cgal-discuss - Re: [cgal-discuss] assertion failed in test_runtime_rounding_modes
  • To:
  • Subject: Re: [cgal-discuss] assertion failed in test_runtime_rounding_modes
  • Date: Thu, 18 Aug 2011 11:34:10 -0400
Marc,
Thanks. Did you mean it's a problem of llvm-gcc (instead of Xcode)?  If this is the case, how come I can build and run cgal examples successfully?
Anyway, I'll try what you suggested.
Yifei
On Thu, Aug 18, 2011 at 9:48 AM, Marc Glisse <> wrote:
On Thu, 18 Aug 2011, Yifei Li wrote:
Hi,
I did see -frounding-math in the cmake output:
-- USING CXXFLAGS = '-O2 -arch x86_64  -frounding-math -fno-strict-aliasing -g'
How do I fix the problem?
Crystal ball... You are using a Mac with a recent version of Xcode.
Adding -DCGAL_FPU_HAS_EXCESS_PRECISION to the CXXFLAGS may help, but the last person who asked said it wasn't enough.
Best option is to complain to Apple with a link to:
http://llvm.org/bugs/show_bug.cgi?id=8100
(your compiler is llvm-gcc)
Now the crystal ball is sometimes wrong...
Marc Glisse
