cgal-discuss - Re: [cgal-discuss] license of CGAL's Tet mesh generation... compatible with Slicer license?
  • To:
  • Subject: Re: [cgal-discuss] license of CGAL's Tet mesh generation... compatible with Slicer license?
  • Date: Wed, 14 Sep 2011 15:50:00 +0200
On 14/09/2011 15:38, Audette, Michel A. wrote:
Dear CGAL developers,
my collaborators and I are giving some thought to integrating the CGAL
tetrahedral mesh generation with Slicer, but I was wondering about the
particular license of this implementation: can the license be made
compatible with Slicer's, which is BSD? Can any restriction be
circumvented by distributing binaries only?
Best wishes,
Michel
Michel Audette, Ph.D.
Assistant Professor,
Department of Modeling, Simulation and Visualization Engineering,
Old Dominion University,
Norfolk, VA.
Hi Michel,
CGAL is under the QPL, which is compatible with BSD.
Only distributing binaries is not a solution but a problem:
The QPL obliges you to distribute source code.
Note that as slicer is distributed under BSD it can be integrated
in commercial code. By integrating CGAL in slicer, this is no
longer possible, as users have to take into account the strongest
restriction of the licenses. That is, when you integrate CGAL,
the CGAL files of the slicer distribution are still under the QPL
and not under the BSD.
Hope this helps,
andreas
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
