- To:
- Subject: Re: [cgal-discuss] error when using CGAL 3.8 and taucs
- Date: Mon, 22 Aug 2011 12:08:02 +0200
Hi Kyewong,
Sorry for this late answer.
You are right, cmake forces you to use the /MD runtime. In the other hand,
CGAL Windows installer downloads TAUCS library for VC++ 9 with /MD runtime.
Your problem is probably different.
Could you describe more precisely the error you get? Is is at compilation or
execution time?
Best regards,
Laurent Saboret
Le 15/08/2011 08:52, kyewong a écrit :
Hi, i need to use both CGAL 3.8 and taucs in my project.
However, some problems(conflicts) are found.
*1* If i just simply use the taucs provided in CGAL 3.8, then error will
occur when running to the "taucs_ccs_factor_llt_mf" function I called in my
program. This error comes from the mlock.c file:
void __cdecl _unlock (
int locknum
* leave the critical section.
LeaveCriticalSection( _locktable[locknum].lock );
*2* I guess the reason for this error is that since only lib files of
dynamic link can be produced using cmake when building CGAL 3.8, the visual
studio project using CGAL 3.8 can only be of /MD option. This way, the taucs
lib should also be built under /MD, while the default taucs lib in CGAL is
built under /MT.
So if I still want to use functions such as "taucs_ccs_factor_llt_mf", I'll
have to recompile taucs under /MD independently, which will be another long
troublesome story...
I'm wondering if there is any elegant way to avoid this trouble please?
Thanks!
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/error-when-using-CGAL-3-8-and-taucs-tp3744007p3744007.html
- [cgal-discuss] error when using CGAL 3.8 and taucs, kyewong, 08/15/2011
- Re: [cgal-discuss] error when using CGAL 3.8 and taucs, Laurent Saboret, 08/22/2011
- [cgal-discuss] Re: error when using CGAL 3.8 and taucs, kyewong, 08/22/2011
- Re: [cgal-discuss] Re: error when using CGAL 3.8 and taucs, Laurent Saboret, 08/22/2011
