- To: <>
- Subject: Re: [cgal-discuss] eigen-decompose the gradient of normal field
- Date: Mon, 12 Sep 2011 23:28:42 +0800
- Importance: Normal
Dear Marc Pouget,
I don’t know how to thank you. If it were not you, I won’t be able
to find where my mistake lies so quickly.
I have read your suggested document on principal curvature,
and it proves the eigenvectors of grad(n(x)) and the eigenvectors
of the weingarten map are just the same, except that the former
are expressed in x,y,z coordinates, while the latter are expressed
in tangent space spanned by the two principal directions.
I noticed my derivation of grad(n(x)) is a little different from
that presented in www.geometrictools.com/Documentation/PrincipalCurvature.pdf,
and
mine was not correct. After correction, now the results are expectedly
right.
Again, thank you very much, and thank CGAL forum for
being such
a
wonderful place to get help!
Yajie.
Sent: Monday, September 12, 2011 5:50 PM
To:
field Hi,
I dont understand your formula what is \nabla{n(x)},
anyway, I dont see how you can get rid of the 1st and 2nd
fundamental forms here and hence the weingarten operator. A way to get
around it and obtain "closed" formula is given there:
(you may want to try Spivak or Porteous for
proofs)
Best
Marc
On Sep 12, 2011, at 10:00 AM, yanyajie wrote:
- [cgal-discuss] eigen-decompose the gradient of normal field, yanyajie, 09/12/2011
- Re: [cgal-discuss] eigen-decompose the gradient of normal field, Marc Pouget, 09/12/2011
- Re: [cgal-discuss] eigen-decompose the gradient of normal field, yanyajie, 09/12/2011
