[cgal-discuss] huge difference between running normal_estimation on Mac and Windows
- To:
- Subject: [cgal-discuss] huge difference between running normal_estimation on Mac and Windows
- Date: Sat, 27 Aug 2011 11:26:31 -0400
Hi,
I compiled and ran examples/Point_set_processing_3/normal_estimation.cpp on Mac and Windows respectively, using sphere_20k.xyz as input data.
It ran very fast on Mac:
Normal estimation
Open data/sphere_20k.xyz for reading...
Reads file data/sphere_20k.xyz: 21000 points, 0.355177 seconds
Estimates Normals Direction by Jet Fitting (k=18)...
done: 2.02112 seconds, 2391 Mb allocated
Orients Normals with a Minimum Spanning Tree (k=18)...
done: 0.596141 seconds, 2401 Mb allocated
Write file test.pwn
However, on Windows, it got stuck in normal orientation (I waited at least 10 mins):
Normal estimation
Open ..\data\sphere_20k.xyz for reading...
Reads file ..\data\sphere_20k.xyz: 21000 points, 1.078 seconds
done: 15.313 seconds, 5 Mb allocated
Any idea why there's such a huge difference?
P.S., The Windows machines is a virtual machine with 2GB memory
Yifei
- [cgal-discuss] huge difference between running normal_estimation on Mac and Windows, Yifei Li, 08/27/2011
- [cgal-discuss] Re: huge difference between running normal_estimation on Mac and Windows, Yifei Li, 08/27/2011
- Re: [cgal-discuss] Re: huge difference between running normal_estimation on Mac and Windows, Laurent Saboret, 08/29/2011
