- To:
- Subject: Re: [cgal-discuss] disabling Core_Diagnostics
- Date: Fri, 5 Aug 2011 11:22:40 +0200
On vendredi 05 août 2011 10:06:18 Cody Rose wrote:
> Hello,
> Is there any way to disable the creation of the Core_Diagnostics file in
> CGAL programs using Core? Requiring my program to have write access to
> the directory it's running from isn't feasible.
If I were you, I would comment the following lines:
if (!outFile) {
// perror("CORE ERROR: cannot open Core Diagnostics file");
std::cerr << "CORE ERROR: can't open Core Diagnostics file"<<std::endl;
std::exit(1); //Note: do not call abort()
in core_error(...), line 192 of src/CGALCore/CoreAux.cpp, and recompile CGAL
libraries.
Laurent Rineau, PhD
- [cgal-discuss] disabling Core_Diagnostics, Cody Rose, 08/05/2011
- Re: [cgal-discuss] disabling Core_Diagnostics, Laurent Rineau (GeometryFactory), 08/05/2011
