cgal-discuss - Re: [cgal-discuss] building CGAL on cygwin/windows
  • To:
  • Subject: Re: [cgal-discuss] building CGAL on cygwin/windows
  • Date: Fri, 2 Sep 2011 10:54:40 +0200
Ok problem is solved.
For the record, my variable QGLVIEWERROOT was pointing to the
QGLViewer folder (containing qglviewer.h)
After pointing to the parent folder (containing
QGLViewer/qglviewer.h) , everything worked like a charm
Thanks for your help
Regards,
Eric Le Goff
http://gplus.to/elegoff
On Fri, Sep 2, 2011 at 10:21 AM, Sebastien Loriot (GeometryFactory)
wrote:
> [snip]
>> I have no idea which value I should set for the two missing cmake variables
>> Any idea ?
> Where is located the file QGLViewer/qglviewer.h on your system?
> try setting cmake variable directly if you have it.
> Sebastien
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
