_2 (rat(1),rat(0))));
CGAL::insert(arr, Segment_2 (Point_2 (rat(0),rat(0)), Point_2 (rat(1/4),rat(1/2))))
return 0;
I kind of understood that point-location query might help me, but after several trials, I'm still at the same point (without pun :) ).
So, does anyone know how to do it ?
Thankfully.
Pierre Cagne
Etudiant à l'ENS de Paris
Département Informatique
- [cgal-discuss] Arrangement_2 : problem during insertions, Pierre Cagne, 08/03/2011
- Re: [cgal-discuss] Arrangement_2 : problem during insertions, Ophir Setter, 08/03/2011
- Re: [cgal-discuss] Arrangement_2 : problem during insertions, Pierre Cagne, 08/03/2011
