Re: [cgal-discuss] Why do we need the property map parameters in read_xyz_points_and_normals()
- To:
- Subject: Re: [cgal-discuss] Why do we need the property map parameters in read_xyz_points_and_normals()
- Date: Tue, 9 Aug 2011 03:38:01 -0400
On Mon, Aug 8, 2011 at 9:34 AM, Laurent Saboret <> wrote:
Hi Yifei,
Property maps are a generalization of std maps. Using C++ templates, they allow to retrieve an information (eg a point position) from a map, from an object's field, from a C array, ...
In the example below, "point_pmap" and "normal_pmap" are temporary variables used by read_xyz_points_and_normals() to write the position and normal in the Pwn point type.
They are not used after the end of read_xyz_points_and_normals().
Yes, I can see that. But I'm still a bit confused. In function read_xyz_points_and_normals(), the position and normal are saved in "point_pmap" and "normal_pmap" as seen by the code:
put(point_pmap, &pwn, point); // point_pmap[&pwn] = pointput(normal_pmap, &pwn, normal); // normal_pmap[&pwn] = normal
At the same time, they are also saved in the container output:
*output++=pwn;
What's the point of this duplication? Thanks
Best regards,
Laurent Saboret
Le 08/08/2011 11:29, Yifei Li a écrit :Laurent,
I did look at the links you gave me. However, although property maps are passed as parameters in those examples, they are never used later. For example, in examples/Point_set_processing_3/read_write_xyz_point_set_example.cpptypedef std::pair<Point,Vector> Pwn;CGAL::read_xyz_points_and_normals(in, std::back_inserter(points), CGAL::First_of_pair_property_map<Pwn>(), CGAL::Second_of_pair_property_map<Pwn>())
the third and fourth parameter are two temporary variables only used in this function call, I don't understand the point of doing this. Without the third and fourth parameters, I would still be able to get the coordinate and normal information by iterating through the container points.
Also I took a look at the source code (read_xyz_points.h) and have a question regarding the following code:
else if (std::istringstream(line) >> x >> y >> z >> nx >> ny >> nz){Point point(x,y,z);Vector normal(nx,ny,nz);Enriched_point pwn;put(point_pmap, &pwn, point); // point_pmap[&pwn] = pointput(normal_pmap, &pwn, normal); // normal_pmap[&pwn] = normal*output++ = pwn;}
if I understand correctly, a property map consists of (key,value) pairs, just like std::map. In the above code, the address of a temporary variable, pwn, is used as key, and the container output stores all the keys. But what's the point of using the address of a temporary variable as key? How would you access the keys later?
Thanks
On Mon, Aug 8, 2011 at 4:44 AM, Laurent Saboret <> wrote:
Hi Yifei,
The "point_pmap" and "normal_pmap" property maps are used to access the point or normal information inside the "output" point type, so as to let the user decide upon the implementation of a point with normal.
See the property maps documentation at
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Point_set_processing_3/Chapter_main.html#Section_56.2
An example is provided in this documentation, and other examples are provided in "Surface Reconstruction from Point Sets" chapter
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Surface_reconstruction_points_3/Chapter_main.html
Best regards,
Laurent Saboret
Le 08/08/2011 09:24, Yifei Li a écrit :
Hi all,
read_xyz_points_and_normals(std::stream& in , OutputIterator output, PointPMap point_pmap, NormalPMap normal_pmap) is used to read coordinates and normals from a file (see CGAL/IO/read_xyz_points_and_normals.h). I don't understand what the parameters point_pmap and normal_pmap are useful for. It sounds like they are used to hold coordinates and normals respectively, but I think output is used for this purpose too. I guess I may use the function in the following way:
typedef std::vector< std::pair<Point,Vector> > points;
read_xyz_points_and_normals(input,std::back_inserter(points));
I appreciate your help.
Yifei
- [cgal-discuss] Why do we need the property map parameters in read_xyz_points_and_normals(), Yifei Li, 08/08/2011
- Re: [cgal-discuss] Why do we need the property map parameters in read_xyz_points_and_normals(), Laurent Saboret, 08/08/2011
- Re: [cgal-discuss] Why do we need the property map parameters in read_xyz_points_and_normals(), Yifei Li, 08/08/2011
- Re: [cgal-discuss] Why do we need the property map parameters in read_xyz_points_and_normals(), Yifei Li, 08/09/2011
- Re: [cgal-discuss] Why do we need the property map parameters in read_xyz_points_and_normals(), Laurent Saboret, 08/09/2011
