cgal-discuss - Re: [cgal-discuss] Test for intersection of Nef_polyhedron_3
  • To: <>
  • Subject: Re: [cgal-discuss] Test for intersection of Nef_polyhedron_3
  • Date: Tue, 23 Aug 2011 17:18:49 -0500
I would guess you could increase the speed by using AABB_tree::any_intersected_primitive(), if anything would, since that will terminate after finding any nonempty subset, and then follow up with an NEF polyhedron intersection to get the precise overlap upon finding that an intersection exists.
--rd
On 08/23/2011 05:16 PM, Robert W. Johnstone wrote:
Hello Everyone,
I'm wondering if there is a fast way to test if the intersection of
two NEF polyhedra would return a non-empty set. I understand that one
could get the result with a call of !N1.intersect(N2).is_empty(), but
suspect a dedicated method could be much faster. Does such a method
exist? If not, are there any suggestions on implementing this
extension?
Thank-you,
Robert
