- To:
- Subject: Re: [cgal-discuss] Error using Taucs
- Date: Mon, 19 Sep 2011 16:10:37 +0200
Hi Mario, Please check that you use the latest version of TAUCS: * on Windows, the recommend way is to use CGAL installer and select the option to download TAUCS (precompiled) * on Unix, you need to download taucs_full.tgz from https://gforge.inria.fr/frs/?group_id=52 (in section "TAUCS 3.5"), then compile and install it When TAUCS is installed, you should run again cmake and make (or compile in Visual Studio). Best regards, Laurent Saboret Le 14/09/2011 19:39, Mario Ynocente Castro a écrit : Hi everyone, i'm testing a method for Poisson Image Editing. However I'm getting the following error : taucs_ccs_ops.c:185: taucs_dccs_permute_symmetrically: Assertion `A->flags & 8 || A->flags & 16' failed. |
- [cgal-discuss] Error using Taucs, Mario Ynocente Castro, 09/14/2011
- Re: [cgal-discuss] Error using Taucs, Laurent Saboret, 09/19/2011
