- To:
- Subject: [cgal-discuss] compile surface reconstruction example
- Date: Fri, 12 Aug 2011 05:57:29 -0400
Hi all,
I'm trying to compile the surface reconstruction example at http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Surface_reconstruction_points_3/Chapter_main.html#Subsection_47.3.2 using cake, and here's my CMakeLists.txt:
make_minimum_required(VERSION 2.8)
project(cgal)
find_package(CGAL)
include(UseCGAL)
add_library(taucs STATIC IMPORTED)
set_property(TARGET taucs PROPERTY IMPORTED_LOCATION /opt/local/lib/libtaucs.a)
add_executable(cgal main.cpp)
target_link_libraries(cgal taucs)
But I got following linking errors (snippet):
"_dtrsm_", referenced from:
_recursive_supernodal_solve_l in libtaucs.a(taucs_sn_llt_D.o)
_recursive_supernodal_solve_lt in libtaucs.a(taucs_sn_llt_D.o)
_recursive_leftlooking_supernodal_factor_llt in libtaucs.a(taucs_sn_llt_D.o)
_recursive_multifrontal_supernodal_factor_llt in libtaucs.a(taucs_sn_llt_D.o)
_leftlooking_supernodal_front_factor in libtaucs.a(taucs_ccs_ooc_llt_D.o)
_recursive_supernodal_solve_l_ooc in libtaucs.a(taucs_ccs_ooc_llt_D.o)
_recursive_supernodal_solve_lt_ooc in libtaucs.a(taucs_ccs_ooc_llt_D.o)
What are the other libraries should I link to my project?
Thanks
Yifei
- [cgal-discuss] compile surface reconstruction example, Yifei Li, 08/12/2011
- Re: [cgal-discuss] compile surface reconstruction example, Laurent Saboret, 08/12/2011
